Question about JES Hardware Solutions (IT70-7-DVD-DZ) Removable Disk Library
My disk does not store to full capacity - JES Hardware Solutions (IT70-7-DVD-DZ) Removable Disk Library
    Brigadier General:
  • 10,406 Answers
What is the advertised capacity of the library, in bytes? in thousands (1000) of bytes? of millions (1,000,000) of bytes?
What is the currently-reported capacity of the library, in bytes? Kilobytes (1024 bytes) ? Megabytes (1024 Kilobytes) ?
Posted on Mar 18, 2011
How to recover capacity of Hard drive
Use Windows disk management utility and reformat de hard disk, simple, fast and easy
Oct 19, 2016 | Hard Computers & Internet
Erasing Memory from KX-FHD332
Follow page 65 and 72 of Panasonic KX FHD332 Operating Instructions Manual
Memory full
When making a copy, the document being stored exceeds the memory capacity of the unit. Press {STOP} to clear the message.
Divide the document into sections.
Fax/memory full
The memory is full of received documents due to a lack of recording paper or a recording paper jam. Install paper (page 14)
or clear the jammed paper (page 72).
L When performing memory transmission, the document being stored exceeds the memory capacity of the unit. Transmit the entire document manually
Mar 11, 2016 | Panasonic Office Equipment & Supplies
How do you solve cant print pc says "procees cannot be processed because there is insufficient disk space"
My guess: verify the capacity of your Hard Disk. Is is really full? It it is full, it's time to make a big cleanup, removing file you don'r really need.
If you hav enogh storing space, you should check the structure of your hard disk.
go co command mode cmd and ru chkdsk c: (or teh unit it supposed to be)
This commend shouldn't make any changes in your disk. If it encouters some siginificative error, which should justifiy the message, you can repair hard dis using CHKDSK C; /F
YOU SHOULD BACKUP YOUR DATA FIRST
When the hard disk has serious issues, Chkdsk sometimes acts weird.
Jun 08, 2015 | Office Equipment & Supplies
What is the Platinum content on a 3.5" platter
The hard drive is the component of the computer where data is stored. Each drive contains one or more platters or disks where data is stored on the magnetic surfaces. The amount of data that can be recorded on a given surface depends very much on the strength of the magnetic field generated by the surface layer.
Platinum enhanced magnetic alloy allows data to be stored at much higher densities.
Back in 1957 when IBM first introduced the hard disk, storing just 5 megabytes of data require fify disks, each measuring 24 inches in diameter. Sixty years later, a much smaller 3.5 inch disk drive is capable of storing over 500 gigabytes of data. An important process to achieving this remarkable increase in storage capacity is by adding platinum to the cobalt alloy to enhance its magnetic properties, allowing data to be stored at higher densities.
With so much digital content being created (at higher and higher definitions) and then shared online by millions of people over high speed broadband internet, the strong demand for higher capacity disk drives has resulted in more platinum being used in the manufacture of hard disks to enhance their storage capacity. The proportion of platinum in the magnetic alloy has gone up from less than 10 percent in 2002 to 35 percent in 2007.
Nov 29, 2010 | Seagate (ST3160827AS) 160 GB Hard Drive
My 250 gb hard drive is only showing capacity of 127gb
Firstly install SP3 if that doesnt work you need to update your bios to get large disk support. If you dont want to perform any of these fixes you could simply split the drive into 2 or more partitions to access the full 250gb. Goto Control Panel/Computer Management/Disk Management you will see in there the missing gb's of your drive. Simply right click it format it and give it a drive letter.......Cheers from Scott
Apr 18, 2010 | Microsoft Windows XP Professional SP2
My DVD drive does not seem to recognize "space" on blank DVDs. I inserted a blank DVD and it kept telling me that it had 0 byte on my DVD when in fact it had 4.7 GB.
Normally a DVD blank or has data stored on it will not show unused disk capacity. If will show the disk capacite of the space it has used.
The read/write DVD disks will show the capacities used and unused after the disk has been formatted and data copied on these DVD disks.
Sep 14, 2009 | Lenovo ThinkPad T61 Notebook
8gb memory stick only able to take 2mb of data
What?  Perhaps you mean your SDHC SD memory card can only store 2GB of data because your card reader and its drivers are pre-SDHC?  Usually formatting isn't an issue.  You get a "disk full" error after 2MB, copying from some file manager?  What, really?
Jul 31, 2008 | Computers & Internet
Capacity
Pre 1999 machine with Award BIOS? If so, this is because when they designed your computer, they didn't imagine 80 GB drives were a realistic prospect. Suggest you download DiskWizard from Seagate's website and use that instead of Windows to format the disk. Hopefully this will be enough to let you see the full capacity of the disk. A.
Feb 12, 2007 | Seagate Barracuda 7200.7 80 GB Hard Drive
JES Hardware Solutions (IT70-7-DVD-DZ) Removable Disk Library Logo
55 people viewed this question
Top JES Hardware Solutions Computers & Internet Experts
David Payne
David Payne
Are you a JES Hardware Solutions Computer and Internet Expert? Answer questions, earn points and help others
