Question about HP w1907 LCD Monitor
POWER BIYYON LOCKOUT hard to get minitor to come on THIS IS A NEW COMPUTER ONLY 6 MONTHS I OLD AND PROBLEM JUST STARTED
I accidently went to settings and went to format and presses yes and it deleted everything i had. It happened like 6 months ago. Over the 6 months i have started over with putting songs on it and...
Unfortunately, you have likely overwritten the old songs by copying new songs.
One free product worth trying is Recuva (http://www.piriform.com/download)
Download and install Recuva, plug the mp3 player into your computer, and see what can be recovered. Even if you can see some of your old songs they might be corrupted so make sure to listen to them.
I hope this has been informative.
Mar 07, 2011 | SanDisk Sansa e250 MP3 Player
1st, my desktop (dell Dimension 5100) had been not used for several months. When turned on, the green error code lights 3, 4 and a flashing battery appeared, along with a beeping noise. I read up on the...
I assume your new computer has IDE controller on the motherboard.
Yes you can install your old hard drive into your new computer as a Slave hard drive.
If the old hard drive is installed on the 2nd IDE controller and it is the only device on the controller then the jumper and be master or slave, but connect the hard drive at the last connector on the IDE cable.
Oct 18, 2010 | Dell Dimension 5100 (D51L1) PC Desktop
I bought a WD5000BEV harddrive in december 2009 and within 6 months it has started giving me problems. Sometimes the computer recognises it and some times it does not. Even thought it appears on the...
Probably not the right answer for your problem. Mine is an external 1 TB Simple Drive. Mine wouldn't respond at all. I unplugged the power cable from the back of the hard drive and replugged it in and instantly it worked (with the computer and hard drive plugged in). I had tried rebooting the computer, plugging/unplugging over and over into the computer and that didn't work.
Jun 16, 2010 | Western Digital External USB 2.0 80 GB...
Computer will power up but hard disks, cd roms, and minitor will not . i do get power to cooling fan and floppy drive
you may have a motherboard issue if you cant get hard drive activity or a display unfortunately there is nothing you can do unless you take it to a repair shop i am sorry!
Dec 19, 2009 | E-Machines T3958 (827103050974) PC Desktop
Iomega 500gb power supply failure
if it's 6 months old, you should be still having warranty, suggest you take it back to where you bought it from.
Jul 18, 2009 | Iomega MiniMax Desktop - Hard drive - 500...
Sea gate ext drive started making clicking noise will not connect
It is still under warranty. Contact Seagate about this matter. They should replace it for you at no cost.
Jan 28, 2009 | Seagate FreeAgent Pro Desktop - 320GB -...
Just rebuilt new pc
Dont connect the monitor via your graphic card, its not installed yet. Connect your minitor via the motherboard.
Good luck to you
Dec 17, 2008 | Dell E193FP 19" Flat Panel LCD Monitor
HP w1907 LCD Monitor Logo
53 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
