Question about Honeywell 3820 Wireless Handheld Barcode Scanner
I left my 3820 Honeywell handheld scanner off the base for a couple hours and now when I try to scan, it just beeps. I left it on the base overnight, thinking it needed to be charged, but after more than 12 hours, it still beeps after reading a barcode.
Corster
  • 79 Answers
SOURCE: problem with scanner
Yeah, from the manual, scan the following settings:
Scan Suffix
7
0
0
9
Scan Options
<DATA> <SUFFIX>
Enter
It's best to copy the necessary barcodes from the manual at 200% zoom, into a Word document and print it out.
Posted on Jan 03, 2008
  • 25 Answers
SOURCE: Barcode scanner scans and beeps, but will not put the numbers in the computer
There is more than one way for that imager to send data to the computer. Are you using USB, serial, or is there a little box that goes between your existing keyboard and the PC that accepts the scanner connector?
Posted on Jan 05, 2008
SOURCE: symbol ls 2106 handheld scanners
I cannot get it going on the pc with windows xp pro
Posted on Sep 14, 2008
SOURCE: The scanner is scanning but no data is transmitted to the PC
I also purchased a Symbol LS4071 and when I connected this scanner (purchased at a great discount through eBay) to my computer using the keyboard wedge (with a ps2 connection - the round connector - the connector is split like a "Y") I received the error message that my computer could not recognize this external hardware. I went to barcodediscount.com and ordered the usb connector for this scanner as usb connections are usually recognized. The part # for this connector is STI85-0200R. It cost 72.55 with shipping, but I received the scanner at such a wonderful price that I thought I'd chance it and try it with a usb rather than a keyboard wedge connector.
The computer immediately recognized the usb connection, and the usb connector comes with a manual with codes to enable proper scanning, but still no luck getting the data into the computer. So I called Symbol's technical support department. The technician told me to remove the rubber "boot" at the bottom of the hand held scanner (not the scanner base) by pulling on the front of it (where the 2 little round circles are). It's tough to remove, but keep at it. Then gently remove the battery and unplug it, then plug it back in and reattach the base. He said this would reset the battery. Voila!!!! Sucess!!!!
If your scanner's keyboard wedge connection is recognized (a little popup window will say that it is a Symbol barcode scanner and that it is installed and ready to use), try taking the battery out and putting it back in to reset it. Hopefully this will also work for you. Symbol's technical support # is (800) 722-6234.
Posted on Mar 23, 2009
  • 74 Answers
SOURCE: 4 beep error when scanning barcode
The four beep error is a communications error. Usually it indicates the scanne is not configured properly. If the scanner is connecting with the CBA-K01-S07PAR cable and you are using a PS/2 keyboard you should have scanned the IBM PC/AT barcode from Adobe page 56 of 342 of the LS2208 Product Reference Guide.
If you do not have a PS/2 keyboard attached and are using a USB to PS/2 adapter you should scan the IBM AT Notebook from that same page. If the scanner does not start working immediately you may have to reboot your system. If the scanner still does not work the CBA-U01-S07ZAR USB cable might be a better choice.
If you are not connecting with either of these cables and are still getting the four beep error a call to the Motorola support center may be in order. Their phone number is 800-653-5350.
Posted on Oct 23, 2009
I have a Binatone house Telephone and it has locked
take the batteries out for 24-48 hours and let it sit unpowered to see if this helps (usually does)
Oct 01, 2014 | Honeywell 2020-5BE Compact Cordless Charge...
Honeywell Barcode Scanners configure for Excel
Find solutions to your Honeywell Barcode Scanner...ask an expert to help you find the right scanner for your application. Honeywell Barcode Scanners for handheld and handsfree bar code scanning
Jan 22, 2014 | Honeywell 3800g Barcode Scanner PN...
Barcode Scanner stopped scanning
These devices do fail, so that is most likely what has happened here.
Apr 13, 2017 | Honeywell 3820 Wireless Handheld Barcode...
My 3820 will no longer scan Follett barcodes. It makes several error beeps every time I try to scan anything
srodgers609
One of the problems I had with my scanner is that the USB port that I had the scanner in when bad. My scanner cable was a little short and it put extra pressure on the port. After time some of the connections in the port broke. To fix the problem I had to replace the USB card in the system.
So I would recommend that you tryu the scanner on another computer and/or another USB controller to see if it works properly. If it does you know that it is the USB port. If it does not then I would look at the cable of the scanner.
Let me know if you have any more problems or questions
Issken
http://www.fixya.com/users/issken
Aug 25, 2011 | Honeywell 3820 Wireless Handheld Barcode...
My Wasp wws-800 works while in the docking station but not when removed, suspect li-ion battery but have not been able to find a replacement. Any ideas
your wws800 should have come with two batteries. One goes in the reception base and one goes in the scanner itself. You should allow for four to 6 hours to fully charge. When charged, scan the setup barcode on the bottom of the reception base and then the BASE code. This will allow your scanner to create a connection with the base. Give it 5 secs or so, you should hear three beeps.
Jul 20, 2011 | Wasp WWS800 Handheld
HOW DO I RESET A CORDLESS SCANNER HONEYWELL 3820?
I believe you can print the documentation and scan a bar code to reset the scanner. You can get the documentation here: http://lib.store.yahoo.net/lib/barcodescannersdiscount/3820UserGuide.pdf
Press CTRL+F and type "reset" to find sections on resetting the scanner.
Mar 02, 2011 | Honeywell 3820 Wireless Handheld Barcode...
Scanner won't read the barcode
you read the code base?
Try another computer, if it is the same, council liaison without base.Direct bluetooth.
Dec 17, 2008 | PSC Quickscan 6500 Handheld
Honeywell 3820 Wireless Handheld Barcode Scanner Logo
221 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
ray gallant
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
