DTI6300 recorder. Sometimes records and sometimes not. Seems to record, red light on, and then lists programme as recorded, but then only plays a blank screen.
Had it 3 months,it was fine,now it has stopped recording and has erased all programmes i had recorded,do i just take it back to comet?
Posted on Aug 30, 2008
Why is it not recording when on standby
To select a programme to record, press the OK button, it will then give you options such as HD or SD, One-off or Series.
Aug 28, 2014 | Televison & Video
Magnavox MDR533HF7 timer programmer records wrong channel sometimes
You have to record some channels manually and you can not use the timer. Since TV went digital the channels are not really on the channel that you see. Where I live channel 5.2, 5.3, 5.4, and so on are really on channel 35 and 45. This tuner has a hard time with these channels because they are not on the station that you see and it does not look like this will be fixed.
Jun 20, 2014 | Magnavox Mdr533h Dvd Hdd Recorder
I have a Thomson DTI6300 which has given many years of very heavy use and still going. However, since switching to Freeview EPG the series record function is recording EVERY occurance rather than just the...
If you select all the available channels for Anytime to download from then the box divides up the available drive space in such as way as to leave you with just 16 hours' worth of space for your personal recordings. The only way to free up more room for your own recordings is to reduce the number of channels you want downloading, which rather takes away the whole point of the system to start with, and also is not actually much of a remedy. After pruning the channel download list quite ruthlessly we were still only left with 31 hours of personal space and that is still really not enough.
The Sky-like UI
This box needs a fair bit more disk space or a more fluid method of dividing up the available space, perhaps by allowing you to alter the length of time the system stores downloaded content. As it is, programmes downloaded will erase themselves after six days unless moved into the personal storage - so exit the 31 hours, stage-left, at a gallop - thereby ensuring the hard drive always has space for the following period's downloads.
Fortunately, the box is smart enought to automatically check that no programmes downloaded overnight match any of the programmes already recorded to avoid doubling up on content.
Dec 05, 2013 | Televison & Video
My logik L160STB11 freeview tv recorder won't record properly
mine did that then wouldn't recognise the hard-drive
Apr 25, 2012 | Televison & Video
My thomson DTI6300 digital TV recorder shows that it is recording but does not stop at the required time. No recording is actually made and the message comes up ''recording failed''. This happens whatever...
If you have no recordings and it's playing up, I'd do a complete reset as follows;
Restore Factory Defaults
This will restore all the factory settings and erase the contents of the box.
Menu>Set-up>Help>Green>Red
Format HDD
This will re-partition and re-format the hard drive.
Menu>Set-up>Help>Green>Blue
This will wipe everything you have recorded. It will also dump your 14 day Electronic Program Guide which will take upto a day to reload. Leave the unit on standby.
You might want to take this opporunity to do a channel scan as well.
Jan 22, 2010 | Televison & Video
I have purchased a Teac HDR2500T video recorder. I can set up to record television programme through EPG or PVR. I can see in LIST that the programme is recording, however when the programme is finshed,...
The part re the other channels having no signal....I had the same problem with mine and that was because the small loop cable in the back wasnt right. I could watch all channels, press record and still watch that channel but try to watch a diff channel while its recording and they were gone. As soon as I had the loop cable in properly it solved the problem. Hope this helps....
Sep 06, 2009 | Televison & Video
Recording fails to delete
Record another programme so that you have something above the dodgy one in your library. Then go back into your library and press down, blue then green really fast. This worked on mine.
Jan 02, 2009 | Philips DIRECTV H20 DTV Receiver
Thomson DTI6300-25 connections
THOMSON DTI6300-25 my mother has one of these but the recorded programs jam so now she can't watch what shes recordered or record anything else (3rd replacement box to do this)
Aug 11, 2008 | Televison & Video
Himage 4010 dvr recorder
i have a propblem with the same dvd but mine when you play the disc the color is wrong it comes out red or green if you have the souloution to this problem plese contact me at chubb_pb4ugo@hotmail.com thank you.
Dec 05, 2007 | Aspire Digital AD-8091 DVD Recorder
Open Questions:
Televison & Video Logo
55 people viewed this question
Top Televison & Video Experts
Electro Med Services...
