Question about Sony VAIO VGC-RB52 PC Desktop
Won't start says windows did not shut down normally tries to start but comes back to same screen
  • sheffernan4 Apr 21, 2011
    The motherboard was replaced by sony over a year ago it has worked since.
  • 449 Answers
Could be dozens of things. This usually happens when there is a crash (blue screen) during boot up. Did you recently do any upgrades? Is this Windows XP or Vista? Try starting in Safe Mode if you can. The possible fixes include doing a CHKDSK (check disk), rolling back to older drivers, or a repair install of the OS.
Posted on Mar 18, 2011
Testimonial: "Very speedy service. "
  • 7 more comments
  • sheffernan4 Mar 18, 2011
    There was a power failure when a truck took down an overhead powercable outside. It does get to the windows screen to try start up after several attempts I get a message cpu temp is out of range press f2 then f2 says temp is 86 in red
    sorry windows xp and the motherboard was recently replaced.
  • Phil
    Phil Mar 18, 2011
    A CPU overheat will cause a system shutdown (to protect the CPU from damage), and it will be a sudden and ungraceful shutdown, the kind that makes Windows display that screen. Sounds like the heatsink and fan assembly may not be installed correctly: You need to have some specialized thermal grease between the CPU and heatsink, the heatsink needs to be the right type for the CPU, the fan needs to be spinning on the heatsink, and the tines should be free of dust. More details athttp://www.build-your-own-computers.com/...
    Thanks I will try that. Thanks for the speedy advice.
    I fixed the overheat problem but still will not boot up gets as far as windows xp screen then pentium D screen then back to windows did not shut down properly. Please help. How do I fix this.
  • Phil
    Phil Mar 18, 2011
    That means it's crashing during the boot process. Could be a corrupted file, or any number of things. If you can take the install disk and boot into Windows Recovery Console, you can run a CHKDSK and see if you can fix any errors on the disk.
    http://www.windowsnetworking.com/article...
    Run CHKDSK C: /F at the recovery console to check disk and fix errors.
  • sheffernan4 Mar 19, 2011
    The only disc I have is a vaio recovery media kit I got from Sony will that work?
  • Phil
    Phil Apr 21, 2011
    The Vaio recovery kit is great, but that will erase all of your software and set it back to factory settings. And, if you replaced the motherboard, the recovery disc won't work.
    Also, tell me about the new motherboard - is it an exact factory replacement, or a 3rd party upgrade? Has the unit EVERY booted since the motherboard was replaced? Windows XP cannot just transfer between motherboards if you install a different type of motherboard, you need to reinstall. And you generally can't re-install from recovery CDs.
    Can you tell me more details?
  • Phil
    Phil Apr 21, 2011
    OK, if it is a factory replaced motherboard, you can use the recovery CDs, except that will erase everything on the hard drive!!
    I don't know if the Sony repair disks let you do a repair install of the OS or not. There are a couple of things you can try, but depending on the underlying damage you might not be able to do much short of reinstalling.
    There are repair things you can do, but it required burning CDs on another machine and doing a lot of stuff that can easily do more harm than good. Do you want to go that way?
Acer aspire 5520
try f8 at the logo screen then disable automatic restart on system failure from the menu to find out what the error is
Jul 15, 2017 | Computers & Internet
Hp dx2200 computer won't power off
If your HP computer refuses to power down, this means that there are still programs open that Windows can't close. Normally when you select the "Shut Down" button from your "Start" menu, Windows closes all open programs, then closes itself, and your basic input/output system (BIOS) turns off all of your hardware. If Windows can't close all open programs, your computer won't be able to power off. This means that you must close these programs yourself.
Right-click on the window of an open program on your Windows taskbar (Bottom of Screen) Click "Close Window." Windows manually closes the program. If a window appears on-screen indicating that Windows cannot get the program to close, click the "Force Close" button in this window to have Windows force the program to shut down. Repeat "Step 1" for any additional programs that are open on your computer. Click "Start." Click "Shut Down." Hope this helps.
Dec 10, 2012 | Computers & Internet
My XPS M2010 had a pop up when I went to turn it on today. I beleive that it never shut down. Pop up said program did not shut down properly do you want to find solution and close or close program. I chose...
There are two reason for this error message
1 Hardware failure
2 Software failure(OS)
To eliminate hardware failure run the hardware diagnostics on the computer.. Use the link
http://findtechhelp12.blogspot.com/2010/12/how-to-run-dell-diagnostics.html
If all the hardware is working well then the issue is with the OS - reinstall it
http://findtechhelp12.blogspot.com/2010/11/how-to-reinstall-os-in-dell-computer.html
Dec 07, 2010 | Dell Computers & Internet
Gateway laptop mx3414-black screen cannot load windows
Try going into safe mode upon startup by hitting the F8 button. If it does then hit safe mode to get into your computer. Go to start>accessories>system tools>system restore. Follow the wizard to restore your computer to a date earlier than when you started having problems. Let me know if you have any problems or questions.
Mar 19, 2009 | Gateway MX3414 Notebook
Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
May 19, 2008 | HP Compaq Presario V2000 Notebook
My computer keeps restarting itself
  1. Start laptop
  2. When the laptops Logo page closes, start to press F8
  3. You should get a Windows Start screen
  4. If you get a Windows Logo page (the kind you normally get when Windows loads, then reset it and start again.
  5. On the Windows Start page select "Last known good configuration" and press enter twice
Hope that solves it for you =)
Apr 12, 2008 | Acer Aspire 5500 5570-2609 Laptop
Sony VAIO VGC-RB52 PC Desktop Logo
85 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
