Question about Magellan RoadMate 1440 Car GPS Receiver
My gps just shut down, yesterday it kept trying to powering up but it never did, sometimes it tired to, now it wont do anything, its only 2 years old.
  • 391 Answers
Hi it would be possible that your battery has given up its last legs i suggest you replace the battery firstly and reset the unit then calibrate i hope this helps it would also be wise to update your maps gooodluck with it
Posted on Mar 18, 2011
Goes into overload and shuts down
Not very much information in your problem troy but you might be drawing more amps than your producing. I had bought a nice little Craftsman electric tire pump but my Yamaha kept dying. After reading the labels, my 2400IS puts out 15 amps and my tire pump needed 18 amps, my friend now has a nice tire pump for his home use. I've seen post that RVers have to add the "booster" kit to start their air conditioners, extra power is needed to start them after that the 2400 can run them. Just a thought, try reading the metal tag on what your trying to run and see how many amps it needs. Anything over 15 will shut you down and some will need that extra "boost" to get them started. I seem to think I read somewhere that it is about $75.00 for the Yamaha booster kit.
Aug 12, 2013 | Yamaha EF2400iS Portable Generator
Premature power down.
Check for loose or corroded power connections.
Jul 12, 2013 | Lowrance LCX-113C HD GPS Receiver
My GolfBuddy World Platinum in stuck in "Factory Mode" and wont do anything.
Press and hold power and menu buttons at same time til unit shuts down. Press power button...tah dah
May 26, 2011 | GolfBuddy Tour Handheld GPS Receiver
My gps will not turn on I need to sent in for repair.It's under 2 year service plan that is going to expair in one months.
Explain not turn on as sometimes that has mre than one meaning.
If it wont charge then that is different to pressing the power button and it not turning on.
A lot of people also say it wont turn on but the steps below usually fix many of these situations.
If you have an SD card in try removing that before you power up.
You may also want to try the hard reset.
Paper clip in the tiny hole by the card slot.
Push it in firmly whilst the unit is powered up (not too hard) for about 3 seconds then release
You may have to power down and then up again and even hold down the power button a little longer the first time you do this
Sep 06, 2009 | Tomtom GO 510 GPS Receiver
My tom tom cannot track its GPS and the screen freezes
My tomtom one screen kept showing that it was waiting for a valid gps signal all day yesterday 7/1/09 what can I do to fix this problem?
Jul 02, 2009 | Tomtom GO GPS Receiver
Hummingbird GPS Matrix 12
evidently the installer put 2 inline fuses to the power line. After more investigating I located the second fuse which was blown.
Jun 22, 2008 | Audio Players & Recorders
I love this unit!
Resetting should not remove your maps. Have you purchased new maps since you bought the unit? Have you tried charging the unit via the computer, or just with the car charger. Sometimes charging on the computer can help.
Feb 03, 2008 | Garmin StreetPilot C330 GPS Receiver
GPS 2200T Just Quit Today
My 2200T developed similar problem and shut down and when attempting to start it, I received “low battery message”. After getting a run around from the manufacturer (out of warranty by a month), I decided to take a look myself. This does not men that I encourage just anyone to do this and if you break the unit more seriously I am not responsible. The process is as follows:
Unscrew the back panel (six screws), gently remove it (be careful of the speaker wires attached to the PC board). You do not have to remove the back panel any further than to get access to the power outlet (where you plug in the power supply). On the inside of the unit, on top of the outlet is a thin copper plate, it is likely that it was bend up with use and lost contact with the plug. Gently bend it inwards using a small screwdriver (be careful not to break it). That should do it. Your unit should be getting the power and battery should charge now.
Feb 03, 2008 | Magellan RoadMate 2200T GPS Receiver
Magellan RoadMate 1440 Car GPS Receiver Logo
171 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
