Question about GE Ovens
On "bake" my GE profile
    Champion:
  • 202 Answers
Make sure the display is correct put a thermometor in oven to get correct reading
Posted on Mar 18, 2011
  • 1 more comment
  • swillrett Mar 18, 2011
    the way i know the actual temp vs. the display temp is with an oven thermometer.
  • Frank England
    Frank England Mar 18, 2011
    yes just a cheap you can buy at hardware store be sure it g0,s to 500 degrees
    I did, that's how i know the actual temp only goes to about 225.
General Electric oven how to reset thermostat
First of all, most oven thermometers move very slowly compared to the electronic sensors and controls on the oven. To make sure you are getting an accurate reading, the thermometer should be in the center of the oven, the oven should be preheated, then wait another 20 minutes after the preheat beep. If the temperature is less than 35 degrees higher or lower at this point, it can be adjusted via the controls. Usually on GE ovens you press and hold bake and broil at the same time until SF comes up in the display. Then press bake, then use the arrow keys to raise or lower the temperature setting. If the temperature is more than 35 degrees off, you may have a bad sensor, bad control board, or other problem.
Aug 08, 2014 | GE Profile JTP18 Electric Single Oven
When attempting to turn the oven on, I press "bake" and the display reads F-3. What is it? How do I get rid of it and start baking again? ( model # MP31WO^2WW) (serial # RV2066660)
Hi
F2 Error indicates a loose/broken wire on the oven temp sensor or the oven temp. sensor itself is bad and should be replaced. To solve this issue test the oven temp. sensor, it should read between 1080-1120 ohms, if the rating is more then that and the door appears to be closing fine then it is the control board that is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Aug 31, 2011 | GE Profile JTP18 Electric Single Oven
Bottom element is not heating to temp an shuts off during heat up - without error code showing in the display. IE. - Press Bake, 350 degrees defaults on screen; Press Start. YOu hear the Click as it...
Hello & Welcome to FixYa
This indicates an open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you wan to be sure before replacing the sensor then you can test it with a voltmeter for around 1100ohms....if it reads more then this then it needs replacement however, if the reading is around or less then 1100ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Mar 05, 2011 | GE JTP15 Electric Single Oven
The oven temperature isn't correct. Ovenw Won't heat up.
has the oven got a fan on it. if so then maybe fan is faulty.
if convection oven then maybe one of elements is faulty
or the thermostat is a problem
regards
richard saupe
Appliance repairman colchester
appliance repairman
Mar 14, 2010 | GE Profile JT915 Electric Single Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
The Oven is set to 450 does not get above 280
  • When the food you're baking is done on top but not on the bottom--or when baking just takes far too long to finish--the bake element may be burned out.
    You may get fooled into thinking it's working, because the oven is hot inside. But many electric ovens use the broil element, too, during the preheat and bake cycles. So the food may be getting heated only by the broil element, which causes poor baking results.
    If the bake element is burned out, replacing it should solve the problem. Otherwise, you need to further troubleshoot the oven's electrical system to locate the defective wire or component.
  • When the temperature is consistent but too high or too low, it could be one of several different things. First check to see if the thermostat sensing bulb has come loose from its holder. It could be lying on the floor of the oven or resting on the heating element. This would cause the oven to not heat correctly.
    If the thermostat bulb is not dislodged, it's likely that the thermostat or sensor is either mis-calibrated or defective.
    Electronic ovens with a digital display use a sensor to monitor oven temperature. To solve temperature problems for these models, you may need to replace the sensor. On some digital-display models, you can calibrate the temperature using the key pad. See your operator's manual for details.
    Ovens without a digital display often use a mechanical system for controlling temperature. On many of these units, you can remove the thermostat knob and adjust the knob itself to more accurately represent the actual setting of the thermostat.
    If, when you remove the knob, there's a screw on the back of it with a small calibration plate, you can loosen the screw, adjust the plate, then tighten the screw again. If the knob isn't adjustable, and the oven temperature is off by more than 30 to 40 degrees, you need to replace the thermostat to solve the problem.
  • Aug 14, 2009 | GE Profile JT912 Electric Single Oven
    GE Oven MODEL J KP27WOP2 WG - WILL NOT HOLD TEMP
    You can re-calibrate the oven as follows;
    press BAKE pad.
    select temp of 500 degress or more.
    immediately PRESS and HOLD the BAKE pad until "00" appears.
    Then press the + or _ pad to adjust temp up or down 5 degrees at a time.
    When fimished press the Clear/Off pad.
    Mar 15, 2009 | GE JTP15 Electric Single Oven
    JTP18WD01WW no broli, no bake panel works
    my wife has arthitis in her hands and the touch screen does not work when she touches it . otherwise it works fine when i use it . is this a body temp problem .
    Nov 04, 2008 | GE Profile JTP18 Electric Single Oven
    GE PROFILE MODEL JTP18WOAZWW
    try fix at  http://www.fixya.com/howto/h155060-dreaded_f7_error
    worked for me.
    Jun 09, 2008 | GE Profile JTP18 Electric Single Oven
    Ovens Logo
    109 people viewed this question
    Top GE Ovens Experts
    William Miller
    William Miller
    Dan Webster
    Dan Webster
     Fix Your Board
    Fix Your Board
    Are you a GE Oven Expert? Answer questions, earn points and help others
