Question about Watches
I am looking for a users guide for a Krohn A300 Fluxed Flame machine for a jeweler.
  • Dr_Memory
    Dr_Memory Aug 08, 2013
    I have one.
  • Dr_Memory
    I have one.
What battery number needed for this watch?
Take your watch to a jeweler who will open it, identify battery type, and perhaps install a replacement.
Feb 17, 2017 | Watches
Where can I get a new band in Baltimore City for my MDC74564W. Went to 2 elite jewelers in the area no one can replace watch band
You'll probably have to go back whee you bought your watch or at least find the company website and look under user support.
Apr 09, 2015 | Watches
User manual for Jaguar J657
I will send you the right manual within few days.
Jun 26, 2013 | Festina Watches
Looking for battery for Timex Electric Watch,3la where can I get the proper one.
Believe it or not, Wal-Mart usually has a decent supply of replacement batteries for Timex. Give them a try.
Aug 29, 2010 | Timex 27191 Wristwatch
I have a continental 17 jewels watch and it looks
mcdevito75 here, You can try online at Continental watch.com However the numbers on the movement itself count the most, numbers on the watch face and back cover help. HINT!! -- If your Continental Watch has thick hands It"s most likely before 1965, if your watch has thin hands it"s most likely after 1965. Best bet, look for a small watch repair shop in your area, they can guide you too a shop that will know if they don"t. Also, you can check with any Antique shops in your area too.
Jul 03, 2010 | Watches
How to set time and data
Go to the columbia website and contact customer service for a manual. It is also possible that you can simply "google" for a manual or users guide for the model of watch. Similar columbia watch models will probably work the same way. In fact, it's unlikely they make their own, so it is probably a Casio watch or similar. Any jeweller who replaces batteries should also be able to help.
Nov 25, 2009 | Columbia All Sport Digi Watch l
Battery was replaced by a jeweler. Since that
As the jeweller is not a watchmaker, he/she even did not realise the watch is not working properly. It sounds like your watch is having jammed gear train or the jeweller did not know how to reset the watch. Go to this website: www.tissot.ch
If you will not find solution there, you will have to look for watchmakers help.
Rate me, please.
Jul 29, 2009 | Tissot Prc100 T22268631 Watch
My big tic display is dim
This sort of watch is usually best taken to bits by a jeweller - they have all the tools to take the backs off etc. without scratches. When lighting effects start to go bad, the battery is usually only to blame if the problem gets steadily worse. otherwise the suspect item is the light itself, probably an LED, or the circuit that is passing power to the light - the controller. It is still almost certainly worth trying to get the battery changed, that will solve most problems with a watch, so maybe you get lucky without spending too much. Hope this helps - please post again if not - also if you need us to find a jeweller near you post with your general area. :)
Feb 18, 2007 | Fossil Degrade Flame Animation JR8215...
Watches Logo
131 people viewed this question
Top Watches Experts
Jimmy Accardi
Are you a Watch Expert? Answer questions, earn points and help others
