Question about HP LaserJet 2840 Printer
How to change baud rate on a hp 2840 all-in-one
SOURCE: How do I change baud rate to 9600 on Epson CX9400Fax?
This fax speed is 33.6 or 33600
You can change settings to 14.4 or 14400 but not to 9.6 or 9600.
Under: Fax Settings you have this choices:
Speed Dial Setup
Scan and print setup
Communication
Header and time
Under Communication:
DRD
ECM - error correction put this one: off
V.34 - this one is for speed: on - 34400; off - 14400
Posted on Aug 19, 2008
ctf1800
  • 4402 Answers
SOURCE: sending fax
changing these settings:
ECM-error correction 'off'
V.34 'off'
Silence Detection 'on'
Posted on Jan 10, 2008
  • 24 Answers
SOURCE: change baud rate
Baud Rate is to lower the transmission speed of the fax, however these are the temp settings and once the power is off you have to reconfigure that. Follow the following steps :
From the front panel:
  1. Press and hold the * key for 3 to 5 seconds until the display screen reads Test -001+ .
  2. Enter in 620 on the key board, and press the Check Mark and the screen will read Cfg param id:
    1. Enter the parameter ____ on the key board and press the Check Mark.
    1. 159 - Receiving Fax baud rate
    • 153 - Transmitting Fax baud rate
    1. The screen will read Cfg param val: 26
    1. Enter in the value ____ and then press the Check Mark .
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    1. Screen will read Test -001+
    2. Press the Reset button until you get back to Ready
    Posted on Jan 22, 2008
    • 44 Answers
    SOURCE: Need to change Baude rate of HP 4215 all-in-one mechine
    That might help. Faxing is signal timing specific. I believe they are sent from the factory to run at "fast" which is 33.6kbps. Try to set it to medium first (14.4) if no luck set to Slow (9.6). Try these steps:
    1. Press Setup .
    2. Select Advanced Fax Setup .
    3. Press OK .
    4. Select Fax Speed .
    5. Press OK .
    6. Select Medium .
    7. Press OK .
    Posted on Nov 13, 2008
    laxmankumar
    • 191 Answers
    SOURCE: baud rate
    Please follow the steps given below to reduce the baud rate on your printer.
    1. Turn on the HP all-in-one.
    2. From the keypad, press * and # keys simultaneously.
    3. Press 1, press 2, and then press 3. Service followed by a number will be displayed on the front panel.
    4. Press the right-arrow to select System Configuration.
    5. Press Enter on the front panel.
    6. Press the right-arrow to select R/W Parameter.
    7. Press Enter. Parameter 0 will be displayed on the front panel.
    8. Press 1, press 5,press 1 (i.e,151) and then press Enter. The display should read Value followed by a number (example, Value 60).
    9. Press 2, press 6, and then press Enter. This will display Parameter 0 on the display.
    10. Press 1, press 5,press 3 (i.e,153) and then press Enter. The display should read Value followed by a number (example, Value 60).
    11. Press 0, and then press Enter. This will display
    12. Press Cancel repeatedly, until the display reads the date and time.
    Posted on May 23, 2009
    How do I access system settings to change the baud rate and turn off ECM.Thanks in advance.
    Fax settings for VoIP ' How to lower the Baud Rate ' Faxing ...
    www.voipmechanic.com/voip-fax-settings-9600-baud.htm
    How to Lower the BAUD rate to 9600 on fax machines for better VoIP faxing success.
    Faxing over VoIP, the correct configuration settings that you ...
    www.voipmechanic.com/faxingissuesandotherdevices.htm
    How to fax over VoIP and the settings and configurations, like BAUD rate that you need to set.
    Dell VoIP Fax Settings, how to lower the BAUD rate and ...
    www.voipmechanic.com/voip-fax-settings-dell.htm
    VoIP Fax settings for Dell printer/fax machines/multi-purpose machines.Missing: kyocera
    Faxing over VoIP - Sfax
    Dec 15, 2015 | Kyocera FS-1128MFP FS-1128MFP...
    How i change the baud rate
    why would you want to change the Baud rate? you don't need to do that.. Ive worked on faxes for over 30 years and never once have I changed a baud rate.. leave it alone..
    May 02, 2014 | Samsung SF-560 Plain Paper Laser Fax
    Baud rate hp 9600
    why need to change baud rate, no need to change???
    because it is not a serial port printing it is usb port printing....?
    Oct 01, 2013 | HEWLETT-PACKARD LaserJet M1522nf...
    Baud rate hp 9600 for HP M1522
    you are using serial port printing...or usb port printing
    if you using usb port printing no need to change the buad rate...????
    How can I change the baud rate on my HP Laserjet 3380?
    There is no baud rate to this printer, it's either parallel cable or USB cable. Baud rate refers to the old serial cable connections, com1 or com2. You can add memory to this printer to make it print more documents faster. Try this location:
    http://reviews.cnet.com/multifunction-devices/hp-laserjet-3380-all/4505-3181_7-30822993.html
    May 11, 2010 | HP LaserJet 3380 All-In-One Printer
    How do I change the baud rate to 9600 on an HP Laserjet All in one 3015
    The baud rate is usually determined by the receiving machine. When one fax contacts another, they negotiate their send/receive rates. That's an automatic function and not generally adjustable on modern faxes.
    Nov 26, 2009 | Office Equipment & Supplies
    Baud rate
    it's in the printer settings menu
    May 15, 2008 | HP PSC 950 All-In-One InkJet Printer
    Change baud rate
    1. 0 = V.17 14400
    • 2 = V.17 9600
    • 6 = V.29 9600
    • 10 = V.27 2400
    Dec 13, 2007 | HP OfficeJet D135 All-In-One InkJet...
    Sending fax
    V.34 'off'
    Oct 22, 2007 | HP LaserJet 3050 All-In-One Printer
    HP LaserJet 2840 Printer Logo
    170 people viewed this question
    Seeker5211
    Seeker5211
