Question about Ovens
When pluged in mirco wave would work for a short time making a clicking sound and then it would stop . it did this several times befor just quiting all together from that point i un pluged the unit
    Champion:
  • 202 Answers
Good idea Not worth fixing could burn down your hse. get a new one they r cheap nowdays
Posted on Mar 18, 2011
I have reset the clock the oven sounds as though it's working for just 2 seconds and then stops. The light will not come on at all. I have cleaned all contact points still no luck .
inverter failure blows safety fuse internally this will power down the oven to prevent further damage new inverter and fuse needed.
Feb 03, 2017 | Neff Ovens
Siemens HB86E560B/01 microwave oven.oven working ok.when selecting wattage for microwave it cutts out after approx.30 secs. higher the wattage selection the sooner it cutts off. is there an overload heat...
Please have your power rating checked on the outlet and also if possible measure the mains voltage on the outlet . If low this can trip the microwave as it runs short of current/voltage.
Also make sure the plug is tight on the socket. Choose a lower wattage and see if the microwave works a longer time. If so the microwave must be checked within for a faulty capacitor, magnetron , wave guide or transformer.
Clean the oven , check the connections within and try once again before we can infer.
Aug 19, 2011 | Ovens
The electronic controls click out with in just a few minutes after starting the oven. The light does not go on and nothing works. This problem started within one week of install and use and have had the...
Unfortunately this seems to be a problem with several of the jenn air models. I have replaced quite a few and have also talked to thier tech line for servicers and they don't have anything else to offer other than replacing the control board. Each time I ran across one I found no other problems and I tested everything. If you replace 3 times you can usually get them to give you a new one.
www.appliancehelponline.com
Mar 18, 2010 | Jenn-Air JGW8130DD Gas Single Oven
F7 Error code while cleaning stovetop
Usually a stuck keypad. Try pushing all buttons at random several times each including cancel. If that does not correct it this time you will need a new touchpad and ERC.
May 03, 2009 | Ovens
We have a 5 burner GE Profile oventop. The clicking from the electric starter doesn't stop unless we unplug the unit. Any suggestions on how to get the clicking to stop?
You have a short in one of the contacts on one of the controls.  Remove the cover to the cooktop.  Visually inspect.  If necessary, disconnect the wires from the controls one at a time....they're all in parallel until you stop the symptom.  Be careful around the wiring...turn off power before touching any uninsulated wires.
Dec 04, 2008 | Ovens
GE JKP45 double wall oven shuts off
This sounds like a loose connection (solder joint) on the main control board. I had one that had a similar problem. checked the price of a control board $350. I took the control panel off, took the board apart and found a loose connection on one of the relays. resoldered the bad connection. oven works fine now.
Nov 07, 2008 | GE JKP45 Electric Double Oven
GE Advantium Microwave oven SCB2000CBB 03 LZ90Z940K
Sounds like the door monitor switch, which would take out the internal ceramic fuse. I'd replace those two plus the primary and secondary door safety interlock switches.
Sep 19, 2008 | Ovens
Starter
Sounds like one of the control knobs got stuck or shorted in the start cycle. Can you get access to the inside where you can see each of the control knobs? Look for wiring and unplug one at a time. This may help you figure which one is shorted.
Mar 21, 2008 | GE JGRP17 Gas Single Oven
Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Jan 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
