Question about Magellan RoadMate 1440 Car GPS Receiver
I have a magellan gps model 1440, yesterday it started acting up. now it wont power up at all, it's only 2 years old. how do i power it up
    Sniper:
  • 54 Answers
Plug in a in car charger, it will automatically boot up
Posted on Mar 18, 2011
My gps just shut down, yesterday it kept trying to powering up but it never did, sometimes it tired to, now it wont do anything, its only 2 years old.
hi it would be possible that your battery has given up its last legs i suggest you replace the battery firstly and reset the unit then calibrate i hope this helps it would also be wise to update your maps gooodluck with it
Mar 18, 2011 | Magellan RoadMate 1440 Car GPS Receiver
Magellan 3000T, approxiamtely 2 years old. Last week, left home and it died on the road, it wont turn on even when powered by external power. The charge light shows it is charging. but it never...
hi djmercer1
the following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Nov 24, 2010 | Magellan RoadMate 3000T GPS Receiver
Reset button for a magellan roadmate 1440
Hi allen,
Magellan RoadMate models 1340, 1440, and 1470 are normally reset as follows:
The reset button is located on the right side of the unit. Press a blunt object like a long-shaft ballpoint pen or a cut off toothpick
into the small hole and hold for approximately 15 seconds. The unit should do a fresh reboot. Sometimes these GPS units can be reset by holding the Power button down for 10-15 seconds to completely shut the unit down. Then, do the same procedure for 10-15 seconds again, to power it back on.
Also, here's another procedure you really only try as a last resort, if the unit is on, but acting up with various menus and functions. Use this very carefully...
While on the main Menu Bar at "System Settings", tap the left corner twice, right corner twice, left corner once, and finally, right corner once. You will see a 'Hidden' menu with a "Reset for first use". Press that option and the unit will perform a hard reset. Hopefully, you can continue all you setups from this point.
Also you can download a complete manual from this link:
http://www.magellangps.com/assets/manuals/Magellan_RoadMate_1440_EN.pdf
The manual won't tell you all these little tricks, so it might be a good idea to make a hard copy of these notes (in case you ever need them again...lol). I hope this helps. Please let me know how it turns out, and contact me if you need further help.
Regards, Bill
Sep 17, 2010 | Magellan RoadMate 1440 Car GPS Receiver
Magellan Roadmate 1440 certainly dead and won't power on. Any advice?
Hi onestrategy,
These are tips I have used and given others about this series Magellan units. Make sure you have external power hooked up for best results.
Regards, Bill
Magellan GPS does not go on at all
the folowing advice pertains to the following magellan gps systems.
assuming your car charger is working (the little green light is on) and your Magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
bill
Jun 03, 2010 | Magellan Maestro 4000 GPS
How do I register and charge my Magellan GPS
In order to "register" your Mag_1440 (or any other Magellan), you need to create an account on the Magellan_GPS Web-Site. You will basically supply your name, address, tel_number, e_mail, and the model and serial_number of your GPS... Once you have created your account and registered you GPS, you may be prompted with Links for software and/or map updates... As far as "charging" the 1440/1470, you only need to plug the GPS_Unit into the Car/Auto_Cigarette outlet via the 12v power cord that came supplied in your package... One can also use any standard 120v (AC) to Mini_USB charger (i.e Motorola Razr Cell-Phone AC_Power-Pack) to charge up the GPS unit...Unfortunately, the Computer_USB to Mini_USB cable (in the box) supposedly will NOT power/charge up the GPS... This Mini_USB cable is used to download the latest firmware (v2-20) onto the GPS (approx. 75_MB)... Therefore, before you attempt to download the latest firmware onto the 1440/1445/1470, be sure that it has been sufficiently charged via the Car_Adpater, or an auxilliary AC-Power Adpater... Hope this helps...
Jan 28, 2010 | Magellan RoadMate 1440 Car GPS Receiver
My magellan roadmate 1440 will not turn on? Is
get a new one.. no way to fix unless u get a new battery
Dec 18, 2009 | Magellan RoadMate 1440 Car GPS Receiver
Magellan roadmate 300 wont stay on
It is the cigarette adapter, mine was doing the same thing until I bought a new adapter. When the old adapter plug to the GPS unit moved at all it would lose power.
Jan 13, 2008 | Magellan RoadMate 300 GPS Receiver
Magellan RoadMate 1440 Car GPS Receiver Logo
221 people viewed this question
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
