How do i clear error codes on a ricoh aficio 3025 copier.?
  • trent montgomery Mar 18, 2011
    how to clear error codes on a ricoh aficio 3025
  • 17,970 Answers
Appreantly Ricoh error codes are not something you can come by easily.
For example, the machine has the ability to trip an alarm when the temperature gets too high and will not continue to work untill the error is cleared out. With oput specific code and knoweled of how to do this, you will need to contact Ricoh to either send somone down to fix the issue or ask them to tell you how to fix it on your own.
Hope this helps
Posted on Mar 18, 2011
  • 4,338 Answers
What error code is it?
in the mean time try :
  • Press and hold online + escape, then power on.
  • Use up and down arrow keys to select SP2
  • Press Enter
  • Use up and down arror to locate SP5
  • Press Enter
  • Use up and down arrow keys to select 810
  • Press Enter
  • Confirm the selection
  • Power off and on.
No loading toner my ricoh aficio 3025
you need to replce the PCU - unit order code is
  • B205-0153
  • that depends on the counter number.
  • or the cap from the other toner is still inside the the toner holder.
  • check the old toner bottle does have a cap on it.
  • how ever for i need the print counter to see if the PCU is for replacement.
  • write the print counter, and see do the old toner bottle have ca p on it or is just a open hole.
  • please write some additional info.
  • Best Reagrds
Oct 16, 2016 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh aficio 3025
Go get the firmware from the ricoh site. Get the rfu file if you are doing it remotely eg. from your laptop or PC. Just make sure nobody is using the printer while you are doing it.
Jul 16, 2014 | Ricoh Aficio 3025 All-In-One Laser Printer
RICOH AFICIO 3025 CODIGO DE ERROR SC 302
High voltage electrical problem:
Charge corona output error - grid voltage error - charge roller current leak.
Not likely to be a diy job.
Apr 06, 2014 | Ricoh Aficio 3025P Black and White Copier
Error code sc 650
Ricoh AF 3025 error code SC650 is wat problem?
Jan 03, 2012 | Ricoh Aficio 3025 All-In-One Laser Printer
Como quitar el error sc 819 de una ricoh 3025
• Software application error
• RAM shortage
• HDD error (hard disk drive )
Apr 06, 2011 | Ricoh Aficio 3025SP Copier
What is error code sc542
I found some information on this error at http://www.fortc.com/2007/06/17/ricoh-cl4000dn-error-code-sc542/
According to this website, the error code is due to a fuser temperature problem.
The Fix
In order to clear error SC542 follow these steps:
- Press and hold online + escape, then power on.
- Use up and down arrow keys to select SP2
- Press Enter
- Use up and down arror to locate SP5
- Press Enter
- Use up and down arrow keys to select 810
- Press Enter
- Confirm the selection
- Power off and on.
Kindly rate this solution, thanks!
Mar 08, 2011 | Ricoh Aficio 3025 All-In-One Laser Printer
How to replace thermistor on Ricoh Aficio 3025?
Take the fuser covers off. The thermistors (I think there is 2 in this model) have red connectors. One screw for each.Check them first and see if they just have a build up of toner.
****You must have the correct ones for each Ricoh model ****
Feb 01, 2010 | Ricoh Aficio 3025 All-In-One Laser Printer
I have a ricoh Aficio 3025 all in one, it is now giving me a fault code of SC543 please advise
its temp. or fixing error. try to clear it in service mode.
yellow 197 red when it says SERVICE MODE turn off and on machine, if it does not help you need to call service to replace thermistor, or lamp, or rise temp. ,or ...
Nov 12, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Ricoh Aficio 3025. The first tray is stuck halfway out, it looks like something came loose please help me!
you have to check the paper feed clucth or the tegestration clucth or you have to chean the paper feed roller
Jun 16, 2009 | Ricoh Aficio 3025 All-In-One Laser Printer
Does not print from Mac OX 10.5 Leopard
from a mac, you need to have a post script print option installed, the system only came with pcl
http://www.websitetoolbox.com/mb/copierquestions
Apr 04, 2008 | Ricoh Aficio 3025 All-In-One Laser Printer
78 people viewed this question
k24674
jasbo
jasbo
