Question about Abit IN9 32X-MAX Motherboard
My pc is not showing anything on screen whereas everything is running inside cpu
  • 961 Answers
Http://www.nvidia.com/Download/index.aspx?lang=en-us
http://www.abit.com.tw/page/en/download/download_driver.php?pFUN_KEY=9000&pTITLE_IMG=/download/images/download.gif
Thefirst link is Nvdia"s link for driver downloads. The second is Abit's. In nvdia's link I put in you info but you will have to enter what driver(software) and your operating system. Keep in mind that you wil have to uninstall ant prior software related to this board before installing new.
Will the system start in safe mode? If so go to "device manager" through "control panel' and click on box next to "dispaly adaptors" your Nvdia driver should show in the drop down. Right click on that and you should see "enable" or "disable" if you see enable, click n that and you should be set
If you have made any recent changes, ie; cables to monitor, you may ahve to hook system back upthe way it was and do a "system restore back to when it did work.
Posted on Mar 18, 2011
How do i fix the black screen of ***** on my windows vista?
The problem is not the fix, the problem is finding out which problem of many possibilities is causing the the black screen.
This requires some troubleshooting.
I assume you are using a PC.
The first step is to turn on the monitor first.
Make sure the power on indicator LED on the monitor comes on.
Then boot the PC. Make sure the CPU fan comes on inside the PC.
(If you are running a laptop and the screen is always black, it is usually the flexible cable joining the screen to the main body has broken. A hardware problem)
Does anything show up on the screen?
If no, check the CPU cooler inside the PC.
If it is plugged up with dust and lint, you may have a burned out CPU that will have to be replaced. (A lack of cooling air causes the CPU to overheat and fail when the safety does not work. A common problem.)
If yes, get a Linux boot CDROM/DVD, boot on the Linux CDROM/DVD, and follow the instructions to run CLAM antivirus under Linux.
When the screen goes black during boot, and stays black, the problem is usually a "Root Kit" virus.
You can not remove these viruses with a normal Windows antivirus program. They are too deeply embedded in the system.
This is the start of the troubleshooting procedure.
You really need somebody "on-site" to troubleshoot a problem that is this complex.
Jan 24, 2016 | Microsoft Windows Vista Ultimate Edition
Cpu temperature error
Turn off PC, Unplug PC from power. Open PC case. Examine all fans including CPU fan and heatsink. clean the fans and heatsink. With case open but everything inside connected properly, Plug pc back in. Power up the PC and check that all fans are running. If not replace fan that is not running. Place PC in a well ventilated area when operating. I use a new small paintbrush for cleaning dust from inside of PC.
Sep 25, 2013 | ASUS Essentio Desktop with Intel Pentium...
This evening when i started my notebook it showing there is no sound device installed whereas everything was up n running perfectly yesterday
Hi there
did you do any updates or install anything new today as sometimes updates can do silly things at times
you could try a system restore that might fix the prob or go to either www.realtek.com and download a audio driver or go to www.sonysupport.com and look for a audio driver
Dec 09, 2010 | Sony VAIO Notebook
Installed new equipment, now monitor is blank
just dump everything and buy a branded new PC....
u will be increasing ur BP....it;s not worth this much effort....
the kind of work u have done...it seems ur an expert so u urself work it out what's wrong...and where did u make a mistake...
i guess ur CPU and MB are not getting along....some issue with ur integration.....of all parts....
Dec 18, 2009 | Computers & Internet
Have emachines T6528 graphics problem
if it doesn't boot at all .( this is the reason that you see that message on the screen it means that no video signal came out from the computer ) ..try to change the cable that leads from the pc to the monitor first ...and if the problem its still on ...it have to be something related with the Ram memory or the CPU ....cause these 2 are the only things that can make a system to do not boot at all ...if any other device will not work ..the pc will still boot to bios ..or will still show the devices it finds on start ...even if is not able to succeed with the operating system boot...
so ...either it boots and you can not see anything cause the cable its damaged...( very possible cause this is the case it shows that message ...when the cable its shorted ..or unplugged ) or it doesn't starts at all cause of the memory or CPU ...
Sep 08, 2009 | E-Machines T6528 PC Desktop
Hooked up a monitor and im not getting any picture. i just purchased the computer second hand today. i tried a second working monitor and still no pic. any ideas?..
Assuming that your monitors are good, if nothing is shown on the monitor, that means it does not receive any signal from the computer (or CPU). When you bought it, did they show you the computer and monitor are in good working condition (that means Windows desk top screen comes up on the monitor if it is a PC). If everything was OK when they showed you, but when you took it home, it does not any more, then maybe something became loose while transportation.
Make sure that when you turn the computer on, you hear the fan on the power supply and inside the computer running, and there should be some lights in front of the computer . If you do not hear anything nor see any lights in front of the computer then that is the reason nothing comes up on monitor. If it is the case, you may want to remove the cover of the computer and physically inspect inside the computer to see if anything becomes loose while transportation.
Just some ideas for you to work on. Good luck!
Aug 18, 2009 | Fujitsu Siemens SCENIC E600 Green PC...
When i press the power button it makes noise and the screen does not show anything
NOise coming from?? Screen do not show anything is Possible problem of LCD, LCD BULB, INVERTER, CPU, MEMORY, OR GRAPHIC CARD. Issue. Try external for make sure if you get picture Your GRAPHIC CARD, MEMORY, CPU is fine.
If sound is coming from FAN system, That is need to be clean(or Change), Or HDD makes sound that is Coming to DUE.
JMC
Aug 15, 2009 | Acer TravelMate 2355 Notebook
Motherboard boot up problem
Try clearing the cmos bios on the board there is a jumper on it
Jan 02, 2009 | EliteGroup ECS G31T-M Motherboard - Quad...
Abit IN9 32X-MAX Motherboard Logo
176 people viewed this question
Top Abit Computers & Internet Experts
Matthew Spark
Matthew Spark
David
David
Jerry Umali
Are you an Abit Computer and Internet Expert? Answer questions, earn points and help others
