I have a bosch WVT1260GB washing machine which when the program starts it washes and washes and never gets to a rinse cycle, it just keeps washing and washing
Bosch wvt1260 control panal wiring diagram
Posted on Mar 21, 2011
    Brigadier General:
  • 6,277 Answers
(Try these guidance notes)
Sorry but I do not know your particular machine BUT I would suggest as a first step that you clean the drain motor lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not go to spin or release the door lock if there is water still left inside.
Here are my complete and general pre-typed (!) guidance notes for checking both the drain filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!) and most are held in by a round cover/knob.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT!
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. If it doesn't work then the motor is malfunctioning!
Hope the filter is the problem and good luck!
John C
Posted on Mar 18, 2011
Why does my Bosch Classixx 1200 Washing Machine rinse if I turn switch to rinse but will not rinse when automatically.
Are you on a delicates program that has no spin or is there a no spin button that has been pressed?
Check the manual to see what programs do what. You can usually find a manual on line if you have lost yours.
Dec 13, 2014 | Bosch Washing Machines
Bosch dishwasher gets stuck at 1 minute
New and highly targeted viral marketing campaigns can instantly place your product, service or brand in front of potential customers. See the best examples of viral marketing videos and social media strategies. Viral Marketing Company Plan Strategies and Resources Viral Shot
Mar 11, 2014 | Bosch 24 in. SGS43C12 Classixx...
Wash doesn't progress to rinse and spin
This is one of 3 faults
1 you may have a problem with the heating cycle check element
2 you might have a water valve not working
3 there may be a program fault
These videos on how to change an element and water valve will help
Jul 22, 2013 | Bosch Classixx WFL 2066 Front Load Washer
My Bosch maxx6 takes very long on wash cycle
Possibly heater fault....if you set unit to, for example, a 40 degree wash, the machine will just keep washing unit it reaches selected temp, then drain and do the rinses. If the heater is open circuit then it will wash and wash and wash until the module times out because it is not getting there and continue to rinses, making the programs excessively long. (You may also find, if it has a display that it sit at 0.01 for a long time at the end of the cycle. Not sure of your model as you have not posted it, but if you go through the test below you can test the heater.
1. Put main dial to off
2. Press and hold start button whilst turning dial one click to left (easycare 30).
3. When display show 8.88 or two of the progress light come on, release the start button
4. Turn dial anticlockwise to 90 cotton (take the long way, NOT thru OFF or you'll have to start over)
5. Press start
The tub will fill a little and if the heater is ok, after a few minutes you will hear it 'kettling', the drum does not turn during this test.
If you have a meter that checks amp draw, if the heater is ok it should read around 9 amps.
Hope this helps
Mar 23, 2013 | Bosch Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
2007 Bosch Washer WFMC 3301
It may be possible that you are using too much soap. There is a turbidity sensor that checks for soap in the water. It will keep rinsing until it thinks the soap is gone. You did not state if you are ever able to complete an entire cycle or not. If the cycle never completes, it is possibly a problem with the main circuit board. Have you allowed the machine to complete a cycle?
May 18, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Washing Machines Logo
261 people viewed this question
Top Washing Machines Experts
