Question about Whirlpool Duet GHW9150P Front Load Washer
Barrel is not turning and it's making a clicking sound
  • 4,323 Answers
Hi
The issue seems to be with either the belt going bad or the pulley is bad and should be replaced. Hope this helps...please post back for further assistance.
Daniel
Posted on Mar 18, 2011
Changed ignition barrel on suzuki ignis 01 now.it will only start by bumping it once started there is no warning lights on and it drive fine you try start with key it clicks or does nothing
Why did you change the ignition cylinder? Sounds as if the ignition switch is not working properly. This switch is usually attached to the back side of the ignition cylinder and the barrel portion of the cylinder turns the switch. You can remove the switch from the cylinder and insert a screwdriver into the switch and turn it manually. If nothing happens when the switch is turned, it could be defective
Dec 18, 2015 | Suzuki Cars & Trucks
Lens error restart camera
  • 1. Begin by turning the power on and off 4 times. If this does not work, remove the battery with the power still on, wait about 15 seconds and replace the battery. Once you have installed the battery, turn the power on. You can plug the audio/visual cable into the camera preventing the LCD screen from powering up. This will allow for more power to be directed to extending or retracting the lens.
  • 2. Try using compressed air to clean around the lens barrel area, this may dislodge the debris that is preventing the lens from extending or retracting.
  • 3. Gently tap on the bottom of the camera while holding the camera with the lens facing the ground. Try using the palm of your hand or the rubber pad on the USB compartment. You want to dislodge any dirt or debris that is lodged within the camera.
  • 4. With the power OFF, place the camera flat on the table with the lens facing the ceiling. While holding the shutter button down turn on the power, this will cause the lens to auto focus hopefully seating the lens barrel guide pins.
NOTE: The next step is the most forceful procedure, therefore use extreme caution when performing. Remember, if a click is heard during this step then stop and check to see if the lens error has been resolved. Clicking sounds may indicate that the lens barrel guide pins have reset.
  • 5. While turning the power on GENTLY twist, pull or push the barrel while the lens is extending or retracting. You want the barrel to move in or out evenly. The idea behind this step is to overcome the friction that is caused by misalignments or dirt within the barrel.
Jun 20, 2012 | Canon PowerShot SD850 IS Digital Camera
The barrel is not turning in the dryer when on. It continues to get and run but the barrel is not turning in the inside?
sounds like the drive belt has come off. If it still makes humming noise the motor is probably fine and you either need to open it up and reattach the belt or order a new one if its to loose or snapped.
May 04, 2011 | Whirlpool Dryers
The barrel makes a rubbing squeeking sound as it turns. Sometimes it is really loud and other times it doesn't make the noise.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Asker's Testimonial " This should give me an ida of what to look for once I open er up
May 20, 2010 | Dryers
My camera wont turn on.
If the lens is stuck inside the camera and you hear a motor noise - changing batteries will not help. This has happened because the lens barrel is jammed inside the camera. Unfortunately, you will not be able to repair that issue. If the lens is stuck outside the camera, slightly tilted, and you hear a motor noise; you might be able to save camera. First, only use good batteries (stay away from alkaline batteries - waste of money), go with Energizer Lithium or Duracell Power Pix (you will get your moneys worth and have less problems with the camera). Second, very GENTLY, pull the lens barrel up and in the opposite direction of the tilt (to make the lens barrel straight), you will hear a slight click sound - DO NOT PUSH ON THE LENS BARREL!!!. Put in the new batteries and the lens should retract.
Oct 06, 2009 | Polaroid i733LP Digital Camera
Zoom lens will not retract.. Canon Power Shot S21S
the block is damaged ...see if the lens barrels are a little bent or something....
Mar 06, 2009 | Canon PowerShot A75 Digital Camera
1991 XJ6 ignition barrel replacement
Remove the steering column panels and turn the key to position 1, there is a hole that is on the steering lock assembly that you need to use a pick or similar rool to puch in the hole and release the spring tension, then the barrel slides right out and make sure you put the new barrel to position 1 and it will slide right in and "click" in place. Put the panels back on and your set to go.
JPTCAT
Oct 02, 2008 | 1991 Jaguar XJ6
Makes 3 beeping sounds then turns off
what happen if you put another memory card in it?
Dec 02, 2007 | Polaroid I533P Digital Camera
Whirlpool Duet GHW9150P Front Load Washer Logo
14 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
