Question about Frigidaire GLEF379D Electric Kitchen Range
I have a frigidaire electric range model #glef379dcd and it shows a F30 warning How to I change the sensor and is this the problem?
4 Suggested Answers
  • 1073 Answers
SOURCE: frigidaire electric ceramic stove
replace oven control
Posted on Apr 16, 2008
  • 116 Answers
SOURCE: Frigidaire Electric Range error code
Hi jacksmdmat,
Your f30 problem may be a bad sensor circuit. It may have an open connection or just plain defective sensor. Check the connection between the clock and the sensor as well as disconnect and measure the resistance of the sensor - should be about 1090ohms at room temp (75F)
Posted on Sep 04, 2008
  • 18 Answers
SOURCE: F30 error during cleaning cycle for Frigidaire
The problem seems related to the sensor switch. The immediate solution was such a simple fix, I couldn't believe it.
STEP one:
Turn power breaker OFF for the range. This is a step you shouldn't NEVER skip, or you could DIE.
STEP two:
Gently pull range out of the slide in area into the kitchen
STEP three:
Unscrew the metal back panel of the range.
STEP four:
Facing the back of the range, you should press the red button between two wire mounts until it clicks. Be careful, and try not to touch ANY wires when you do this.
STEP five:
Turn breaker back ON.
STEP five:
If you didn't unplug the stove, the oven should still be locked, but will unlock immediately when you hit the CLEAR/OFF button on the control panel on the fron of the range.
Keep in mind that this is only a TEMPORARY solution and would probably occur again the next time you clean the oven. Try replacing the sensor switch for a longer term solution. You can order one for less than $20. I will buy it from the website that includes the most comprehensive instructions for replacing the item for this range type. Any suggestions?
Posted on Jun 14, 2009
Frigidaire stove door locked f30 error code
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. Try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, contact a professional to move forward accurately
Nov 25, 2012 | Frigidaire FES367 Electric Kitchen Range
Cfef 372ec4 Frigidaire f 30 problem
Hi - Typically error code F30 for Frigidaire range indicates an issue with the sensor probe or the wiring harness between sensor probe and EOC. If you have already changed the sensor, I suggest checking the wiring or contacting a professional to move forward accurately. You can try resetting the unit and see if the error code will clear. You can either unplug the unit or flip the household circuit breaker off. Wait approximately ten minutes and turn on the range. If issue continues, once again contact a professional to properly diagnose the unit.
Oct 14, 2012 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
What does f30 mean on the read out
F30 = Open Probe Connection
1. (F30 or F31) Check resistance at room temperature & compare to *RTD Sensor resistance chart. If resistance does not match the RTD chart replace RTD Sensor Probe. Check Sensor wiring harness between EOC & Sensor Probe connector.
2. (F30 or F31) Check resistance at room temperature, if less than 500 ohms, replace *RTD Sensor Probe. Check for shorted Sensor Probe harness between EOC & Probe connector.
Hope helps.
Apr 25, 2011 | Frigidaire 30" Self-Cleaning Freestanding...
Error code F30 on a frigidaire ples389ecc oven.
THAT CODES MEANS EITHER THE PROBE SENSOR OR THE ELECTRONIC CONTROL IS BAD. UNPLUG. WITH WIRING DIAGRAM AND OHM METER, TEST THE TWO WIRES GOING TO PROBE. IF YOU GET ABOUT 1100 OHMS, YOU HAVE A BAD CONTROL. IF YOU GET 0 OR INFINITY, IT'S THE SENSOR OR THE WIRES BETWEEN THE PROBE AND THE CONTROL
BOYNISMO@YAHOO.COM OR 714-334-1998. I CAN WALK YOU THROUGH IF NEEDED
Dec 26, 2009 | Frigidaire PLEF398AC Electric Kitchen...
What is F30 error?
Range made by Frigidaire, cannot pull up info right now for that F30 code, just the F3 which means something is wrong in the sensor circuit, sensor, wiring harness or the EOC/clock...what does your tech sheet tell us this F30 means??? What was the ohm reading on the old sensor.....if changing this did not solve the problem about down to checking the wiring harness, if it is ok back to the clock causing the problem if the F30 pertains to the sensor circuit failure....
Oct 14, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Our figidaire electronic stove/oven model PLES399ECD, serial number NF62311528, mfg'd 2/2006 has an error code for F30 when any program is selected. The manual does not list F30, what is F30?
Open (F30) or shorted (F31) RTD sensor
probe/ wiring problem. Note: EOC may
initially display an "F10", thinking a
runaway condition exists.
1- Press Cancel key.
2- Check wiring in probe circuit for possible short or open
condition. Check RTD resistance at room temperature
(compare to probe resistance chart). If resistance does not
match the chart, replace the RTD sensor probe. Let the oven
cool down and restart the function.
3- If the problem persists replace the relay board.
Sep 25, 2009 | Frigidaire PLEF398AC Electric Kitchen...
Kenmore Elite made by Frigidaire 30" slide in electric range model # 790.46603501 shows F30 ERR. Oven will not work. Range top is fine. Help!!! Turkey to cook!! Lynne
The F30 error code indicates that the electronic oven control board detects an "open" oven temperature sensor probe circuit.
This is usually caused by a failed oven temperature sensor probe.
Replacing this component will likely fix your problem.
You can order this part from www.searspartsdirect.com website.
If you replace this part yourself, be sure that you unplug the range to disconnect electrical power before accessing this component.
On some models, you can replace the probe by removing the screws that mount this component to the inside back wall of the oven.
Carefully pull the probe inside the oven cavity until you encounter the wire harness disconnect plug.
Unplug the sensor and replace it with the new one. Mount the new probe on the back wall of the oven.
On some models, you have to remove the lower back oven panel to access the sensor probe.
If you replace the probe and still have this problem, you will need to unplug the range and measure the resistance through the violet wires that plug into the control board (this is where the sensor probe circuit is connected to the control board).
If the resistance through the oven temperature sensor probe circuit is normal (about 1100 ohms at room temperature) then the electronic oven control board will need to be replaced.
http://media.fotki.com/1_p,wbwdqtgkkqdrrfgxgtqsskgwtqkq,vi/ktrrwffdrxkddstsrtq/1/1303472/5961857/image45310img-or.jpg
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Nov 26, 2008 | Frigidaire FEB27S6DC / FEB27S7DC Electric...
Hi jacksmdmat,
Jul 16, 2008 | Frigidaire PLEF398AC Electric Kitchen...
Frigidaire stove door looked
temp was too high or the sensor smoked. this happens, self clean wreaks havoc with the electronics on this stuff. need your model to tell you what the error code means
May 10, 2008 | Frigidaire FES367 Electric Kitchen Range
Frigidaire GLEF379D Electric Kitchen Range Logo
71 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
