Question about Shure T2 / PG58 Professional Microphone
RF signal strength good, but audio zero. New battery. Mic head: green wires intact. Can get audio static touching wire to contacts 90 degrees from green wires.
    Prodigy:
    An expert who has answered 500 questions.
  • Shure Expert
  • 611 Answers
Contact the following for repair:
http://shure.custhelp.com/app/answers/detail/a_id/4053
Posted on Jul 27, 2014
5 Suggested Answers
SOURCE: Pure static w/ Phantom power on
me too, its driving me crazy
Posted on Jul 24, 2008
  • 611 Answers
SOURCE: all power on, signal is reading on receiver. No
Unfortunately, there are many things that can cause this symptom. I suggest calling Shure Applications at 800-516-2525. They can help you troubleshoot your wireless.
Posted on Jan 21, 2011
  • 611 Answers
SOURCE: New Shure PG4. RF and audio fm mic OK to PG4 but
Sounds like a complicated issue. Many things could cause this symptom. Try calling Shure at 800-516-525 to see if they can help troubleshoot.
Posted on May 04, 2011
  • 611 Answers
SOURCE: Have Shure T2 Wireless transmitter - no audio - can fix?
There is a company in Chicago that can still repair old Shure wireless. Delta Audio 877-764-3634.
Posted on Nov 02, 2011
My amp is on but the subs don't work Kenwood amp
Ok. Simple test to check if your subs are blown. Hook up speaker wire and simply touch each wire to each end of a new aa battery. You should hear like a sizzling static sound from the sub and it should jump slightly if its good. If subs are good you may be having issues with the connection terminals or worse. And it could simply be the audio connection from the stereo or the audio wires need replaced. Possibly replace the stereo or amp. So many more options but this should get you headed in the right direction.
Sep 04, 2014 | Car Audio & Video
Pyle troubleshooting
You've obviously checked battery strength, battery connection and volume settings for the dead mic...does the green transmit (RF) LED light when you turn the mic on? Does the red audio (AF) LED light when you talk into the mic? Best solution....buy a better quality wireless system ($85 wireless?!? ...no thanks).
May 20, 2014 | Pyle PDWM2100 Microphone
The radio recieves great rf power works rodger beep works throws a good strong signal on other radios has a new mic but no modulation
Is this new mic wired for your radio? just because it fits the socket doesnt mean its right. Did the old mic do the same thing reason why you got the new one? just sounds more like a loose wire at the jack where the mic plugs in? has that connector ever been loose or needed tightened at any time?
Jan 03, 2013 | Galaxy Radios DX-44V 40-Channels Base CB...
The wiring harness. To the stereo has been cut. I need to install oem stereo and don't know where to start to find which wire hold the ground or power.
1998 Chevrolet Malibu Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: Orange
Car Radio Accessory Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black
Car Radio Illumination Wire: Gray
Car Stereo Dimmer Wire: Brown
Car Stereo Antenna Trigger Wire: Pink
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: 4? x 6?
Car Audio Front Speakers Location: Doors
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: 6? x 9?
Car Audio Rear Speakers Location: Rear Deck
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
Hope this helps (remember to rate this).
Nov 05, 2010 | 1998 Chevrolet Malibu
Radio harness is cut trying to install new radio need wire diagram
2003 Kia Spectra Car Stereo Wiring Color Codes
Car Radio Battery Constant 12v+ Wire: Pink
Car Radio Accessory Switched 12v+ Wire: Green
Car Radio Illumination Wire: Red/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Green
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): Yellow/White
Right Front Speaker Negative Wire (-): Yellow/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Black
Left Rear Speaker Negative Wire (-): Brown/Green
Right Rear Speaker Positive Wire (+): Light Green/Yellow
Right Rear Speaker Negative Wire (-): Ornage/Black
Jan 05, 2010 | 2003 Kia Spectra
I have a uniden 68xl with no audio. The audio chip is good. It has key and swing just no ears. What else could it be?
make sure the RF gain is on max.
If the meter is moving when receiving, but you don't hear it, it could be the mic. Try a different mic and see if it works. It could also be a broken wire to the mic jack.
If the meter doesn't swing when some one is transmitting to you and you don't hear them, there could be either something wrong in the receive section of the radio, a bad resistor in conjunction with the RF gain control, or it could just be a bad knob.
You can hot wire it to full to check it like this:
Look for the wires on the RF gain knob. Its 2 wires. Disconnect them form the knob and twist or solder them together. If you have receive after that its a bad knob.
You can replace it, or just solder the wires permenantly together and put some shrink tube on it and use it like that. You don't need RF gain any way.
Most of the time its on full any way. no need to turn it down.
Nov 18, 2009 | Radio Communications
Dropped the mic.
I would imagine the mic element broke. To test, remove from the case and without touching anything else, touch (using a small screwdriver if need be) the solder connections on the wires for the mic element (while system is up). Hum? Yes? bad mic element. No? Problem with electronics. Look for broken wires also.
The receiver shows signal so RF is ok. You have a problem with the audio section.
Apr 28, 2009 | Audio Players & Recorders
We have a Sennheiserew100 G2 mic kit with a wireless lav mic and transmitter we use for a canon xh-a1. The shotgun mic has been prefect but the lav mic is creating a static/noise in the background but then...
This is probably interference in the wireless connection for the lavalier mic.
Try switching channels to find a clear one!
Or switch to a wired lav mic if that's practical.
For audio expertise and PA system help with feedback and noise, try our new DVD "PA Systems for Small Groups" at www.whamuniversal.com
Apr 13, 2009 | Sennheiser 100/500 G2 Series Wireless...
Car audio
zeus_s007- This is a pretty technical,request so i hope you understand my instructions. I hope the harness plug is present,this makes it easier.First of all i'll give you the wire colors,there are a couple the same color and we will start there.
tan-left front speaker-positive
gray-left front speaker-negative
light green-right front speaker-pos.
dark green-right front sreaker-neg.
brown-left rear speaker-pos.
yellow-left rear speaker-neg.
dark blue-right rear speaker-pos.
light blue-right rear speaker-neg.
orange-12volt constant-memory
black-ground
yellow- 12volt key switched-may be bigger than yellow speaker wire-we can check the wires,will explain later.
gray - dash dimmer
brown-dash dimmer
You don't need the last 2 mentioned,any others left over not needed.
The safest way to check the 2 brown,grey,and yellow is to use a AA battery, as a speaker tester.You take the colored wires for the speakers and touch the AA battery to them. For example you know the 2blue ones are right rear wires-so take the AA battery and touch one blue to the one end of the AA battery and the other end to the other blue wire, you will hear static on that speaker.This will let you know the 2 proper wires for the speaker,no static -wrong wire.you only have to do this for the grey,brown,and yellow wires.Well I hope I don't confuse you,if your not sure,let me know.Good luck, happy wiring.
cooltek Mar,5/08
Mar 04, 2008 | Audio Players & Recorders
Shure T2 / PG58 Professional Microphone Logo
100 people viewed this question
Top Shure Audio Players & Recorders Experts
Ben Armstrong
Vito Vacirca Jr.
Jerry Greenberg
Jerry Greenberg
Are you a Shure Audio Player and Recorder Expert? Answer questions, earn points and help others
