Question about Google Gmail
I lost my gmail tool bar that allowed me to change colors, enlarge type, change to bold, etc
  • 43 Answers
At the bottom of the screen where it says 'Gmail View', make sure it is set to 'Standard' and not 'Basic HTML'. If it is, make sure you don't have any adblocking software or extensions running on the page.
If neither of those fix it, you might want to try clearing out your temp files and cache & re-logging in. Press Ctrl, Shift and Delete all at the same time and delete everything but your passwords and form data. You'll then have to re-log in and that should fix it...
Posted on Mar 18, 2011
I need to know how to take the fuse box under the hood of my 2005 Chevy Impala so I can put a new one in.
Underhood Electrical Center or Junction Block Replacement
Removal Procedure
  1. Disconnect the negative battery cable. Refer to Battery Negative Cable Disconnect/Connect Procedure in Engine Electrical.
  2. Click to Enlarge
  3. Disconnect the positive battery cables from the underhood fuse block terminals.
  4. Remove the tape from the wiring harness at the base of the underhood fuse block base.
  5. Click to Enlarge
  6. Release the underhood fuse block(s) clip retainers using a small flat-bladed tool.
  7. Click to Enlarge
  8. Remove the fuse block(s) and wiring harness lifting up from the base and reposition from the base.
  9. Click to Enlarge
  10. Remove the nuts from the underhood fuse block base.
  11. Remove the underhood fuse block base from the shock tower.
  12. Click to Enlarge
  13. Remove the underhood fuse block lower front terminal positive assurance retainers using a small flat-bladed tool.
  14. Click to Enlarge
  15. Remove the plastic shields from the battery cable and buss bar terminals, using a small flat-bladed tool to release the clip retainer.
  16. Click to Enlarge
  17. Remove the bolts from the buss bar jumper bar.
  18. Click to Enlarge
  19. Remove the buss bar jumper bar from the fuse block(s).
  20. Click to Enlarge
  21. Remove the fuses from the fuse block(s) to access the buss bar terminal release tabs.
  22. Click to Enlarge
  23. Remove the buss bar(s) from the fuse block(s) using a terminal releasing tool, and pulling down and out on the buss bar.
  24. Click to Enlarge
  25. Remove the buss bar(s) from the fuse block(s).
  26. Click to Enlarge
  27. Release the clip retainers from the underhood fuse block(s) battery cable and buss bar terminals using a small flat-bladed tool.
  28. Click to Enlarge
  29. Remove the underhood fuse block(s) battery cable and buss bar terminals from the fuse block by pulling down.
  30. Remove the fuse block and lamp wiring harness from the vehicle, if required.
I copied the info from my database, sorry, it is read only, The way I copied it, read only, no pictures.
Jan 28, 2018 | Chevrolet Impala Cars & Trucks
Font is too small
In Gmail page go right up to right hand top corner (three little bars) click and go down to settings, Top right hand says search settings, click and and type in font, change settings from there
Jan 05, 2014 | Computers & Internet
How to enlarge print? enlarge font? NX230
Any changes to font size, color, etc is controlled by the software in your computer, that you are creating or viewing the document in - if you are just viewing a document in something like Acrobat, you cannot change the type size- your only option is to "blow" up the output, but it might be bigger than what will fit on one page of printer paper
Aug 31, 2012 | Epson Stylus NX230 Small-in-One Color...
How do i bold print
Bold underlined itallics fontsizes and colours
Type <b> before the writing that you want bold.
End the bold text, type </b> after the part that you want in bold to go back to normal.
Type <i> or <u>, to write in italics, or underline.
Type <center> to center a selected area. When finished, you will need to type</center>
Type <font color="colorcode"> and end it with </font>,to write with different colored fonts.
Type <font fontsize="size">to change the size of the font you would like to use.
hope this helps
Aug 13, 2012 | Microsoft Windows Vista Home Premium with...
Gmail icon missing
go to tool--click on it
go down to toolbars
and see if google tool bar is there--if not
on your brower--type in google & go to the website & download it again
Mar 19, 2012 | Google Gmail
How do i get bold letters on my computer,i do not want to purchase program
Without having the operator manual what I recall on these types of type writers, they have a key next to the space bar called "Features Key."
Most keys are color labeled.
Select the bold feature, it's color origin,
1. Press and hold that features key
2. Touch the bold key, now you are in bold typing mode.
3. When you finish bold typing, press the features key and hold, then touch the bold to turn it off.
Oct 16, 2009 | Brother ML-100 Typewriter
MS Word 2007 Bold, Italics, Underline, etc doesn't work
best guess is you install office 30days ago and forgot to register. if you haven't registered yet, please do so and install latest service pack.
Oct 14, 2009 | Microsoft Office Home and Student 2007...
For some reason I can't log in to gmail one specific computer
perform a browser reset by going into: tools - internet options - advanced - reset.
2. remove all the tool bars from add or remove programs.( like google , yahoo tool bars)
Sep 25, 2009 | Google Gmail
Gmail tool bar!
i had a google toolbar plus gmail but used a recovery tape now lost google toolbar and cant get my gmail
Oct 16, 2008 | Google Gmail
Change font color for e-Mail
CAUSE loadTOCNode(1, 'cause'); This behavior can occur if either of the following conditions exists: • Microsoft Internet Explorer is configured to ignore specified formatting features in the Accessibility dialog box. • Outlook Express is configured to use plain text.
RESOLUTION
loadTOCNode(1, 'resolution'); To change the format of the text when you compose a message, use one of the following methods:
Turn off the Accessibility Settings loadTOCNode(2, 'resolution'); To turn off the Accessibility settings, follow these steps: 1. Click Start, point to Settings, click Control Panel, and then double-click Internet or Internet Settings. 2. On the General tab, click Accessibility. 3. Click the following check boxes as necessary to clear them: • Ignore colors specified on Web pages • Ignore font styles specified on Web pages • Ignore font sizes specified on Web pages 4. Click OK. 5. Restart your computer for the changes to take effect.
Change the Sending Format loadTOCNode(2, 'resolution'); Change the sending format to Rich Text (HTML). To do so, follow these steps: 1. In Outlook Express, click Options on the Tools menu. 2. Click the Send tab, and then click HTML under Mail Sending Format. 3. Click OK. 4. Restart your computer for the changes to take effect.
May 31, 2008 | Microsoft Office Outlook 2003 for PC
Google Gmail Logo
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
