Question about Honeywell 3800g Wired Handheld Barcode Scanner
Hi, I use a Honeywell 3800g scanner. I have it setup so that it will advance to the next field after a scan. If the next field already contains proper data, like today's date, I have to use the TAB key on the keyboard to advance or skip over the field until I get to the next field where I want to enter data. Is there a way to have a barcode that when scanned, would advance or TAB over without "touching" the data in that field? Regards, Pat Bouchard
3 Suggested Answers
  • 23 Answers
SOURCE: {TAB} after I scan barcodes??
I just had to do this today... took me a while, but I figured it out. Download the manual from here:
http://www.modul-bio.com/media/Symbol_LS2208_Manual.pdf
Scan the following barcodes in order and it will add a tab to the end of the barcode you scan.
Scan "Scan Options" Pg 13-6
Scan "<Data><Suffix>" Pg 13-7
Scan "Scan Suffix>" Pg 13-5
Scan "7" Pg Appendix D-3
Scan "0" Pg Appendix D-1
Scan "9" Pg Appendix D-4
Scan "Enter" Pg 13-8
You should now have a tab at the end of any barcodes you scan. Hope this helps!
Posted on Mar 30, 2010
  • 34 Answers
SOURCE: I have a Honeywell 3800g Barcode Scanner with a
Most barcode scanners will not use a standard mini-din to USB adapter. You need to replace the cable with a USB cable designed for that bar scanner. Here is a Google shopping result for the cable you need. Good luck!
http://www.google.com/products/catalog?q=honeywell+3800g+usb+cable&hl=en&safe=off&prmd=ivns&biw=1419&bih=695&bav=on.2,or.&wrapid=tlif129971812876510&um=1&ie=UTF-8&cid=1100600390771774037&sa=X&ei=_B94TdetEI6NrQG6p5nuCQ&ved=0CF0Q8wIwAA#
Posted on Mar 10, 2011
Honeywell Barcode Scanners configure for Excel
Find solutions to your Honeywell Barcode Scanner...ask an expert to help you find the right scanner for your application. Honeywell Barcode Scanners for handheld and handsfree bar code scanning
Jan 22, 2014 | Honeywell 3800g Barcode Scanner PN...
I would like to use the honeywell 3800g14-usbkite scanner on widows 7. The user guide says that as soon as the scanner is plugged into the usb, the scanner will beep, despite downloading official drivers...
Go to Control Panel. Open Device and Printers. Do you see a picture of your scanner? If not, run the Windows Troubleshooter and have it detect new devices. Iff you do see a picture, right click on the picture and have it update drivers
Nov 01, 2017 | Honeywell 3800g Barcode Scanner PN...
Need installasion instructions as well as program
Hi
Click hear to find the manual read the manual and install the your HoneyWell 3800G
Jun 08, 2011 | Honeywell (formerly Hand Held ProductsHHP)...
My 3800g barcode scanner puts a prefix of ~% before the UPC number. I'm sure the answer is somewhere in the 156 page manual, but to a non-technical guy like me the manual may as well be written in...
Hi
If you have the user guide then go to the page 48(4.3) there all option available, To clear the perfix and suffix, other wise download the user guide to Click hear
May 26, 2011 | Honeywell 3800g Barcode Scanner PN...
Hi, I am trying to install the drivers for my HandHeld 3800G Linear Imager (barcode scanner), but keep getting the following error: "Cannot Install this Hardware There was a problem installing...
you may have to delete the file or uninstall-then reinstall..if this does not work you may have to go to the honeywell site and reload the drivers again as you may have lost a thread during the initial download ...happens more than you think...good luck
May 19, 2017 | Honeywell (formerly Hand Held ProductsHHP)...
I have a Honeywell 3800g tethered barcode reader that has been working fine on the same computer for approximately 3 weeks. It has been used to scan patient ID bar codes and drug NDC numbers in our...
It's a USB scanner. Maybe you accidentally scanned some rogue barcode that changed the default symbology to something that you can't use in Meditech. I would start troubleshooting basically with this. On the PC where it no longer reads into your Meditech software, try to remove and re-insert the USB cable on both ends - scanner and USB port. Next, ensure that the scanner's driver is set to use this HID (human interface device) as a keyboard emulation device. Next, get (or download and print) the manual for the device, because it has barcodes for changing scanning settings, symbologies, etc. Scan the barcode that says "Reset to default settings", then try scanning again. At this point, if you still cannot get a reading in the Meditech software, try to specify the correct symbology for your medication barcodes. If you still have issues, try a different USB port on the same PC. If still issues, try a different PC. If it works on Meditech on another PC, perhaps you need to update your Meditech version on the bad PC to match the version that works. If all else fails, exchange it for another one; perhaps it truly is defective. I hope you can get up and scanning again!
Edit: I just realized this scanner has more cables than just USB. Are you using a wedge? If so, what kind (PS/2, RS232 (serial) interface, etc.)? There is different troubleshooting for PS/2 and RS232.
Mar 24, 2017 | Honeywell Office Equipment & Supplies
Hi I have downloaded drivers for canoscan N676U Scanner but it tis not contain any setup file hence I con not install it and use it.
hi this may be a .inf file install, what you have to do is,go to control panel then add new hardware, then click next at next window,it will then search for hardware, then it will ask is hardware already connected, click yes ( make sure scanner is plugged in) then scroll all the way down to bottom of list to add new hardware,then click at next window install hardware that i manually select from a list,then select all devices,then click the have disk, it will then ask you to direct it to where you have downloaded the driver files to, then it will give you a choice , pick your one then install...done, hope this helps please vote thanks
Jun 08, 2010 | Canon CanoScan N676U Flatbed Scanner
Honeywell 3800g Wired Handheld Barcode Scanner Logo
657 people viewed this question
Top Honeywell Computers & Internet Experts
Les Morrison
Les Morrison
k24674
Are you a Honeywell Computer and Internet Expert? Answer questions, earn points and help others
