Question about Phonic Helix18fw 18 Channel Mixer with Firewire
I get a distorted sound from my speakers throug a Phonic Helix Board. It is connected on a PC through Fire Wire. The distortion is also there while using microphones or other inputs (CD-players etc.). It worked fine for a year... There's no Left/Right led indicator while playing music, the "solo" buttons don't seem to work. I have tried to hook up a new poweramp, new speakers etc. nothing seems to work.... Please help me, I need this mixer very bad.... Thank you Ton Wanten The Netherlands.
Hallo landgenoot ;)
It seems it is a power supply problem; distorted sound, no meters, solo buttons not working, headphones low level and distorted. One of the power supply voltages might be too low or even missing. The Helix series mixers use mainly 4 supply voltages: + 15 V and - 15 V for the analog part (audio), + 5 V for the DSP and logic and +48 V only for the phantom power. If for example the + or - 15 V is too low, clipping of the positive or negative parts of the waveform (dependng on which voltage is too low) will occur. If possible, first measure the voltages coming out of the power supply. You could use a metal part of a jack as ground reference.
For the FireWire board an extra voltage supplied by the switched PSU is used. It is specified as +12,2 V, but I measured 14 V. This voltage is lowered to + 5 V by a resistor on the FW board and a 7805 regulator. (Not very efficient!) But as far as I can see, the FW voltage is not the problem here. I have some service documentation of the Helix series mixers (12, 17 and 24, so if you need more you can conatct me: frankdevries [at] versatel.nl.
Groeten, Frank.
Posted on Jan 05, 2013
The helixboard was returned to the factory... they fixed the problem: by sending me a new one :)
Posted on Jan 06, 2013
4 Suggested Answers
mwalker02
  • 41 Answers
SOURCE: pc not recognizing phonic helix 18 universal mixer
I have a Yamaha AW1600 and I had to go into my firewall settings and add it to my exceptions to allow the program access to my computer through the firewall. This may help. Thanks!
Posted on Jun 02, 2009
deepfunktion
  • 18 Answers
SOURCE: Phonic mixer not connecting to my PC
install drivers with device disconected
Posted on Jul 14, 2009
  • 29 Answers
SOURCE: Phonic Helix Board sound problems
You don't specify which model Phonic mixer in question.
Is it a powered mixer ? And are you plugging your speakers into the speaker outputs ? If it's not a powered mixer and you're plugging speakers into the Line Outputs, you're not using a power amplifier between the line outputs and your speakers - this won't work.
If it is a powered mixer and you are plugging speakers into the speaker output connectors and still getting little or no sound, check your speaker cables and the speakers themselves by plugging them into known good amps.
Posted on Aug 01, 2009
How do you fix a speaker distortion problem
I have no idea of what make and model that you have. To find out if the problem id the speaker or your amplifier, remove the distorted speaker and connect a known good one. If there is still distortion-it's not the speaker that is distorting-it's that channel of the amplifier.
Oct 18, 2014 | Music
Question about Peavey Escort 3000 300 watt portable PA, both right and left mains work fine, but the right speaker has distortion sound. Even if I change speakers the right out speaker circuit is dist
sounds like an internal connection problem. open access panel and check the solder connection is not broken or loose. Be sure the metal mesh jacket is not touching the lead wire as that would cause a scratchy noise and feedback, or maybe near the internal cable causing feedback
Aug 06, 2014 | Peavey Escort 3000 300 Watt Portable PA...
Marshall MB4410, with low volume gives no real volume,
Guitar amps have preamp sections (think unpowered audio mixer) and power amp sections (Crown rack-mount amp). An excellent way to isolate audio problems if amp is still producing audio is to check the preamp out (line out). Preamp output distorted = preamp failure. Connect MP3 player to "Power Amp In"...sound distorted = power amp failure. In your case the latter is the case as your "line out" is clean. Also test each speaker for clear sound as speaker cone damage from being overpowered is fairly common. At 300w. I'll assume the failure was not from cranking the volume to loud but a shorted speaker or speaker wiring could zap the power amp in an instant.
Jan 06, 2014 | Marshall MB4410 Bass Combo Amplifier
Operations manual
Here is a link to your manual, hope it helps.
http://www.phonic.com/en/helix-board-18-firewire-mkii.html
Nov 27, 2013 | Phonic Helix18fw 18 Channel Mixer with...
I have a Phonic Helix Board 24 firewire MK2 When i open it all the peak led stays open I think the power suply is busted I need an expert
The power supply uses three, 3 terminal regulator chips. You should find +/- 15 volts and +5 volts DC from those. There are two fuses, one for each polarity. If one of those is blown, that would cause the problem and one would need to find WHY it blew before replacing it.
You need to find a competent electronics repair person.
Nov 02, 2010 | Phonic Helix18fw 18 Channel Mixer with...
My hot rod deluxe has internal distortion problems.
There are many components in the system. Electrolytic capacitors are most suspect. C49, C50, C45, C51
There are many others but these are top suspects. You MAY be able to detect a change by cooling these components with circuit cooler spray.
ALSO check the +/- 16 volt power sources in the unit.
Jul 08, 2010 | Fender Hot Rod Deluxe Guitar Combo...
My BOSS Distortion(DS-1) pedal buzzes whenever the distortion is up. I've changed the battery, outlet, and amp, but it continues to sound. I tried a different pedal, and it worked fine. How can I stop it...
This sounds like a broken ground wire or trace within the unit if an IDENTICAL pedal does not act the same AT THE SAME SETTINGS.
Sometimes a circuit trace gets broken on the board inside pedals and can cause this.
Since an identical pedal doesn't have the problem, service is required.
If you know electronics you can open the pedal and look for obvious problems.
HINT: Use a bright LED penlight to "candle" the circuit board to look for cracks.
Look for broken solder joints... this can take an experienced eye to spot.
A distortion pedal NORMALLY is very simple circuitry.
Nov 08, 2009 | Boss Music
Jul 03, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Pc not recognizing phonic helix 18 universal mixer
May 30, 2009 | Phonic Helix18fw 18 Channel Mixer with...
Phonic Helix18fw 18 Channel Mixer with Firewire Logo
228 people viewed this question
Top Phonic Music Experts
Ben Armstrong
NOEL
NOEL
Are you a Phonic Music Expert? Answer questions, earn points and help others
