Question about Roper RS25AEXLQ Side by Side Refrigerator
Where is the fan that cools the refrigerator? There is no air flow from the freezer.
  • Roper Master
  • 43,501 Answers
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Mar 18, 2011
Refrigerator section stopped cooling, but the freezer section still works.
Hi. There is a valve in the top corner of the frigde that controls the cold Air to flow from the freezer to cool the fridge. This valve called a damper closes when the door is opened. You have to depress the door switch and listen for the fan in the freezer to switch on then feel for cold air to flow into the fridge compartment. The fan could have failed or the damper valve could be stuck closed.
Jun 05, 2016 | Maytag MFF2258VE
Our 2 door stainless ken more refrigerator is not cooling but the freezer is working good. Thanks for your help
Your evaporator fan is probably not running. Another thing to check is your freezer port to fresh food side. If you freezer is blocking the air flow your fresh food side will not cool. Find the vent to fresh food side and see if you have air flow, if no air flow you need a new evaporator fan.
Sep 26, 2014 | Kenmore Refrigerators
My Maytag MFF2558VEM Bottom Freezer French Door Refrigerator doesn't keep cool
What you should be looking for is a blocked air flow. The fan in the freezer will push air up to the fridge and cool it off. Look for a dead fan motor in the freezer or a blocked air vent Good luck
Sep 08, 2012 | Maytag MFF2558VEM Bottom Freezer French...
Refrigerator does not cool below 50. Freezer side is ok
all cooling comes from thefreezer, lower down air flow to freezer and increase air flow to refrigerator, this should help.
Apr 08, 2011 | Admiral 26 cu. ft. Side-By-Side...
FREEZER FREEZERS BUT THE REFIGERATOR WONT GET COLD
Check the air return on the bottom left wall of the refrigerator side. Check for cold air flow at the top of the refrigerator when the compressor is running. If you feel no air flow, open the freezer door and see if you detect significantly more air flow after opening the freezer door. This could indicate a return air flow restriction and make sure that there no blocking of air vent at the top of refrigerator section that supplies the cold air from the freezer.Check the door seal gasket on the refrigerator for leaks.
If the vents and air flow paths in the refrigerator are proper, then check the back wall of the freezer for excessive frost. A defrost system problem could be preventing the refrigerator from cooling properly. If you do see excessive frost on the evaporator in the freezer, you may be able to restore proper cooling in the refrigerator by storing your food in an ice chest and then shutting off the refrigerator/freezer and letting the unit completely defrost for about 24 hours. Leave the doors open for air circulation. After the frost on the evaporator has defrosted, plug the unit back in and see if the refrigerator and freezer will cool properly.
If there is still same problem then you need to replace evaporator fan.
Hope this helps.
Shane
Mar 01, 2011 | Whirlpool Refrigerators
My freezer is working but the fridge isnt
Check 24volts fan (DC) is working, which flows the cool air in refrigerator compartments. If not working, replace the fan.Or any materiel you keep by blocking the air flow.
Jan 22, 2011 | Kenmore 73502 / 73504 / 73509 Bottom...
My refrigerator is not working, but my freezer is
Usually there is a air flow problem from it not defrosting(all the evaporator coils are frosted up with moisture preventing air flow-defrost problem ) or the fan motor is not turning in the back of the freezer section above the evaporator....
All of the cooling in the top or refrigerator section is done by air flow circulating across the coils in the freezer to get temps down to 38 degrees or so. You have to listen for the fan running in the freezer section, feel for air at the top back of the refrigerator(the damper control) Sometimes a bi-metal thermostat in the defrost circuit is also used in series with the evaporator fan motor, if it is open the fan will not run........(this I have seen) Also check the vents for the return air to the freezer(behind the crispers are not covered accidentally) Hope this helps........
Jan 10, 2011 | Maytag MFD2560HES Bottom Freezer French...
Refrigerator compartment cools correctly for a few days then no longer receives cold air from freezer. The freezer continues to operate and gets much colder than it should.
does your fan blow? freezers have a fan that pushes cold air to the fridge side if fan is bad freezer will run extremely cold and fridge won't cool down and since frige won't cool down thermostat in fridge doesn't tell compressor to stop
Feb 26, 2009 | Refrigerators
Amana BX22A2W - freezer works, fridge not cooling
Check the damper in the top back of the fresh food section. make sure that it is open and air is coming through it.
Oct 29, 2008 | Amana ABB2227DE Bottom Freezer...
Roper RS25AEXLQ Side by Side Refrigerator Logo
71 people viewed this question
Top Roper Refrigerators Experts
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Roper Refrigerator Expert? Answer questions, earn points and help others
