Question about Dishwashers
I have a Kitchenaid Dishwasher, model #KUDCO3FVSSO. When it was initially installed, it was secured with two clips on the top front of the unit, to the underside of the countertop. The countertop at the time was formica top with a flakeboard bottom. This material made it easy to secure. I am switching to concrete countertops today and wanted to know two things. One if the clips can be installed somewhere else where they won't be seen. Two if they have to be installed in the same place how is it done considering the new surface?
4 Suggested Answers
IB4G2008
  • 3587 Answers
SOURCE: We have replaced our kitchen
the under counter inserts, made from plastic moldings(standard for dishwashers) are one approach. Having a custom frame built,and installed, is strongest long term solution. And all the better if it's a sliding type, for ease of service, which you WILL need sooner or later.
I'd call a local carpenter, and show them your issue, and get this done properly.
the granite will not do well, when it's penetrated at more than 25 to 40% of it's depth.
Posted on Mar 17, 2008
SOURCE: mounting brackets for granite countertop
This is the best way i have found. You must check this company out. Granite Grabbers www.GraniteGrabbers.com They are extremely simple mounting brackets secured with a very strong double sided adhesive. You do not have to drill you cabinets or deal with any expoy.
I have used them with excellent success, took 5 minutes to install
Posted on Feb 03, 2009
erpaalai
  • 999 Answers
SOURCE: our dishwasher steam has expanded the wood chip at
You cannot resize the wood once it has swelled. You have 2 choices: 1, replace the countertop with something more steam resistant or,2 remove the swelled area and replace the wood with pine or oak glued into place with moisture resistant adhesive.
Eric
Posted on Dec 30, 2009
Our KitchenAid dishwasher started making scary baby cry sounds. then a few months later the clean dishes would have a white film over them like dried detergent didn't rinse.
Hello Cindy;
My name is peter. I am a retired field service appliance technician.
You need to provide a model number so I can see what you have. The model number is on a tag on the front face of your dishwasher after you open the dishwasher door.
You may want to remove the bottom front panel on your dishwasher, run the dishwasher and observe. There are two clip pins on the top of the bottom panel. Push in with a putty knife or something similar. Pull on the top of the panel on both sides, then lift the panel up.
Jun 08, 2015 | KitchenAid Dishwashers
What are the dimensions?
You are missing a digit in the model number. KitchenAid Dishwashers have a number (0-6) after the SS.
The KUDI01FLSS0 installation guide gives the dimensions of the dishwasher opening and the unit itself on various pages. See http://www.kitchenaid.ca/assets/pdfs/literature/Installation%20Instructions%20-%208524480.pdf . The top vent and the front vent KUDI01FLSS model washers are slightly different. The front vent dishwasher dimensions are 33 7/8" H (with the wheels removed) x 23 7/8" W x 24 7/8" D (including the handle). The top vent model is only 24 1/2" deep. With the wheels in their lowest position, the opening for the dishwasher must be 34 1/2" high (from floor to the bottom of the counter top).
I hope this helps. Other KitchenAid appliance manuals are available here: http://shared.whirlpoolcorp.com/product_literature/search.jsp?siteCd=KAD . Use the search box to enter the model number and use the drop down menu to select Consumer.
Aug 14, 2012 | KitchenAid 24 in. KUDI01FLSS Stainless...
I misplaced my installation instructions. in the instructions i saw a comment about securing the dishwasher to the side of the counter if it was under a granite counter top. i did not read the...
Every dishwasher I’ve ever dealt with has at least one way to secure it to the counter/cabinet. The model I have now uses only two brackets at the top. The one in my old house had these plus two holes on each side around the door area that you could screw through then cover the screws with little rubber plugs. The hardware has always been supplied with the unit but I’m sure you could find what you need at your local home improvement store.
Feb 03, 2018 | GE Hotpoint HDA3500N Dishwasher
I cannot change cycles and the dishwasher won't turn on.
Micro controller problem. Take help from authorized service center help.
Apr 11, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
I have a stainless steel kitchenaid dishwasher that has come completely loose. I can pull the whole dishwasher out of the wall. I need to know how to tighten it back down?
Generally, these units just slide into the cavity, and then several screws are driven up into the underside of the cabinet top. Open the door and look up at the upper front lip. Either the screws were never installed, they may have pulled out of the wood due to being too short, or the cabinet is made of chip board and the screw holes were not pre-drilled. Hope this helps!
Jan 07, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Kitchenaid Dish Drawer unit is canted forward; I need to get to the back legs to adjust them downward. How do I get to them?
Open the dishwasher door and undo the two screws that secure the face to the counter-top. Open the kickplate and slide the diswasher out of it's hole. You should be able to easily access the back legs now. It may be easier to disconnect the drain and supply hoses (turn off the angle stop first) and flip the dishwasher upside down using a carpenter's level to make sure all your feet line up. Flip it over, reconnect, and reinstall.
Jul 01, 2009 | KitchenAid Dishwashers
KitchenAid model KUDS25SH (Stainless) latch has come loose.
Remove the six or seven screws that secure the entire control panel to the door (screws are located inside of door around the top. Pull out the control panel and the door latch mechanism will be right there for you to work on.
Jan 31, 2009 | KitchenAid KUDC25CH Dishwasher
Leaking around seal in the center of dishwasher
the white hook peice is just that, a clip to hld down the motor. as you reinstalled you must have twisted or shifted housing to "pop" that clip. no worries easy fix. remove the lower rack and give alook at the motor assy from within ther tub make sure the black gasket is pushed completely down flush with the bottom of the d/w. applying pressure to top of motor assy will push it flush. the motor simply rests in the opening . the clip holds it in place from underneath, unable to find a pic but there a 3 in total under unit.
Nov 05, 2008 | KitchenAid 24 in. KUDS02FRSS Stainless...
I have kitchenAid KUDM24SEWH5. The door opens with no resistance. I assume the door spring came loose or broke. How do I check this out?
If you remove the toe kick panel and look at either side of the machine you will see a lower frame rail near the floor. If you look at the upper and lower edges of the toe kick you should see 2 or 4 screws which are typically used to hold it on. Under the panel on either side there is a spring clipped to the frame rail about 4 to 6 inches from the front. This is the door spring. It attaches on an arm the is at a 90 degree angle from the front door panel. There is one on each side.
Alternately you may pull the dishwasher out from the cabinet to reattach the spring if it is loose. If you open the dishwasher door and look upwards under your counter top near the top of the dishwasher you should see two screws which fasten the dishwasher to the cabinet. Some models have side screws but most just have the top. With the screws out you should be able to bull the dishwasher straight out from under the cabinet. Do not use the door to pull as you could pop it off of the hinges. You will only have to pull it out 6 inches or so to see the springs and mounting positions.
Jul 29, 2008 | KitchenAid Dishwashers
Dishwashers Logo
91 people viewed this question
Top Dishwashers Experts
