Thank you for using FixYa
Go into to your router from the browser and type in 192.168.1.1 it should open the page to enter information. You will need to put in the password which should be admin in both boxes, unless you have changed it.
Click on the Wireless Stecurity subsection at the top of the page. In order to password protect your wireless network first use the Security Mode dropdown box to select WEP and then from the WEP Security dropdown box select 128 bits 26 hex digits. Choose a password between 6 and 8 characters and type it into the Passphrase box. Then click Generate. Finally click Save Settings and then Continue when the Settings are successfuldialog is displayed. You may also select WPA encryption, however not
all network cards support this, so check your documentation first. Go on down the page and don't forget to save in information. Get out of the router and reset the power on router.
I hope this was useful and please comment if this was helpful to you.
Configuring WEP on the router
First, let's log on to the router.
Write down the SSID
In the Linksys WRT54G router you will find the wireless security options under Wireless > Wireless Security. This page allows you to set wireless encryption options.
'WRT54G
The Wireless Security page allows you to generate a strong network key. Here is how.
Your computer will now be disconnected from the router. You may see a 'page not found' warning or some other error message in your webbrowser. Your router now demands that computers that connect to it use WEP encryption and the correct WEP key. In other words: you have succesfully secured your network.
If you need more help come back.Post /thumbs / testimonial are welcome!
