Question about Samsung Audio Players & Recorders
I had to restart my HT-C5530 Home theatre bluray device by pressing the stop button more than 5 seconds which brought me back to the initial setup. Now it seems that the remote can't send its signal to the device and its stuck on the first setup page where you select the languuage of choice. Please help me! thank you! P.S. I tried the troubleshooting in the manual: check bateries, make sure remote is within range and angle, and make sure BD/TV is selected on the remote.
  • 84 Answers
SOURCE: ESA ET413E LOST INSTRUCTION MANUAL, NO SELECT KEY!
when picture is displayed on your tv after pressing menu,press the channel up/down button on the remote or tv. there can also be a button that shifts right to left. this may hilight the the settings you want to change. if the up/down button scrolled you thru the settings, then the right/left buttons should change the settings.
hope it works
wg
Posted on Jan 28, 2008
SOURCE: Unresponsive remote
Had same problem with this reciever over the weekend. I had to hook up a TV to the COMPOSITE monitor jack and then I could see the menus. I could never get it to show the menu over the component outputs, however a DVD player hooked up played perfectly. Anyone have a solution?
Posted on Feb 18, 2008
jay_win2002
  • 16 Answers
SOURCE: How can I get all 5 of my speakers to work with no remote???
if it dose not have an opion to change specker setup on reciever''then you will need the remote''''
Posted on Jan 30, 2009
  • 121 Answers
SOURCE: tomtom xl.... on starting unit it immediately goes to select a language and then a few more windows such as right/left handed, time display format and eventually it goes to select a voice where after
yep common error reset it or plug it in to pc and download other voice
Posted on May 04, 2009
  • 14 Answers
SOURCE: Tom Tom one Will not perform setup, locks up at voice selection.
Try doing a man reset.
Posted on Jun 24, 2009
How to reset an adr6350 phone
Preferred Method
  1. From a home screen, select the applications tab (located in the lower left).
  2. Select Settings.
  3. Select SD & phone storage.
  4. Select Factory data reset.
  5. Select Reset phone.
  6. Select Erase Everything.
  7. Perform Initial Activation/Setup.
Alternate Method
  1. Press the Power button for 3 - 5 seconds.
  2. Select Power off.
    linote.gif If the device isn't responding proceed with step 3.
  3. Remove/replace the battery.
  4. Press and hold the Volume down key then press and hold the Power button for 3 to 5 seconds.
  5. When the HBOOT screen appears, release the Volume down key and Power button.
  6. Press the Volume key to select FACTORY RESET then press the Power button.
    linote.gif This boot process takes several moments. If the device hangs or freezes, remove/replace the battery.
Mar 08, 2014 | HTC Incredible 2 II / ADR6350 ADR-6350 Hot...
MAKING A SAMSUNG HT-F6500W REGION-FREE
1) Switch Player off then On (this is to clean-boot firmware).
2) Wait until main menu appears
3) Open Disc Tray and Close Disc Tray (May not be necessary)
4) As soon as "No Disc" is displayed quickly press REPEAT on
remote quickly use the following code for your current
region:
Region 1: Press - 2,9,3,3,4
Region 2: Press - 5,7,5,3,8
Region 3: Press - 5,6,7,3,2
Region 4: Press - 7,6,8,8,4
Region 5: Press - 5,3,8,1,4
Region 6: Press - 2,4,4,6,2
5) Your current Region will appear in the top-right corner
6) Quickly Press "9" before it disappears (It should replace
the code with a "9" in the corner)
7) Switch Player Off and then On again.
Note that REPEAT is part of the code so one smooth press of
6 keys is required.
There isn`t currently a region hack for Blue-Ray Disks
Dec 27, 2013 | Samsung HT-F6500W/ZA Home Theater System -...
Samsung home theatre HT-X30,
The DVD player may have failed.
Dec 19, 2013 | Audio Players & Recorders
Why wont my ht-e3550 play tv sounds
I have the exact same problem - I have connected the RCA cables but it's just not working....this is very frustrating. Anyone who has a solution - pls contribute! Regards, Justin
Mar 16, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
Does anyone have the code for sky remote to tune it in to the sa-ht880 Home theatre I did have it on old remote and the volume button worked but can't find code now :-(
Step 1:
You can set up your old remote very simple.
your old remote should have a "Setup" button.
Step 2:
Next you have to have your T.V/Home Theater on.
Step 3:
While the T.V is on press and hold the "setup" button for 3 seconds on your old remote.
a light should indicate that its on "setup" mode.
Step 4:
while your remote is on setup mode point it to the T.V and press the "Power" button until the device turns off.
Step 5:
Once your T.V turns off you can press "Enter" on your remote will be setup and ready for that T.V.
Feb 06, 2013 | Televison & Video
Virgin mobile venture won't start
Take the battery out. Then put it back in. I couldn't find anything that would work but doing a hard reset. Once I did that the phone worked again. I lost everything but my phone works again.
To hard reset the Virgin Venture please follow the instructions below:
Start with the phone turned off.
  1. Press power button until the phone turns on and vibrates.
  2. Press and hold the up volume button until you see the word hello.
  3. Release the up volume button.
    Note
    : You will see the word hello on the screen for about 5-7 seconds.
  4. The screen will display the android guy next to an exclamation point inside a triangle.
  5. Press the home button to access Android system recovery screen.
  6. Scroll to and select wipe data/factory reset.
    Note
    : The volume button scrolls and the enter/return key selects
  7. Scroll to and select Yes.
  8. The Venture will reset.
  9. Select reboot system now.
The Venture will reboot to the initial setup screen
Aug 10, 2012 | Virgin Mobile PCD Venture No Contract...
HOW DO YOU RESET A SAMSUNG HT-WX70 HOME THEATRE SYSTEM?
According to the instruction manual you turn off the unit and press the Stop button on main unit for at least 5 seconds. Didn't help me with my problem (shutting down for no apparent reason) maybe it will help you with your problem.
May 06, 2009 | Samsung HT-WX70 Theater System
Resetting the progressive scan mode on an LG lh-d2645 home theatre system
the above is correct but you need to have the dvd player on with no disc in so "no disk" is shown on the front display. then hold down the stop button for 5 secs to reset the display mode back.
Jan 20, 2008 | LG LH-D6230 System
Swa3000
  1. With the home theater system off, press and hold the REMAIN button on the home theater's remote control for 5 seconds.
    Note: You can release the REMAIN button when the POWER LED blinks blue/Red depending on model.
  2. With the SWA-3000 turned on, use a ball point pen to press the RESET button on the back of the SWA-3000. The POWER LED in the front of the home theater blinks two times.
Feb 14, 2007 | Samsung HT-Q70 Home Theater System System
53 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
