Question about Zebra 3.60V,1500mAh,Li-ion,Replacement Barcode Scanner Battery Replacement Parts, Battery for SYMBOL P360, P370, P460, P470,Compatibl... (5014000079KTBTYPL01SM470ISYM360)
How do i find tec or place that can get help or repair, for a symbol p370\p470 or download the setting so i can program or upload it to another. im in green bay, wi i have one with error 4, synax 1: 2; 2 one with error 4, syntax 1: 3; 0 they wont initialize wally
  • wpbrzezinski Mar 18, 2011
    yes it worked
    now to fine a local dealer
  • Zebra Master
  • 19,396 Answers
Hi.
Error 4 is a programming error (wrong decimal value- here MCL guide).
The errors belong to the MCL, try resetting the scanner with this RESET PROCEDURE.
OR How Do I Erase an MCL Application from a Keyless P370/P470?
To get repair and support, register here:click here to continue., then click here.
Alternatively use Contact Us.
Regards.
Ginko.
Posted on Mar 18, 2011
Scanner scans incorrect barcodes to intuit pos on
Needs to be programmed, cal me 847-847-7835 x202
Sep 25, 2013 | Symbol P370 Handheld
I need to strip the last character from the barcode when scanned with a Symbol P370 scanner. Is there a procedure for that?
If the barcode is a UPC-A or UPC-E you would scan the Do Not Transmit UPC-A or UPC-E Check Digit barcode from the P370 Product Reference Guide.
If the barcode is something other than a UPC-A or UPC-E the last character can be stripped using Advanced Data Formatting which would require the use of 123Scan. You can download 123Scan from support.symbol.com.
The P370 is NOT supported by the newer 123Scan2.
Jan 21, 2011 | Symbol P370 Wireless Barcode Scanner
Code 128 Barcode Problem
Hello paul blando. I think I can help you here. First, are you sure your barcodes with asterisks are Code128 like the others? Generally a Code128 barcode will look like: "(1234) 567890 (01) 123456" and wouldn't really use asterisks at all. However, I know that it is standard practice for people who make their own Code39 barcodes to start and end the code with an asterisk to denote a start/stop action. Could they be Code39? They would look like: "*123456789*". If this is the case, then I have the manual for the P370/P470 on my company's site here. Take a look at the Code39 Chapter and make sure to print and scan the pages to disable the check-digit transmittal. If that doesn't do the trick, then try the "recall defaults" or "reset to defaults" barcode to reset the scanner to it's initial defaults. That should put it on track. If you still have trouble, please feel free to send me a message or email me. I hope this helps. Good luck!
Dec 02, 2009 | Symbol P370 Handheld
How do i enter and ascii value on the keypad of the p370
Sure, there is a easy way to get this ASCII value entered. Please contact me. You can always contact me by phone or email 630-622-2024 akowalski@legacyglobal.com Please visit our website www.legacyglobal.com
Sep 01, 2009 | Symbol P370 Handheld
Symblo Scanner not pairing with Base
If the bar codes are in good shape and can be read by other scanners then your scanner probably needs to go to repair. You try to reboot the scanner by pressing FUNC then *
If you need the scanner repaired let me know and I can repair it for you.
Jun 01, 2009 | Symbol P370 Handheld
Symbol p370 scanner weak signal
Try changing the frequency that the gun uses. Ususally 83. 82, 81 are the best, but others might be better depending on electromagnetic interference.
Apr 19, 2008 | Symbol LS 4071 Handheld
123Scan File
P370 WILL NOT connect with your terminal or base, so forget about this intent and go for the goal which is loading your programming to your scanner. According to Motorola the work around is simple and faster than trying to resolve this.
Start with Reseting the scanner completly back to Defaults.
In the 123Scan, PRINT Barcodes and the rules ADF Rules of your programming.
Start scanning from
"Parameter Settings" until the last page barcode "Reset Scanner".
That is it. Problem solved.
You will need to do this for every new programming Rule.
Nov 18, 2006 | Symbol P370 Handheld
Zebra 3.60V,1500mAh,Li-ion,Replacement Barcode Scanner Battery Replacement Parts, Battery for SYMBOL P360, P370, P460, P470,Compatibl... (5014000079KTBTYPL01SM470ISYM360) Logo
105 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
