Question about SATO Cl412e Label Printer
Hi, I am using SATO CL412e printer(network printer) and getting below error while printing a BarTender label: Error :3700 BarTender cannot use printer '\\xxx.xxx.x.xx\SATO CL412e' to design, print or export a label format due to a printer setup problem. There are several possible reasons: 1) The printer is not turned on or is off line. Try printing a test page from Windows. 2) The printer does not exist on your system or network. 3) Security settings prevent access to the printer. 4) If you use a network for printing, there may be a problem with the network connection or the printer driver. 5) There may not be enough memory available. Try closing files and programs you aren't using. 6) The printer driver is installed incorrectly. Try reinstalling the printer driver. Please help me to resolve this printing issue.
How can I adust the printer for even distribution ?
Computer program issue. unless the paper is tracking off. Try Reloading paper and check that rollar is latch rvrnly
Jul 25, 2014 | SATO Cl412e Label Printer
Sato shuting down
Replace Power board inside the printer
May 22, 2014 | SATO Cl412e Label Printer
I am using Bartender software and a I4208 printer. It won't print on the first 1/10th inch of a 1inch x 4inch label. It also won't present after printing. Any help would be great. This printer is set up as...
In Seagull driver/Bartender software, Present Distance may be called Tear Off and can be adjusted after checking Post-Print actions in Document Properties, Stock tab. Standard setting is 0.40 inches.
On the same tab, right below that, is "Top Offset", and that adjustment may get you the lower Start of Print you want. Ok to try negative number here.
Sep 25, 2013 | Datamax I-4308 Thermal Label Printer
The following error is coming over the On Printed label. [PY] parameter error ! Ple give me a solution..
This sounds like a software problem. Can you give me details of software used i.e. database and labeling software?
Aug 23, 2011 | SATO M84Pro Label Printer
Ribbon not printing correctly on new labels have a sato CL412E and we are using the same ink ribbons we always use (premium wax/resin ribbon TRX-55) and we just started using new labels from a new company...
The ribbon / label combination usually doesn't have anything to do with print position of the fields on the label. Is the quality/durability of the print that you are seeing on the new labels the same as before ? With a glossier stock print quality should actually be better. This will at least tell you that the ribbon is correct for the new label stock. Is the new label a different size than previous labels ? That could account for the fields not printing in the correct position if the printer is not calibrating correctly on the new size.
Not sure if this will help but may give some ideas...
Apr 07, 2010 | SATO Cl412e Label Printer
What is dip stick setting for dhcp Sato cl412e with ethernet card
You must use the provided software to change the settings. It looks for the printer by the MAC address
Aug 17, 2009 | SATO Cl412e Label Printer
Getting an sensor error on Sato Barcode label printer CL412
Possible solution recalibrate media sensor and make sure your using the right media type on your label.
Aug 10, 2009 | SATO Cl412e Label Printer
Hi there! I work with Zebra TLP2844 through
If you are using Bartender, Make sure to use the Seagull Scientific Zebra Driver. The zebra driver works (but not properly) with bartender. Download the driver from Seagull Scientific site. You can also email bartender tech support, their contact details are available from the help screen on the main bartender design screen. I have always found them to be extremely knowledgeable and helpful.
Jul 01, 2009 | Zebra LP 2844 Thermal Printer
Printer Error(Sato Cl 408 e)
PROBLEMA EN AJUSTAR EL CORTE DE LA ETIQUETA, CUANDO LA IMPRESORA SENSA LA ETIQUETA, ESTA QUE CORRIDA HACIA LA PARTE DE ATRAS DEL CABEZAL HACIENDO NECESARIO UN FEED PARA PODER CORTAR LA ETIQUETA
Jul 05, 2008 | SATO CL408e Thermal Printer
Printer problem
check baud rate on NIC card (pull out NIC), against COM settings on PC. they must match. 9600 usually works
May 22, 2007 | SATO CL408e Thermal Printer
SATO Cl412e Label Printer Logo
294 people viewed this question
Top SATO Office Equipment & Supplies Experts
CheckitRight
CheckitRight
kbtkbt
pkwc
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
