Question about Joovy Zoom ATS Joggin Stroller Black Jogging Strollers
My joovy Zoom troller shakes, mostly when running but sometimes walking too. Seems to do it when front wheel is in swivel mode. When front wheel is fixed, stroller tends to veer off to one side, then I'll straighten the stroller, and it might veer off to same side or the other side. Help!
Joovy wheel
Here is a link for parts... http://www.joovy.com
Jan 09, 2013 | Joovy Caboose Baby Gear
Our stroller shakes when pushing forward (very badly - would shake the baby out of the stroller if we had her in it), but if you pull the stroller back it appears to cease shaking. Is there something...
You don't mention what make / model you have. Try turning stroller upside down ( without baby in it *-) ) and spin each wheel to see if it runs freely. Try to rock the wheels from side to side to see if there is any play in the axel. On a flat smooth surface do all wheels touch the ground? If the front wheels swivel do they rotate freely without any side to side play? Some strollers have nuts you can adjust others just have Silver domes. Try tightening nuts till wheels get tight then back off just enough so they spin freely try taping domes on tighter using a large socket from a socket set and a hammer so the pressure is around the edge of the dome and not in the centre where it would dent. Silicon spray is the best lubricant for strollers.
May 09, 2011 | Bertini Baby Gear
My front swivel wheel shakes about 30 seconds into our walk. What is causing this? Can it be repaired?
Hey there,
Its hard to say what exactly the problem is but here are seem things to try.
If you turn the stroller upside down you should see 4 screws (2 on each side) right by the front wheel on the underside of the stroller. Make sure those are in tight because if they are loose they can cause shaking in the stroller. Also make sure that the wheel is screwed in tightly to the wheel base as well.
If these steps dont work then you might need to order a replacement for the front wheel. This can be done by calling customer service of Kolcraft at 800.453.7673 or you can email them at customerservice@kolcraft.com.
This is their website : http://www.kolcraft.com/customer-service/replacement-parts/
Hope this helps!!
Mar 01, 2011 | Jeep Liberty Urban Terrain Jogger
Baby trend double jogger stroller pulls to the left when front wheel is in locked position AND front wheel wobbles (cannot push through it)when on swivel.
Hey! I just fixed my shaking wheel! There is a red lever above the swivel wheel. I pushed it up. And guess what... I can jog with my stroller!
Jul 03, 2010 | Baby Trend Expedition Double Jogger
Babyjogger city elite front wheel shakes
You need to put more weight on the front of the stroller. The wheel is shaking because it's able to swivel....
Apr 12, 2010 | Baby Jogger City Series Single Stroller
Phil and Teds Vibe front wheel doesn't swivel
I had this problem 4 times with mine!!! the company tried to repair (unsuccessful) and then replaced it. The same problem occurrred with the second one after a month. Phil and Ted's took it back and put a thing called "super lube" on it. At first it was no better, but with a little use it seems to have come good.....for now. This is a terrible stroller that I really regret buying!!!!
Nov 19, 2009 | Baby Gear
Swiveling Problems
Sounds like a loose bolt. Check under the front of your foot protector.
Sep 29, 2009 | InSTEP Safari TT Single AR165 Jogger
My jogging stroller shakes
Well, i'm not positive in this, seeing how I never had kids, but while jogging are you pushing down harder on the stroller? or you could look for smaller wheels to put it on, but then again you might have'ft to bend over to do it, and if the handle which you push is tall that has to do with force viberating the stroller
Nov 29, 2007 | Baby Gear
Shakes when going fast
Problem suggests that the stroller has sustained structural damage in the accident.If you use it with any additional weight than what is the recommended as per cataloge the stroller may give away causing injury.The damage is beyond repairs and hence it is not safe to use the equipment any more.
Aug 25, 2007 | SafeTech Double Jogging Stroller
Joovy Zoom ATS Joggin Stroller  Black Jogging Strollers Logo
182 people viewed this question
Top Joovy Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Joovy Baby Gear Expert? Answer questions, earn points and help others
