Question about Bose Wave Radio
How do i change the memory back up battery? - Bose Wave Radio
    Top Expert:
  • Bose Master
  • 74,106 Answers
Hello
You can replace the battery without loosing its memory. Follow these instructions. Battery must be changed as fast as you can. So read well and they do the work.
o Bose radio uses a standard nine-volt battery that serves as a backup for the memory and alarm when it's unplugged or when the power is off. It will power these functions for up to three days. Using the radio without the battery won't damage it, but the memory won't be backed up. The battery does not provide enough power for normal operation, including the lighted display.
To install a battery, turn the radio over. Push on the arrow on the battery chamber cover and move it aside. Match the terminals on the battery with their opposites inside the chamber, and push the battery securely into place. Close the cover and return the radio to an upright position.
Connect the power cord to the jack on the back of the radio. The flat side of the connector must line up with the flat side of the jack. Since the power cord contains the FM antenna, uncoil the cord for the best reception. Plug the power cord into a standard electrical outlet.
An FM cable connector is on the back of the radio. Contact your cable company for help in setting up your connection. When you set it up, be sure to use a splitter that separates the FM signal from the TV signal so that the TV signal won't be transmitted to your radio.
If your remote is slotted on the back, press the tip of a pen into the opening and push the battery chamber cover to the side. If there's no slot, push the tab to one side with your finger and open the chamber cover. Use only a lithium battery size CR 2032 or DL 2032. Place the battery into the chamber with the plus sign face-up. Push the chamber cover closed and it will lock.
Posted on Mar 18, 2011
Where are the back up batteries located
In this model, I think they are located under a small cover behind the receipt roll. Make sure you LEAVE THE POWER ON IN REG MODE when changing the batteries or you will lose all programming and sales memory. As long as the display is lit, it is safe to change the batteries.
Oct 14, 2015 | Casio PCR-T2000 Cash Register
How I change the battery
What is year--make--model? You can't get the battery in or out? Also, with some vehicles, you may be ahead to use a memory saver that plugs into cigar lighter or power outlet, to help keep some memory systems alive if you have to disconnect battery.
Some systems if they lose memory it can cause problems.
Mar 04, 2015 | Cars & Trucks
My polaroid DVF-720 digital camcorder wont turn on.the battery is fully charged and it is in the right way.
1.Remove battery
2.Remove memory(EXTERNAL MEMORY)
3.Plug in the power ,CLICK BUTTON ON in 10 second.
4.Plug out the power
5.Insert back battery.
6.Click button ON IN 10 SECONDS AGAIN.if it will ON MOVE TO STEP 7. IF NOT,GO TO STEP
7.OFF CAMERA AND THEN BACKUP YOUR MEMORY(EXTERNAL) to pc
8.CHECK AND FORMAT
9.INSERT BACK EXTERNAL MEMORY
10. ON BACK AGAIN.
11.TRY CHANGE BATTERY . SOMETIMES BATTERY WAS ISSUED FOR THAT. IT NEED OPTIMUM POWER. BATTERY FULL DOESN'T MEAN THAT IS OKAY.
however, mostly issue are cause from external memory, if that can ON without external memory that mean your memory was problem. backup, checking disk.
FORMAT, USING PC .IF SUCCESS IN FORMAT USING PC, THEN FORMAT AGAIN IN YOUR CAMERA. IN FORMATTING USING PC, TRY USE FAT32 THAN FAT.
TRY IT...out
May 28, 2011 | Cameras
Memory setting changed - no bios screen to reset memory to auto I had a running system DG41KR + 2G memory(KVR1333D3N9/2G) I wanted to increase memory to 4G, could only get KVR1333D3N9/4G Inserting...
It sounds like what you need to do is reset your bios back to factory settings. You can do this by doing something called Clearing your CMOS. To do this, look at your motherboard for a silver battery. Near it should be three pins perpendicular from the motherboard. On two of them should be something called a jumper. With the computer unplugged, move the jumper to the other two pins. Wait for 30 seconds then move it back. Plug the power back in and start it back up. Everything should be working properly. If you cannot find the three pins, just pull out the battery for a few hours with the computer unplugged from the wall. This will accomplish the same thing, it will just take longer.
May 17, 2011 | Intel DG41KR Motherboard
(dell mini 10) Changed RAM from 1gb to 2gb, tried start up and got 4 beeps. Changed it back to the old 1gb, start up and still got 4 beeps....What do I do?????! ! ! !
Try this:
Remove all the memory. Remove the battery.. Wait for ~10 seconds. Turn it on using a power adapter without the battery or memory in.. Wait a couple of seconds, let it beep.
Turn it off again Wait for ~10 seconds. Insert the memory you want. Turn it on.
Apr 28, 2011 | Computers & Internet
I am getting a Memory Battery is Low - how do I recharge or replace teh memory batter. I only load AAA batteries into the equipment?
The memory battery is normally charged by the AA batteries. Leave the batteries in for 5 days. If this doesn't recharge the memory battery then it needs replacing. It's recommended that you send the unit back to Garmin to have it replaced. The memory battery is a Panasonic VL 1220. If you want to attempt changing the battery yourself there's some information on how to do so at http://forums.groundspeak.com/GC/lofiversion/index.php?t38975.html
Nov 08, 2010 | Garmin GPS 12XL GPS Receiver
Change sim card
to change the SIM card just remove the back cover. You should see the memory card just below the battery. Remove the battery to see the SIM card.
May 31, 2010 | Motorola Mobility RAZR V3m Cellular Phone
Sir, My mobile is Nokia 6500 model. In contact settings,at first it was set as contacts>>settings>>"memory in use"-PHONE AND SIM. By mistake I have changed the option of "memory in use" to...
usually the phone memory security code for nokia mobiles will be 12345, until it is changed manually. try this code... else, u have to consult the service provider i guess.
memory card not detecting....
First you open gallery on screen. If the memory card ok the first item will be the name of your Card. If it is not found that means the card not detecting. You may do this.:
Open Gallery, then press the back ( battery cover ) of the phone and hold for one second, now see the screen, you can see the card name on first line. But when you take your hand back form the battery cover the display revert to the same as before.
The point of pressing:- near to the lense ( Just right side of the lense) . You know why ?. The memory card is located inside of that place.
This means there is a switch (Battery cover open / close) located just left side of the memory card, and there is a TIP projected in the same place at the Battery cover. When we close the back cover the switch become ON. Here is the problem.....!. The switch will not contact even you close the cover. When you press the cover hardly the switch become contact. when you remove the hand again it become open.
More clarification:-
In a new phone if you open the battery cover the memory card will not work at all. It will detect only after closing the cover.
this may help you.
Jan 08, 2010 | Nokia 6500 Slide Cellular Phone
When I press the power button the light turns
hi..
Try taking out your batteries and then taking out your memory card. Put back in batteries. Turn on camera.
If this works, just put back in your memory card and try again. Sometimes the memory card hangs and you need to pop it in and out.
thank u
rate me!!
Jul 15, 2009 | Sanyo Xacti VPC-S770 Digital Camera
Change memory on Lifebook S7010
Check on back side of laptop you find 1 battery slot .And RAM slot is upon battry position .
Open that plate above battery and just pull RAM memory then you can change it.
Jun 23, 2009 | Fujitsu Siemens LifeBook S7010 Notebook
Bose Wave Radio Logo
159 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Ben Armstrong
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
