Question about Kelvinator MDB121RF Dishwasher
Whirlpool MBD121RF dishwasher. Fills and drains but does not wash (spray water - as far as I can tell). Nothing seems blocked. Both pump and timer are expensive to replace and the unit is 15 years old.
  • 1462 Answers
SOURCE: Dishwasher not getting water into spray arm, so no clean dishes
two possibilities: open door when in use. check if water is coming out of the spray arms. if it is and at a good rate, then the problem may be the spray arm jets blocked. the spray arms are only rotated by water coming out of the angled jets at their end or is the main circulating pump running ok?
Posted on Apr 02, 2007
  • 14 Answers
SOURCE: Whirlpool dishwasher model gu1200 not working
I checked. There is no sheet of any kind inside or below the door of my Whirlpool dishwasher.
In any case, opening up the non-washing washer revealed that the filter behind the chopper assembly was clogged with food. I cleaned it off, put the thing back together again, and it was washing dishes again, until about three days later. I took it apart again and found food clogging the filter behind the chopper. I thought the chopper wasn't chopping, so I replaced it. It was around $16. About three days later it wasn't washing dishes again.
Further examination (dis-assembly of the sump motor and impeller) revealed that the end of the impeller (which is designed to engage the chopper) had broken off, thus the chopper no longer spins with the sump motor. The impeller costs about $20 and isn't too hard to replace, as long and you keep track of what you've dis-assembled and put it back together in reverse order.
On whirlpool dishwashers, the sump motor drives the impeller (it's connected via the threaded end of the motor shaft) and the impeller, in turn, drives the chopper. The chopper you can replace from inside the tub, without removing the dishwasher from its home or taking apart the sump assembly. But save your $16, as that probably isn't what is wrong... The impeller, being screwed onto the motor shaft, requires complete removal of the dishwasher so that you can completely remove the base assembly that holds the motor assembly.
If you have a GU-series whirlpool washer, the tech manual can be found here:
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/52521bdbd0ef763c85256cbc00520548/$FILE/8178022.pdf
It has complete instructions for the replacement of every part.
Posted on Dec 29, 2007
SOURCE: dishwasher pump will drain but not force water into spray arms
If the washer is not used regularly the shaft can stick to the seals and prevent the motor from spinning. This happens quite regularly for me if I don't use the washer often. You can just take off the bottom panel - after shutting off power to the dishwasher - and access the motor. you should see some fins and then just try to spin the motor by hand. It usually takes about 90 degrees of rotation before the motor breaks free from the seal. You'll have to fight through the spring-like resistance created by the seal-shaft adhesion. After it breaks free the motor spins freely and you should be all set to go. I haven't found a more permanent fix for this other than running the dishwasher more regularly.
Posted on Feb 09, 2008
watugot
  • 290 Answers
SOURCE: dishwasher - no spray arm action
If it is filling with water properly then it sounds like the chopper screen is clogged so that water isn't getting into the pump. You can remove the top of the pump housing and get to the screen and chopper blade to inspect it. Go to sears.com, click on parts and enter your model number and you can view a diagram of the pump parts to help in disassembling it.
If the pump is not clogged then you have a problem with the impeller or motor. If this is the case you can replace the entire sump assembly just about as cheap as replacing individual parts of the pump.
Post back with any questions.
Thanks, Mike
Posted on Feb 16, 2008
  • 126 Answers
SOURCE: GE Nautilus GSD4200 Dishwasher will not wash/drain
The average life of a dishwasher is 7-10 years. The symptoms strongly indicate a motor pump problem and my personal opinion is if that is the case youd be better to put the money toward a new dishwasher.
Posted on Dec 30, 2008
DISHWASHER MODEL #WDF520PADW5 WHIRLPOOL IT FILLS TUB & GOES THROUGH CYCLES DRAINS DRIES BUT DOES NOT SPRAY WATER TO CLEAN DISHES
That is odd, you would think something would prevent it running if the pump had failed. Can you hear the pump running?
Check the filters if there are any protecting the pump, see if you can verify the impeller in the pump is turning. Make sure that the spray arms turn freely and that the holes are not blocked.
Jul 20, 2016 | Whirlpool Dishwashers
Fills with water then all leds flash no wash but will pump out
If the unit is filling up and pumping out water, as far as you can tell, but the lights and power to the control panel are not constant, then I would have a professional look at the control panel and timer because there seems to be a miscommunication.
Sep 13, 2012 | Electrolux Frigidaire Professional Series...
Whirlpool dishwasher wont wash
if the bottom tub is filling with water but not washing the issues is with the wash motor, some of this model use a start capacitor that can fail, if it has a capacitor on the side of the motor it may have failed but are difficult to diagnose but are cheap to replace so worth trying, if this doesn't help or if it doesn't have a capacitor then the fault is with the wash motor.
Mar 08, 2012 | Whirlpool Gold 24 in. Built-In Dishwasher...
I have a whirlpool Adp8540 that seems to go through the wash cycle completely but when we open it up the water has not gone through the spraying arms and the soap is a solid mass at the bottom of the...
It is likely the water circulation system is faulty. This dishwasher uses a single motor to run the water pump and the drain pump. If you hear the wash pump operate during wash cycle then it is likely there is a blockage in the water circulation manifold which distributes the water through the arms.
If you do not hear the pump operate during wash cycle then the sensor is faulty. The sensor tells dishwasher to switch to drain cycle from wash cycle.
Try following the diagrams at top of this website to get idea of parts.
Oct 13, 2011 | Dishwashers
Dishwasher fills and makes some sound but no water is sprayed. When canceled the pump drains the dish washer. Is there a separate pump that pumps during the wash cycle?
It could be that the jet holes in the rotor arms are blocked.
The arms are easy to remove so take them out and check out the jets.
Also take out the filter in the bottom of the machine and check that it is clear.
Sep 26, 2010 | Whirlpool 24 in. DU920QWD Built-in...
Why doesn't my detergent in dishwasher dissolve?
I've been having the same problem. It's a Sears Elite, made by Whirlpool. The problem gradually got worse until the dishwasher failed to wash at all. It runs through it's cycles and fills and drains, but the water isn't spraying. I am still in the process of fixing it, but it seems that the pump that sprays the water has failed. The motor runs, but the pump isn't pumping. I will be taking it apart to see if it's clogged or if the impeller is broken. Good luck with yours.
Apr 16, 2010 | Cascade 1400 Gph Pump
Whirlpool dishwasher has food particles baked on.
Heating element may fail. This will lead to the machine stopping part way through its cycle
Pumps. There are 2 pumps in most dishwashers. The drain pump,( which describes itself -it pumps the water out of the machine.)
The recirculating pump which forces the water at high pressure through the spray nozzles and arms. (This is how the cleaning action is performed)
These pump may either leak, or burn out. Either way, the only solution is replacement.
Mar 09, 2010 | Dishwashers
Dishwasher doesn't spray water after filling?
could be a blocked pump or capacitor fault,check if pump armature will move(centre rotating part)you may be able to view end of pump with lamp,there may also be a slot for a screwdriver to move armature,you will feel if there is something stuck,hope this helps
May 27, 2009 | Whirlpool DUL300 XTL Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Dishwasher will not go thru wash cycles
doy you hear any sound from either in the wash cycle
Feb 11, 2008 | Dishwashers
Dishwashers Logo
69 people viewed this question
Top Kelvinator Dishwashers Experts
P Scarbs
Level 1 Expert
paul
paul
Are you a Kelvinator Dishwasher Expert? Answer questions, earn points and help others
