Question about Panasonic Cameras
Panasonic DMX-lx2 Lumix When I turn the camera on "memory card full" appears and will not allow me to take a photo. I have checked both the memory card and built in memory and no valid picture to play appears. Help
    Genius:
  • 1,847 Answers
Take the batteries out and do a power recycle.
Posted on Aug 02, 2008
  • Legin Varghese
    Legin Varghese Aug 02, 2008
    Format both the internal and external memory and then try.
My Panasonic DMC-FZ20 says Memory Card Error.
Hi
Please check your cameras capability to support larger sized SD cards.It may not support those two SD cards.Also check for slide locks on the side of the cards and slide them to 'open' before inserting.
Hope it helps.Thanks!
Feb 18, 2012 | Panasonic Lumix DMC-FZ20 Digital Camera
MY CAMERA READS THIS MEMORY CARD IS PROTECTED
Look at your memory card. SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card.
Aug 08, 2011 | Panasonic Lumix DMC-LX2 Digital Camera
I bought a SDHC 4GB card and introduced in the camera. When turn on, came the message "memory error". What should I do?
Check your instructions, is a 4GB SDHC card compatible with your camera.
if you don't have a manual, just google "panasonic lumix dmc-fx01 manual" several options will appear.
Page 16 deals with card compatibility, it states that the maximum you can use is a 2GB Sd card, no mention of SDHC.
Nov 19, 2010 | Panasonic Lumix DMC-FX01 Digital Camera
I have an SD 4GB card which I used to use for my Canon digicam. Now, I would like to use it for my LX2 and the LX2 won't read the card. I have reformatted the card through my mac and the LX2 still won't...
When the error comes up onscreen you should still be able to access the review menu (where you look at your photos), just keep pressing the button for review. even though the error shows you should definitely still be able to format it in camera. Also double check the usual things - the card is unlocked and compatible with the LX2. Hope that helps.
Jul 25, 2010 | Panasonic Lumix DMC-LX2 Digital Camera
Memory card is locked, how do I unlock this?
Problems typically are pretty rare with Panasonic Lumix digital cameras. On those occasions where you do have an issue, though, look for an error message on the Panasonic camera for some clues as to how to fix the problem.
he seven tips listed here should help you troubleshoot your Panasonic camera error messages.
  1. Built-in Memory Error error message. If you see this error message with your Panasonic camera, the internal memory area of the camera is either full or corrupted. Try downloading photos from the internal memory. If the error message continues to appear, you may need to format the internal memory area.
  2. Memory Card Locked / Memory Card error message. Both of these error messages are related to the memory card, rather than the Panasonic camera. If you have an SD memory card, check the write protect switch on the side of the card. Slide the switch up to unlock the card. If the error message persists, it's possible the memory card is corrupted and needs to be formatted. It's also possible the memory card was formatted using another device that is not compatible with Panasonic's file structure system. Format the card with your Panasonic camera to fix the problem ... but keep in mind that formatting the card will erase any photos stored on it.
  3. No Additional Selections Can Be Made error message. If your Panasonic camera allows you to "save" photos as your "favorites," you may find this error message because the camera has a limited number of photos that can be labeled as favorites, usually 999 photos. You cannot mark another photo as a favorite until you remove the favorite label from one or more photos. This error message also may occur if you're trying to delete more than 999 photos at one time.
  4. No Valid Picture error message. This error message typically refers to a problem with the memory card. Most of the time, you'll find this error message when you try to play back images from the memory card and the memory card is corrupted, empty, broken, or has been formatted with another camera. To fix the memory card, you must format it, but formatting a memory card causes all photos stored on it to be lost. Try inserting the memory card in another device or in your computer and try downloading any photos stored on it before formatting it with your Panasonic camera.
  5. Please Turn Camera Off And Then On Again error message. At least this error message says "please." This error message most likely occurs when one of the parts of the camera's hardware is malfunctioning, usually a jammed lens housing. To try to fix this problem, start by turning the camera off for a few seconds before turning it back on. If this doesn't fix the problem, try resetting the camera by removing the battery and memory card from the camera for at least 10 minutes. Replace both items and then try turning the camera on again. If the lens housing is jamming as the lens moves through its zoom range, try gently cleaning the housing, removing any debris or grime. If all of these steps don't fix the problem, you'll probably need a repair center for the camera.
  6. This Battery Cannot Be Used error message. With this error message, you've either inserted a battery that's incompatible with your Panasonic camera or you've inserted a battery that has dirty contacts. Gently clean the metal contacts with a dry cloth. In addition, make sure the battery housing is free of debris. You sometimes may see this error message if you're using a battery that's not manufactured by Panasonic. If the third-party battery is working OK to power the camera, you probably can ignore this error message.
  7. This Picture Is Protected error message. You'll see this Panasonic camera error message when the photo you've selected has been protected from deletion. Try working through the camera's menus to figure out how to remove any protection labels for the photo files.
Keep in mind that different models of Lumix cameras may provide a different set of error messages than is shown here. If you are seeing Panasonic camera error messages that aren't listed here, check with the user guide for your model of Panasonic Lumix camera for a list of other error messages, or visit the Support area of the Panasonic Web site.
Jul 11, 2010 | Panasonic Cameras
This memory card is protected
Sometimes I get 'this memory card is protected warning'. It turned out that the lock on the left upper side of the SD memory card slipped down. The lock is tiny and gray on SanDisk.The lock suppose to be in upper position towards top.
You can download manual for FX-7 from Panasonic.
FX-7 and FX-8 are similar.
http://tinyurl.com/35m35xe
Jun 23, 2010 | Panasonic Lumix DMC-FX8 Digital Camera
A move corupted
this occasionally happens when the memory card writes the file with an error. A picture would be corrupted, this is appearently what happened to your movie. I not know of a way to save your movie. It is very likely lost.
Oct 24, 2009 | Panasonic Lumix DMC-LX2 Digital Camera
Panasonic Lumix DMC-LX2 error message
Try removing the card and re-inserting it was an intermittent issue with one card for me,the problem has now disappeared
Mar 17, 2008 | Panasonic Lumix DMC-LX2 Digital Camera
Cameras Logo
97 people viewed this question
Top Panasonic Cameras Experts
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
