Question about DataHand Professiona II (a20001000) Keyboard
Only green light goes on, can't shift into other modes. Originally, the cursor went crazy, wouldn't stop when or where I wanted it to, then, later, when I hit the letter "t" it would also type a "v", now the "v" key doesn't even work. I have my keyboard hooked up to an apple laptop. Is there a place where I may take or send it to get it fixed. I live in Upper Marlboro, MD 20772. All the phone numbers I have for Datahand's corporate office in AZ are disconnected. Thank you for any assistance you may give me. My phone number is 301/627=6535. Jonathan Duley
Speed odometer reading went crazy, later while in drive jerked as if to shift gears. 2000 Buick lesabre
Do you have an engine management light on dash if so use obd reader to scan fault.
Mar 15, 2016 | Buick Cars & Trucks
Audi A6 Brake Light & Beeping
think its a computer system issue-its all connectd these days-even with the steering--disconnect batt then put it back after a minute-may clear up--------if not pull plug at computer clean it and replug a few times-----these reboots at times work------but u mite need to run a thuro diagnostic to see different voltages-go to a good mechanic not a dealer--a hand held scanner will not do this
Nov 11, 2013 | 2005 Audi A6 3.2
My 2003 Neon Gages going crazy all dashboard lights are on
same thing happened to me, with a 2003 neon sxt..... but tranny went into error and wouldn't shift out of first til i reset the engine error, tranny and gages were fine (til it got cold). i had to warm the car up, reset the error to go anywhere. i was told it was the drivetrain computer. but i'm still checking other things.
Oct 14, 2009 | 2003 Dodge Neon
Speedometer just stopped working with no notice
If trans is still shifting its most likely a blown cluster fuse or bad cluster.If you have a check engine light & trans don't shift most likely blown trans fuse or trans vss (speedo) harness at right drive axle broken puple with white stripe wire or light green wire with black stripe
Sep 02, 2009 | 2005 Pontiac Sunfire
Car slipped out of DRIVE position only revving the RPM's.
Tranny low on fluid. When you stop or turn it all goes to one side causing the problems.
Jul 28, 2009 | 2003 Chrysler 300M
Philips plasma tv. has green line on left side of screen.
Using your TV's remote control press the right cursor button three times and it will adjust the Screen to the right and the green line will disappear. Use the left button if your green line is on the left.
Thanks to:
http://www.tivocommunity.com/tivo-vb/showthread.php?t=319984
Oct 16, 2008 | Philips 50PF7320A 50 in. Plasma HDTV
DataHand Professiona II (a20001000) Keyboard Logo
29 people viewed this question
Top DataHand Computers & Internet Experts
David Payne
David Payne
Are you a DataHand Computer and Internet Expert? Answer questions, earn points and help others
