Question about GE Heating & Cooling
Out side unit fan running but dont hear compressor
    Genius:
  • 1,033 Answers
Hello, the first thing to check would be the capacitor, if it looks bulged or discolord replace it. Also, discharge the capacitor with a insulated screwdriver and check it's microfard rating with a multimeter, take your meter leads to each terminal on the capacitor if don't get the proper microfarad rating that is printed on the capacitor then replace it. If you have a dual capacitor there will be a HERM, COMMON, FAN? In this case just check from HERM to common. If that checks out good and you have power to the compressor then most likely your compressor has failed electrically and should be replaced. Also check the contactor coil and make sure it is getting power on each side of it.
Posted on Mar 18, 2011
Samsung RF2178CBPX99. When do internal cooling fans cycle? Frenchdoor model. We have just reinstalled this unit. We dont hear internal or condensor fans running
When the compressor is running at least the freezer fan should be on and if not also the evaporator fan in the fresh food section should be running when it calls for cold air but basically anytime the compressor runs the fans should be running all of .them. a lot of times when there's a problem with the start relay and run capacitor on the compressor d external and internal fans will not come on what you need to do is find out if the compressor is getting hot and not running
Appliance 911 Sea Breeze
Oct 01, 2015 | Samsung Refrigerators
Refrigerator running and not getting cold
you may hear the condensor fan in the rear area and evaporator fan in the freezer compartment,but the compressor is not running due to a bad ptc overload/relay on the compressor body,unplug the unit,then on the left side of the compressor in the lower back side is the ptc,unplug it off the compressor and get a replacement,this is what helps start and operate the compressor
Oct 25, 2012 | Kenmore Refrigerators
Profile Arctica, Air flow fan runs but compressor dont kick in to make anything cold!
1. is light on in side when you open the door. If not check breakers or fuses.
2. Can you hear the compressor running. If not do you hear any clicking sounds.
3. If you hear clicking sounds, try putting a fan on compressor and unplug refrigerator.
4. Wait one hour.
5. plug back in. If compressor starts let it run and see if it cools, if it doesnt, call service man.
6. If it goes back to clicking, call a service man.
try this.
Feb 23, 2011 | GE Profile Arctica 25.4 Cubic Feet...
My compressor is running and cond. fan is running but freezer side nor fridge side will cool.
If the compressor is running their are 2 possibilities. The unit is low on freon or the crank broke and all you are hearing is motor in the compressor ruining.
Dec 28, 2010 | Refrigerators
RRUDD ACHIEVER 30, OUTSIDE FAN WON'T SPIN.
does the unit outside run at all,can you hear a humming noise or the compressor run or is it just dead.if you hear the comp. run or a humming noise then i would say it needs a new motor.but if you hear absolutely nothing out there,what i would do if you dont have a meter, is open panel on condenser and push the contacts in on the contactor when this is done its like jumpstarting the unit,it should all come on ,compressor and fan motor,if motor comes on then your contactor is bad (cost approx.$50.00) if it doesnot come on then its motor when replacing motor be sure to get a new capacitor with it (cost $80.00 to $120.00 plus cap 5mhz.$5.00 to $15.00) depends on where you get it home depo/menards/etc.high priced try granger or a local a/c distributor youll get it much cheaper.hope this helps
Sep 29, 2009 | Ruud UBHC Air Conditioner
Refrigerator and freezer both are not working. fan in back of unit running but internal fan not running. i also cannot hear the compressor kicking on.
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 23, 2009 | Maytag MSD2756G Side by Side Refrigerator
Outside A/C unit
you should be able to hear the compressor motor running. if you dont hear anything its more than likely ists a control problem. is the fan running inside?
Mar 15, 2009 | Ruud Handle Air Conditioner
Refrigerator not colling properly
Let it run until you have a problem again then look at the back wall of the inside of the freezer, if there is frost then it's not defrosting and that would be your problem (usually the defrost heater). If you don't see frost then you need to determine if the compressor is running or not. It's possible to hear the two fans run, but not the compressor. If the compressor is running, along with the 2 fans, then it is a sealed system problem and usually not worth fixing. If it's not running you'll need to check the compressor start relay on the side of the compressor. It is possible for a bad compressor to cause the relay to fail, so replacing it may or may not get you going again.
Jul 21, 2008 | Kenmore 53642 / 53644 Side by Side...
The unit is nolonger cold and ice is melting
i have the same problem as above. the lights are on in both the refrigarator and freezer. I do hear the motor (fan) running but there is nothing cooling coming out.
Feb 15, 2008 | Whirlpool ED5GTNXMQ Side by Side...
Heating & Cooling Logo
Top GE Heating & Cooling Experts
ray gallant
Lawrence Oravetz
richie46
Are you a GE Heating and Cooling Expert? Answer questions, earn points and help others
