Question about Kitchen Ranges
GE countertop microwave #JES1334SD001. When I shut the door the fan comes on (with no heat) and won't turn off until I open the door. Pressing "clear" button doesn't stop it. But heating/cooking works fine when programmed. Is this just a latch spring problem, or a Smart Board problem?
MicrowaveSvc
  • 9085 Answers
SOURCE: microwave seems to turn on when door latch is opened
What's happening is you are activating one door switch a little before the other, and that is causing your light, fan, and turntable to come on. The plastic parts are not perfectly rigid, so they flex a little when you press the button, and that causes the lag to be more apparent. Even if you press the door open faster and look really close, you may notice the light, fan, and turntable coming on for a split second. That's perfectly normal. The relay on the control board must also be turned on before it will actually be cooking.
Posted on Feb 23, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: GE spacemaker Profile XL1800 vent fan will not shut off
It may be a bad door switch, a loose door switch mount, or a problem on the control panel, such as a sticky relay.
I would suspect a sticky relay first, but the door switches should be checked.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, linked here on Fixya: http://tinyurl.com/yzjozk
If you need your control panel assembly (smart board) repaired, we do that for $39.95 nationwide.
You can find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
Posted on Dec 02, 2007
MicrowaveSvc
  • 9085 Answers
SOURCE: MIcrowave oven stopped heating - Whirlpool MH6150XMS
Generally, the most common causes of a failure to heat are:
- bad door switches or door switch mounts
- loose connection at the magnetron
- problem or loose connection on the control unit circuit board
- bad magnetron or other high voltage part (such as a shorted diode)
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
You can usually find helpful exploded view diagrams and order parts by entering your full model number here: http://tinyurl.com/gv383
There should also be a "mini-manual" hidden inside the unit behind the control panel, which is very helpful when troubleshooting.
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Mar 20, 2008
SOURCE: jenn air s136 stove won,t self clean
You've probably already read pages 34 through 37 of the owners manual for this oven. We had this stove in the house we bought and the owner wrote in his own directions, which seem to work fine:
1. Turn knob selector to clean.
2. Turn temp knob to clean.
3. Close and lock door.
4. Push enter button and turn dial clockwise to desired time.
5. Push enter button again.
You've probably already tried this, but just in case I figured I'd pass it along.
Posted on Mar 21, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here: http://tinyurl.com/yzjozk
We also have this full service manual at our site: http://www.microwavedisplay.com/R1480_R1481_R1482_sm.pdf
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
Posted on Apr 18, 2008
Why does the fan and turn table run when door is opened - ge microwave
I'd be AWFULLY NERVOUS about that - you don't know if the magnetron is also generating microwaves. If it IS, it can give you cataracts and/or blind you.
Aug 12, 2014 | GE Countertop Microwave Oven
How can I get the fan to turn off when the microwave is turned off?
Most GE over the range microwave ovens have a cavity heat thermostat. if the exhaust fan cut on due to external heat generated to oven, the fan will run until unit totally cools down. in this case unplug unit. Also fan can run if you have a broken door paw or if one of the door secondary switches is bad.
Aug 09, 2014 | GE SpaceMaker Microwave Ovens
My GE Profile Countertop Convection/Microwave Oven PEB1590DMBB Has stopped working.
It sounds like you may have a shorted cook relay on the control circuit board which can be repaired simply and inexpensively.
A YouTube video showing how to remove a typical over the range control panel assembly in under 5 minutes, is here.
Nov 30, 2012 | General Electric PEB1590DMBB: Profile 1.5...
Microwave light stays on and unit won't heat/run
If it's not heating at all, the magnetron is to blame.
May 26, 2012 | GE JVM1330BW/WW Microwave Oven
Oven won't shut off
One of the door switches is defective, caused by a build up of food particles or normal ware, to correct this a professional will need to identify the problem and replace it.
Mar 07, 2012 | GE Advantium 120 Convection/Microwave Oven
GE Spacesaver Microwave not heating, inside fan not working
I suggest you have the microwave oven replaced, the prices have dropped considerably for the last several years and you have got your money worth out of the unit.
Mar 02, 2012 | GE JVM1640 Microwave Oven
Won't heat or cook. Has power, light and clock work, Fan comes on when you push cook button but the carousel doesn't turn and it doesn't cook
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
jhfjk
Jun 29, 2010 | GE Countertop Microwave Oven
GE microwave won't turn off
Just checked the GE website. Had the same problem with my 5 year old microwave. GE website says to close and open the door quickly three times. First time I did this it didn't work. Second time I closed the door with some significant force and reopened it more quickly. Worked. Unplugged the microwave, plugged it back in, still fine.
Mar 21, 2009 | Microwave Ovens
Microwave Oven Problem
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP pad) is the primary cause of door switch failure. It's probably not actually heating with the door open, but better safe than sorry! If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info (as well as a text file which helps in diagnosing and repairing door switch problems) at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your full model number (without the suffix) here: http://tinyurl.com/gv383
Apr 10, 2007 | GE JEM25 Microwave Oven
Microwave seems to turn on when door latch is opened
Feb 22, 2007 | GE Spacemaker JVM1640SJ Microwave Oven
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
