My laptop wont connect to hub when wireless, says ip address wrong
  • 107 Answers
Try manually locating ip address to your laptop Right click on the local area connection icon and then click on Status, click on the properties this will help you to be able to Change the Local Area Connection Properties, Click on the Internet Protocol(TCP/IP) Click the properties button under then click on use this IP address provide the required IP address, Subnet mask and Default gateway and also click on use this DNS server address and then fill the field as necessary after try repairing the Local Area Connection.
Posted on Mar 18, 2011
How do i connect my WG302 to my laptop using a console cable?
if Windows
go to dosprompt on p.c or start run cmd <press the enter key>
type in ipconfig <press the enter key>
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ?
note the ip address of the laptop and the subnet mask
If the ip address is not 192.168.0.210 then go into the network settings and set the laptop up with 192.168.0.210 and then make it a static ip address.
was the ip address of the laptop 192.168.0.210 with a subnet of 255.255.255.0 ? (if not restart the laptop ) and check again
Next question how did you connect the wg302 directly to the laptop was it directly connected or was it through a network switch or network hub. Most likely the Cable router or DSL router has a DCHP server assigning different ip address lease range. You can either change the ip address of the access point device to one in the original current router lease range and assign it as static for the wireless access point device in the dchp lease table or assign the wireless access point with the second ip address as an example 10.0.0.2 and make sure the router dchp server allocates above 10.0.0.20 then temporarily connect router to laptop and temporily set laptop with 192.168.0.210 and then log into access point and change ip address to 10.0.0.2 for wireless access point device and turn off its dchp server. Then change laptop to use dhcp while connected into network hub or network switch with original router and restart laptop wired back into original normal network.
Dec 04, 2014 | NetGear WG302 802.11g ProSafe Wireless...
Belkin Wireless router
Is the laptop connected to the router wirelessly? because that can be the porblem if that laptop is not connected wirelessly it wont be working, so make sure that the laptop is connected to your wireless network...
Hope that helps..............
Sep 03, 2008 | Arris Wireless G Broadband Router (wr850g)
My hp laptop had its memory wiped back to factory specs how do i give it a valid ip address so it can connect to my homenet 4a4e wireless
Check your router and confirm ip adress, and type manual ip adress on your wireless network connection properties in your computer.
Apr 13, 2012 | Computers & Internet
My lap top wont conect wirerless for my super hub but dose with cable in
check your laptop if their is button of wireless being switch on or in the keyboard. Also check your laptop is the wireless driver properly installed. The reason why you cannot connect due to none visibility of the network. Could you also set an IP address of your laptop if you have set your wired connection into IP. Hope it helps thanks.
Sep 25, 2011 | Computers & Internet
Laptop won't connect to wireless internet
wat is the Ip address
default gateway
????? Fast reply needed for a quicker resolution
Mar 18, 2010 | Google Chrome
Have 1 desktop and laptop connected to router ans i bought a new laptop .. and it wont work with my wireless belkin router what am i doing wrong?
check whether driver for wireless is installed properly in the laptop .To check it navigate the device manager and see device wireless is installed.
The wireless may be sometimes disabled ensure it is enabled.
Then try to search for the wireless signal and connect to it.
Ensure correct ip address is received automatically in laptop by using command ipconfig/all in command prompt
check router dhcp address range.
Mar 03, 2010 | Belkin (F5D8231-4) Wireless Router...
Belkin Wireless 5-Port Hub (F5L009) Problem
If you set the allowed IP address in the security section of the router then you must fix your computer IP to 192.168.1.101 with a subnet mask of 255.255.255.0 the default gateway should still be 192.168.1.1 and when you get in delete the security locking out all but the one address. Good Luck
Sep 03, 2009 | Belkin Wireless USB Hub
I CANT GET CONNECTED TO BT HUB
have you typed the key exactly? viz uppercase/lowercase. The switch(hub) might have MAC address filtering on. also check if the switch(hub) has a DHCP running, which allocates IP addresses, if not you need to set your wireless connections IP address within the same range as the switch. If all else fails attempt to connect the switch via a utp network cable which should have been suplied with the switch(hub) so you can access the switch and make the necessary changes... email me on djtracer@vodamail.co.za should you need more info.
Aug 11, 2009 | Computers & Internet
Wireless connection problem
BT is right, the fault is at your end, because you can connect to the Internet with an ethernet cable.
You have lost your wireless connection with the wireless hub.
This could be low signal strength (especially if the wireless access point is in one part of the house and your laptop is in another room)
OR Your laptop wireless card has lost its wireless access configuration.
Check your laptop wireless configuration, check your signal strength, check your SSID, check your security (WEP or WAP),
Have you got MAC address filtering.
Go to control panel, click on network connections, right click on Wireless Network, Click on repair (might fix your connection problem), Else right click on Status (should give you indication of how your wireless is functioning or not functioning).
Check your TCP/IP settings is set for "Obtain an IP address automatically"
Without more information it is difficult to identify exactly what is wrong with your connection.
May 11, 2008 | Acer Aspire 5100 Notebook
I have an ethernet hub to which my dsl modem is connected. I also have two computers on this hub so I can access the internet on both PCs. I am trying to also connect a belkin wireless access point to the...
You should try to upgrade to a router. The main differences between a router and a hub is a router has a microcontroller and a hub does not. The router can operate at something called a full duplex which means it can send and receive data at the same time, it will also come with an additional IP address, possibly your internet service provider will only allow a limited number of IP addresses per one line. First unplug another connection and then try your X-box connection.
Mar 25, 2008 | Computers & Internet
Computers & Internet Logo
93 people viewed this question
David Payne
David Payne
