Question about Tower Heating & Cooling
How to fit a TOWER STT RSA T40 room thermostat when conected it cuts out but wont come back on
Conection error and call drop, changed my sim card, are hinges related to network conection
fthis solution helpful/useful for you please rate the solution. THANKS FOR USINGFIXYA. Wait for the device to start up completely
May 22, 2011 | Nokia E90 Smartphone
Cutting old johnson 3/4 steel pipe. Need conection, to enable conection to new blue pipe
the best option is to follow the steel pipe back to the next threaded fitting. Then install an adapter to convert to the plastic.
Sep 16, 2010 | Johnson Plumbing
55 cup farberware coffee urn.
A burn out element it means the two ends with the ohm meter should read infinity number or nothing depents from ohm meter in any case you should read that the two ends are open circuit somewhere the internal wire is cut off. As for the thermostat you should conect the two points where the lement is conected and turn the thermostat if you seen at onhmeter that aroud room temperature the themostat open and then if you rotate it reverse just litle bit and the theremostat close then the thermostat works fine. Youcan even here and small click when it open and close during the turning left and then right at the point of room temeperature.
Good luck.
Remember top vote for this answer
Mar 09, 2010 | Coffee Makers & Espresso Machines
I have bought a replacement main oven Thermostat for a tricity bendix Town & Country Mod no SIE459TCGR the conections on the replacement thermostat 46THC15/F5G1E2 are different from the original can...
Hi.
This is an universal replacement part, that is the reason why it is different from your TB original part.
The thermostat should have the temperature probe already attached.
Fit temperature probe and thermostat, then connect the element (s) wires on one side of the thermostat. The order in which you connect element polarity to thermostat does not matter. The thermostat will cut off power to element when the specific temperature is being reached by the temperature probe.
Dec 12, 2009 | Ovens
Im fitting a 1200 x 800 shower tray but having problems getting old one out same size,its in an en-suite, tray just a bit longer than room, dont want to break tiles thats in cant replace them any ideas
well if the old one wont come out,,, then the new one wont go in,,,as its the same size,,, looks like you will need to risk them tiles to me, even if you cut the old one out, you cant cut the new one back in can you?
so its back to them tiles, go on, risk it!!!
Oct 23, 2009 | Dreamline SHOWER ENCLOSURE TRAY Right...
IBM T40 2373 display cuts off.
When it cuts out can you still see the display very faintly or does it just go completely black?
Mar 10, 2009 | IBM ThinkPad T40 2373 Notebook
My tv doest work properly em Brazil
HI,
I'll think youve got a different PAL system in Brazil.
Brazil has PAL-M en RSA PAL.
regards,
Gerard
Oct 30, 2008 | Hisense TA42P40M 42 in. Plasma Television
Heating & Cooling Logo
81 people viewed this question
Top Tower Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
Are you a Tower Heating and Cooling Expert? Answer questions, earn points and help others
