I can;t go online with my router. says the IP conflict
    Problem Solver:
  • 5 Answers
Go to start menu..CONTROL PANEL. open network connections.
then right click to your local connection that indicate with yellow exclamation point..
then repair..
if you use manual ip address try
then this time properties...
double click INTERNET PROTOCOL(TCP/IP) then select "obtain an IP address automatically"
and "obtain DNS server address automatically...
Posted on Mar 19, 2011
How to resolve Belkin N150 conflicting with Linksys WRT54G
Both the routers are having the same default IP addresses that's why they are conflicting.
Put only one router in the switch connected the a PC on the same LAN.
Open your browser and put the default IP address (like for most of the routers 192.168.1.1 or 192.168.0.1), hit enter and give the login ID and password (in most of the cases, admin/password orv admin/admin), go t configuration> IP settings> Static IP Mode> Change the IP from 192.168.x.1 to 192.168.x.2 (or any other other number except 1 and <254).
Save and reboot.
Now enjoy both routers plugged in simultaneously in the same LAN. :)
Sep 03, 2012 | Belkin Basic Wireless Router
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
I want to use it as an wireless access point . It is connected to another router by cable. Pls help how to do it
The main thing to remember when doing this is to make sure that each of the routers have a DIFFERENT IP ADDRESS! If they do not it will not work. You can use one as 192.168.1.1 and one as 192.168.0.1 . This will resolve a IP conflict that will happen from default settings. Once this is done it will do the rest. All you have to do is disconnect each router from each other, reset them one my one and connect to each one individually with a cable and change the IP addresses to ensure that when they are connected together their is no conflict. When you hook them to the cable modem, you will need to connect the modem up first and make sure its online, then one router and wait 30 seconds and then the 2nd one. There you go... DONE!
Feedback appreciated!
Jan 28, 2011 | Computers & Internet
I have a message that say Ip address conflict, what can I do
I can't get my wireless g broadband router to work with my dsl speedstream 5100 modem i can connect to internet when my ethernet cable goes from my xp pc or my mac osx desktop directly to the dsl...
make sure that there is no IP conflict with the two devices. speedstream and wireless G. if both of them have same IP gateway you have to change the IP either one of them for you to have a connection.
Apr 04, 2010 | Linksys Wireless-G WRT54G Router
IP address conflicting
Have you checked to see if either computer has a static IP address? that might conflict with the DHCP table.
Jun 27, 2009 | Belkin (F5D7230-4) Router (587009)
Home computer on same network can't be online at same time.
If you set static IP in your computer change the last number of your static IP address in your TCP/IP setting of your LAN. The two unit shouldn't have the same IP address say 192.168.1.5 the other shall be 192.168.1.25 or don't use the router's default utility page IP address.
Jun 11, 2009 | Belkin (F5D8231-4) Wireless Router...
Shared wireless connection between laptop and PS3
Hi philly - If this fixes your problem please rate as fixed. PLEASE wait til your fixed. Are you runnimg your pc wired? Check to make sure that your IP connection is set to obtain ip automatically and obtain DNS server automatically. What's your operating system please/ Thanks.
Jeff
May 17, 2008 | Linksys Wireless-G WRT54G Router
Router
Before you can get online through the router all you need to do is change the Linksys router's IP address. Because the westell and the linksys has the same range of IP address that creates a conflict on your network that's why you can't get online.
First login to the setup page of your linksys router.
  1. Under the Setup Tab (this is the first screen that you will see after typing in the linksys router's password.) make sure that the Internet connection type is set to Automatic Configuration- DHCP, Then on the same page look for router IP address or LAN IP address. By default its 192.168.1.1, you need to change it to 192.168.2.1. And hit save settings. You will get disconnected from the linksys page, that is normal. If you want to log back in to the router page you use the new address of your linksys (192.168.2.1).
  2. Now you restart your computer to refresh the connection and that should get you online.
Just reply to my post to let me know if your done doing this. We will setup the wireless after we make sure that you can get online wired to the router.
May 13, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Cannot connect with ATT modem
Connect your pc to the ATT box. If online, check the ip address of the computer. If the ip address is 192.168.1.x, then you just have to change the router ip address. The wrt54g ip is 192.168.1.1, it may be having conflict with the ATT modem. Change the wrt54g ip to 192.168.2.1
Good Luck
Mar 05, 2008 | Linksys Wireless-G WRT54G Router
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
