Question about Sony Handycam DCR-TRV9 Mini DV Digital Camcorder
Parallel gray lines on display - Sony Handycam DCR-TRV9 Mini DV Digital Camcorder
    Genius:
  • 1,812 Answers
This is usually caused by an oxidized or defective Audio/Video drum. You can try running a cleaning tape through the camera. If this does not solve the problem the camera will need to be serviced by a qualified service technician.
My name is Rick and I'm a professional repair technician with over 20 years in the business and have repaired many of these. I'm semi retired and work from home with little overhead so I can keep repair costs low. If you decide to have the camera repaired, please click HERE for a directory listing that suits your needs.
If this response has been of any help to you, please be sure and give a positive vote for me on FixYa.com .
Posted on Mar 18, 2011
Phone not working
Hi Pam,
Try these..1...remove your telephone line from base unit and fix it into a working land phone and check whether is it having normal dial tone.If it's having engage tone(beep beep...)remove paralleled phones and re connect to cordless base unit.
2.If line is ok (normal dial tone with full volume) & still display indicates line is busy, your main base unit must be having faulty components inside.Commonly these defects happen in thundering or surges through telephone lines.You have to take full set to a repair shop.
Rana.
Dec 28, 2013 | Gigaset As300 Twin Dect Cordless Phone -...
Error badint 0085ddc0
The 'badint' error on the T6100 indicates the printers firmware has for some reason 'crashed', this error should not be seen in normal operation of the printer.
One common cause of "BADINT" messages is the use of an external print server or host computer with incompatible parallel-port settings. If you have an external print server connected to the printer's parallel port there is a setting on the print parallel interface that may need changing, to change parallel interface setting. • Set the printer to Offline. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access On) • Press the Mode key: display will show Offline Normal. • Press any Arrow key until display shows Offline Config. • Press the Forms/1 key. • Press any Arrow key until display shows Config Paralel. • Press the CPI/2 key. • Press any Arrow key until display shows Paralel Bi-Dir. • Press the LPI/3 key. • Press any Arrow key until display shows Bi-Dir Off. • Press the Enter key and the interface will be set. • Press the Clear key. • Press the Enter and LF keys together for approx 3 - 4 seconds. The alarm will sound. (Tech Access Off) On the external Print Server, you need to ensure that the unit is also set for Uni-directional working.
Nov 04, 2011 | Tally Line Matrix T6100 Printer
What does "parallel set on"
helo, check and make sure other phone is not on, looks like it saying that the line is tied up by other phone . If you only have one phone, try disconnecting base from power and remove battery from phone. hope this helps
Jan 28, 2011 | Computers & Internet
Display has lines and is gray
This is known problem of ccd imager chip failure in Canon A95 and ccd imager chip will be replaced to fix the issue.
Local camera repair shop will help you because camera will take apart in detail and soldering work is also involved.
Thanks.
Jul 13, 2010 | Canon PowerShot A95 Digital Camera
Power is on to my Canon Pixma MP780, but no display
I got such problem on my MP 780 (grayed boxes on bottom LCD line, no function). It turned out to be missing 1.5V for CPU core. On revese (solder) side of mainboard i found point described as "1.5V". I've powered this from external supply (took about 2 amperes) for few seconds and MP is alive again (without external supply).
Jun 06, 2010 | Canon PIXMA MP780 All-In-One InkJet...
Gray Stripes displayed when playing video
I am having the same problem with a Sony Digital 8, When I hit play I see blue screen buy when I press play and fast foward I see the same gray scan lines> Did you have a stuck tape or problems ejecting tape? I think it is more than cleaning the heads. When I try to record it indicates no tape in camera.
Apr 25, 2009 | Canon DC210 DVD Camcorder
Lines on page
The effecds like 'banding' very often this happens when the ink is running low.
When you say 'full color' do you mean at the 'best' [i.e. most ink used] setting or the you are printing the image on a full sheet of paper?
How do your images appear when you print small, say wallet sized, single image only on the page? draft mode? Gray scale?
Jul 16, 2008 | Canon PIXMA iP3000 InkJet Photo Printer
LCD Display - Gray Shades/Lines
1ST OF ALL U SHOULD CHECK UR CPU WITH ANY OTHER MONIOR IF IT WORKS OK THEN BUY 256MB XFX 3GP CARD
Dec 14, 2007 | Gateway GeForce2 NV15, (64 MB) Graphic...
Sony Handycam DCR-TRV9 Mini DV Digital Camcorder Logo
66 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
