Question about Logitech Harmony 1000 LCD Touchscreen Remote Control
My screen is discolored where it got wet. Can it be taken apart and cleaned?
Fixing loose parts on led lcd tv.
All your thinking might not be true. You can think whatever you like. But; all of it are not valuable in case of an LCD TV.
Thing further. Then think it over again and again. Sit back at ease, and continue thinking.
Come here to this forum, after thinking has been over. OK?
Aug 08, 2016 | Televison & Video
Turns on and then shuts off
there is a self reseting thermal cut out sensing motor temperature. The motor is overheating due to lack of ventilation, probably obstructed by dust and stuff. Vac needs to be taken apart and cleaned to make sure.
Apr 24, 2015 | Bosch 3931B-SPB Airsweep 6.6 Gallon...
Hr 42 stuck slide.
Sounds like you still have some kind of fastener in there. Be careful. It also sounds like the slide is exposed and perhaps what ever it is covering can't be fully seen. I would try to google an exploded view. If you can't find one see if you can buy a new carburetor kit. if you have taken it all apart you should replace all the gaskets and "O"rings anyway, even if the carb was never installed. Are you using carburetor cleaner? if you are you may have caused some of the O rings to swell. A new carburetor kit will come with a detailed exploded view. If there is something holding it, you will be able to see it.
Best of luck
Ray
Apr 28, 2014 | 2000 Harley Davidson FLSTC Heritage...
I have a dyson animal d17 i have taken apart completly and cleaned all filters and clogs and i still have little to no suction and wont turn on in the upright position
With no suction you should check the venturis. They can become clogged if you suck up wet dust, wet cat litter, etc. You\'ll need a Torx Screwdriver to get it apart. See where that gets you.
Jan 07, 2014 | Dyson DC14 All Floors Upright Vacuum...
Ipod touch 16g got wet touch screen not working
Put it in a bag of uncooked rice. Leave it there for a few days. This will hopefully dry it out. If not, you'll need to have it taken apart to clean and reseat cables.
Nov 18, 2012 | Audio Players & Recorders
I have a Bissell ProHeat Turbo 2x Carpet cleaner.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
tiutiu
Jan 10, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
I have a 50 in projection tv, how do i know if im light engine is bad or maybe its just my projection bulb thats bad? i have 2 dark spots on the top corners and some discolor on the top half of the screen....
Okay - now we are geting somewhere - This is an LCD rear screen projection Sony TV.
A few things to consider:
1) Is it in an fairly cleanly or dusty environment.
2) How long have you had it - how old is it?
3) Has it ever been taken apart and the output lens been cleaned ?
'large dust build up causes the dark spotsin the corners possibly'.
Here is the issue on LCD projection
a) If the lamp has an incredible amount of hours on it then it gets extremely hot and will damage the Polarizer and Analyzer filters 'your discoloring issue' and then harms the LCD panel 'not good'.
Ways to check your lamp - pull it out. If you look into the reflector and at the lamp element 'bulb' is there a lot of white build up? If there is, this is carbon build up. If there is any deformity to the lamp's nice and eliptical Bulb element or dark areas. Replace it.
Hope this all helps.
Blessings,
A/V Media Guy
Nov 23, 2009 | Office Equipment & Supplies
Wont start,was runing two days ago,have fresh gas,checked plug
Your carberator should be taken apart and cleaned with carb cleaner or solvent for at least an hour. Also check that your fuel hose isn't kinked. If your plug is not wet, then that means it isn't getting any gas to cylinder.
May 09, 2009 | Poulan 25cc 2-Cycle Gas Powered String...
Bug stuck in tv
NEEDS TO BE TAKEN APART BY A PROFFESSIONAL IT IS EASY TO BREAK THE PLASMA SCREEN IF NOT TAKEN APART CORRECTLY, THEN THE INSIDE GLASS CAN BE CLEANED
Dec 02, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
LUMINOX DEAD IN THE WATER!!!
No real way to clean it yourself, you need to take it to a professional who can diassemble it, clean it then reseal...unfortunately that takes tools and the knowledge...dont try at home, if its gotten wet, it WILL need to be taken apart and worked on.
Mar 14, 2008 | Navy Seal Luminox Watch
Logitech Harmony 1000 LCD Touchscreen Remote Control Logo
133 people viewed this question
Top Logitech Televison & Video Experts
Jerry Umali
cwradio73
Are you a Logitech Televison and Video Expert? Answer questions, earn points and help others
