I have a hp slimline 3100. the cpu fan runs fast everytime i open a program or play a cd. it speeds up the slows down. sometimes it runs really fast, then the computer shuts down. whats going on?
Also clean the old heat sink compound off both the CPU and heat sink and apply new compound. Radio Shack 276-1372 less than $3. It worked on mine now the fan doesn't even need to turn on.
Posted on Mar 25, 2011
  • 917 Answers
This is an indication of overheating within the PC. Open the PC case and clean all the air vents. Take the heatsink and fan off the CPU and give it them a good clean. Put the heatsink and fan back on to the CPU and start up the PC. check that the fan on the heatsink is running smoothly.
Also, make sure the vents on the power supply are clear and the fan on the power supply runs well.
If you go into the BIOS setup, you may be able to monitor the fan and the CPU temperature.
Posted on Mar 18, 2011
Fan runs hard computer is slow hp compaq nc6000
- Stop Overclocking your CPU.
- Make sure your Heat Sink is placed properly above the processor.
- Clean the Processor fan, Heat Sink and other peripherals.
- Use High Speed fans.
- Use CPU Heat Sink Paste in the processor.
- Fix OS registry with reliable program like I always use Reginout.
- Shut down your computer at least two hour a day.
Hope these tips will help.
Jan 05, 2014 | HP Compaq 6735s Notebook
CPU fan running at constant full speed
Seems like you cpu is running hot and therefore triggering the fan to spin fast in order to keep the temp low. You can monitor the cpu temp buy downloading this programs and see its really the cpu thats overheating. http://www.techpowerup.com/realtemp/
Sep 07, 2011 | Dell OptiPlex 330 Desktop Desktop Computer...
Hi, how to switch off HP Proliant DL320 G2 server fans? In Normal fans speed and noise
The fans are essential to the cooling of the processors and everything else in there, if they are running fast then usually that means your processor is overworked. I'd go for a fresh operating system if you can.
The fans should come on really fast when its first turned on, then slow down after a few minutes.
Oct 29, 2010 | HP ProLiant DL320 G2 Server
My PS2 will play only some DVD movies fine. It does the same with PS2 games. Seems like they have removed something that the older, larger PS2s had that allowed them to read DVDs more deeply and play...
Hi there Mike,
The only possible reason for your problem, since your slimline ps2 is STILL reading them (but just a little slow sometimes), is because the lens could hardly read your discs due to dust build up. Try cleaning it using a disc cleaner and letting it spin for like 30 seconds. If this does not fix the issue, then you may have to MANUALLY clean the lens. Open the cover and once you see the lens, get a clean swab or qtip and damp it in an alcohol and gently wipe the lens in a circular manner. Then let it dry and try to play those discs again.
Please let me know how this goes. Thank you for using FixYa.
Oct 25, 2010 | Sony PlayStation 2 Slimline Console
Hp slimline cooling fan is always running
there is not really an answer for this question.
your machine has fan o fans running all times to avoid the CPU from over heating and BURNING, you see how compact it is. consider this. how much heat will come from the CPU, hard drive, GPU, RAM sticks and cd/dvd drive, ahve them all working and not cooling system at all your pc will overheat in less than 20 minutes.
Oct 07, 2009 | Computers & Internet
There are some days when this computer works slow
Possible antivirus or windows updates. They usually run in the background so you wouldn't notice when they are running an update. This is especially the case with Windows. It will slow down the internet speed as well as the Pc itself until it is complete. Apart from that, You may have other programs that automatically run without your knowledge which also update. If the probem gets worse, you may want to download an anti spyware program to check for malware that your antivirus software doesn't catch. Best of luck and hope I've answered your question.
Greg
Jul 09, 2009 | HP Pavilion Slimline s3407c Desktop,...
Want to increase the speed of my pc
Hello alanwemple,
Increasing the RAM is surely a good first step to speeding your computer up some. It was my impression that the a340n supports a total of 4GB, so you might want to recheck your manual. And 4GB would certainly be better than 2. As for the CPU, it's upgradeable on this machine, it uses a "Socket 478" chip. Simply remove the old one and insert a new one. But, the CPU is probably not contributing that much to your slowness problem.
Two things that I'd look at first, before I tackled the CPU is video performance and the hard drive. A faster video card with more video RAM can substantially speed things up. And, the hard drive may need some maintenance, starting with defrag. You may also want to do a disk cleanup and while you are at it, run a full virus check and malware detection program such as MacAfee or Norton to make absolutely sure that no bad stuff is slowing you down. And these are cheaper than replacing the CPU.
Hope this helps.
Apr 07, 2009 | HP Pavilion a340n (DQ099AABA) PC Desktop
Cd/dvd burner too slow
It may just be that that is the speed of your drive.  See if it says on the drive how fast it is.  If it is too slow, then you may want to consider getting a newer, faster drive.
Feb 03, 2009 | Dell Dimension 3100 PC Desktop
My Sager laptop is running a program called VirtualDJ. This program runs videos. The computer's CPU is heating up to 95C in an hour and shutting down. How can I stop this. I had put a fan blowing air...
no there is no problum with your software . i think this is problum with your cpu fan. it is jaam or it is very slow. ple chack fan of Cpu is moving its normal speed.
if u can open ur laptop ple lubricate ur cpu fan
Jun 03, 2008 | Computers & Internet
CPU fan races
thanks bigunit12 - as I suspected, no real concern
expect the noise is a pain.
I do think the HS might be marginal and so I shall replace sometime with a higher capacity model, also maybe increase fan flow capacity and add a case hot air extractor fan.
Just to make sure
Jan 07, 2008 | E-Machines T5048 (7136) PC Desktop
Computers & Internet Logo
294 people viewed this question
David Payne
David Payne
