At times on my television the right speaker cuts out and then suddenly the sound is back. i have put my setting to dolby pro logic 3d phonic as originally it was just dolby pro logic. i have no external speakers. will this resolve the problem
  • andydebsb98 Mar 19, 2011
    sorry about that - the model number is av-32wfr1ek. as i say it is intermittent and last night it was ok. the funny thing is that it is always ok in the daytime and only happens very briefly at night. how much do you think it would cost to repair?
  • andydebsb98 Mar 20, 2011
    thank you so much for your advise, much appreciated. i will not poke about with it!! last night it seemed fine so i dont know. should i leave the setting on dolby pro logic 3d phonic. i have no stereo or amplifiers so i cant connect speakers. thank you so much
  • 917 Answers
It is most likely to be a hardware problem, probably a bad connection at the speaker. If it is within the speaker you will need to replace the speaker.
Posted on Mar 18, 2011
  • 4 more comments
  • andydebsb98 Mar 18, 2011
    thank you. is it repairable and will it cost a lot of money. can it be done in home as its very very heavy to move! the tv is 10 years old but other than nthat it works perfect
  • Raj Patel Mar 18, 2011
    You've not posted a model number so I can't give specific advice but it should be possible to take the back off the TV reasonably easily. Make sur the power cord is disconnected first. I would advise trying to swap the left
  • Raj Patel Mar 19, 2011
    This is a CRT type TV with one centre speaker and left
    This is a CRT type TV with one centre speaker and left and right speakers each consisting of a 10cm main speaker and 3.5cm tweeter. It may be a bad connection on the coil of the right-hand 10cm speaker.
    The Dolby Pro Logic setting you were using was driving the left and right TV speakers in stereo mode, with surround sound audio going out via external surround speaker outputs.
    Your current setting of 3D Phonic makes the left and right speakers the same as the centre speaker and you loose the stereo audio. This then has to be added by connecting an amplifier and speakers to the phono audio outputs. The surround sound is still provided by the surround sound speaker outputs.
    If you don't want to get the TV repaired you could just connect a pair of amplified speakers to the phono outputs for the left and right stereo audio and leave the setting at 3D Phonic.
    If you want it repaired then unless you have electronics experience and have worked on CRT TVs before, I would recommend getting a professional TV repair shop to do it. A replacement speaker should not be too expensive since 10cm round speakers are readily available.
    DO NOT poke around inside the TV if you have no experience because CRT TVs can be dangerous even with the power disconnected.
UNABLE TO POWER UP
Check for a bad fuse inside the receiver.
Jun 20, 2015 | Yamaha AVENTAGE RX-A1030 3D A/V Receiver -...
Delayed Sound from Center Speaker
Go to this website, make an account, go to support, help center. Thenfollow the instructions and you might get your answer.
Hope this helps. :)
Jan 21, 2008 | NAD T762 Receiver
I have a buzzing coming from my suuround sound speakers
Check to make sure your audio cables aren't touching any power cables. This will ensurethat you aren't getting signal interruption from latent overflow. Next, make sure you volume levels are correct. You could be overdriving the channel with too much output. Finally, make sure your speakers and/or source aren't next to anything with a strong radiation signal such as a transmitting device (2.4 GHz phone or microwave). Let me know if you've verified this and then we'll troubleshoot further. This sounds like interference to me.
Jan 02, 2015 | Onkyo HT-R2295 3D Ready A/V Receiver - 7.1...
All the speaker outlets seem to work fine, except the fronts, all will work, but if i plug the fronts in, all the sound then tends to just fade away, and then i have nothing, no sound. i can't figure...
I would:
1- First make sure you are properly testing using a reliable source, such as a CD Player or itunes. 2- Make sure the Listening Preset is not on Dolby Pro Logic. Make sure it is on Stereo mode and see if the problem persists.
What usually happens is that when listening to 2ch (Left and Right) Audio such as Television or Music and Dolby Pro Logic is on as a preset, Dolby Pro Logic analyzes both Stereo tracks, tries to detect the voices (center channel), ambient sounds (surround and fronts) and processes the signals into a 5.1 or 6.1 System. You tend to get a fading effect when Dolby Pro Logic is selected and listening to an old VHS, DVD or even music.
To remove a preset, make sure you select the Stereo button at the bottom left of the remote to pan through the options.
Hope this helps
Jul 21, 2011 | Harman Kardon AVR 230 6.1 Channels...
We hooked it up and have no sound
From the Console Settings screen in the System area of the Xbox Dashboard, you can configure the video output of your Xbox 360 console for a widescreen, high-definition TV, determine your audio options, and check your console's serial number and Xbox Dashboard version.
Go to correct section for ... Audio
Change your audio output settings for games from this screen. These audio settings do not affect DVD movie playback. For DVD audio settings, refer to an individual DVD movie's setup screen.
Settings consist of:
  • Analog Output Settings: choose Mono to merge the left and right audio signals so that you can hear all sound through a connection to a monaural TV or monitor; choose Dolby Pro Logic II to listen in normal stereo (no audio surround receiver required) or to listen to Dolby Pro Logic or Dolby Pro Logic II soundtracks from compatible games or other media.
    Dolby Pro Logic consists of four channels of audio: front left/center/right and a monaural surround channel that is mirrored in each of your rear left/right speakers. Dolby Pro Logic II uses digital signal processing to generate 5.0 audio (front left/center/right, rear left/right) from any stereo (left/right) programming, whether from movies, music, or games. Unlike movies and music, however, games are specially encoded with Dolby Pro Logic II decoding in mind.
    To listen in either Dolby Pro Logic or Dolby Pro Logic II surround sound, you must connect your cable's left/right (white/red) RCA connectors to a compatible surround receiver. For more information, see our connection page for the cable you're using:
  • Digital Output Settings: configure this setting only if you'll be using the Toslink optical digital-audio output from a compatible Xbox 360 AV cable (optical digital-audio cable sold separately):
    The default digital-audio setting is Dolby Digital 5.1. If this is your preference, you do not have to make a selection from this screen.
May 13, 2011 | Microsoft Xbox 360 Console
The audio keeps going in and out and cuts off. Also I have other devices going into aux in but it doesn't show 5.1 surround it only shows the front L, Front R, and CT speakers in stereo. I want everything...
If you are playing a source that is Stereo such as FM Radio or a CD the sound will not use all 5.1 speakers unless you enable the correct Surround Mode. On the remote there is a button on the lower right of the remote that says SURROUND. You can toggle through the various surround modes with this button the mode you want is Dolby Pro Logic The Pro Logic mode uses the built-in circuit to steer the Left, Center, Right and Mono Surround channel audio signals and uses all five speakers to play both stereo and Dolby Pro Logic program source, such as TV and VCR. You can use this mode with any stereo program source (such as VCR/TV) to enjoy multi-channel sound experience.
Mar 02, 2011 | RCA RTD317W Theater System
Cant get sound from right and left rear speakers
Your source will determine the Dolby Digital capabilities. WHAT is on video 1 and is it Dolby Digital?
Jul 04, 2010 | Kenwood VR-407 Receiver
Kenwood 107VR rec and No vol from Sub Output w/ menu Opt On
In the setup menu are the speakers set to large or small? On some receivers if you have it set to large all the bass is directed to the right-left fronts.
On my pioneer receiver if the speakers are set to large the sub-pre-out only works if the receiver is in a surround mode, if its in stereo mode and the speakers are set to large the sub-pre-out is dead. If the speakers are set to small the sub-pre-out works all the time.
Also, some receivers won't send a signal to the sub-pre-out if there is no LFE discreet signal info from the dolby digital or dts bitstreem.
For example I have several older dvd's that light up the L C R SL SR icons on my receiver, but don't light up the LFE icon. I have other older dvd's that just light up the L and R icons meaning they are only recorded in stereo like a vhs tape recorded in dolby surround.
In my basement I also have a kenwood dolby digital receiver.
I've noticed that when a dvd only lights up the left and right icons the pioneer will automatically switch to dolby pro logic surround. The kenwood will only send the signal to the left and right fronts (stereo). If I manually switch it (kenwood) to dolby pro logic I'll get sound from all the speakers just like the pioneer, but it does'nt do it by itself.
Most receivers that have a tape monitor won't work in surround mode with the tape monitor on. The pioneer will let me use the tape monitor with dolby pro-logic but won't pass through a dolby digital signal with the monitor on.
Hope this helps.
Apr 18, 2010 | Kenwood 107VR
Not getting true surround sound
The only way to get Dolby 5.1 audio out of the Xbox will be via fiber optic cable from the Xbox to a Dolby Digital amplifier - which will output a decoded 5.1 signal to a 6 channel amplifier and 5 speakers and one sub-woofer. I doubt the Logitech speaker system has a Dolby 5.1 decoder built in with the amplifier for under $100, but I can't say for sure. If the Logitech has a an optical (or TOSLink) input, connect it to the Xbox and follow the instructions below.
To configure your audio settings, follow these steps:
  1. Start the Xbox 360 console without a disc in the disc tray.
  2. In the System section of the Xbox Dashboard, select Console Settings.
  3. In the Console Settings area, select Audio.
  4. In the Audio Settings area, configure settings for analog output or digital output:
    • Analog output settings:
      • Dolby Pro Logic II: Select this setting for stereo systems or Dolby Pro Logic II-compatible systems.
      • Mono: Select this setting for systems that do not support stereo output. Note If you have connected to Xbox LIVE and downloaded any AutoUpdates, the Mono option will not be available.
    • Digital output settings:
      • Digital Stereo: Select this setting to use digital stereo output.
      • Dolby Digital 5.1: Select this setting to use Dolby Digital output.
      • Enable WMA Pro: Select this setting to enable WMA Pro pass-through if your receiver supports the WMA Pro format.
Note You must use one of the following cables to support digital output:
  • Xbox 360 Component HD AV Cable
  • VGA HD AV cable
  • S-video AV cable
  • Advanced SCART AV cable
  • Japanese HDAV D-connector AV cable
Additional info:
http://www.dummies.com/how-to/content/hooking-up-xbox-360-sound.html
Sep 28, 2009 | Audio Players & Recorders
Canoot get surround sound from back speakers
MAKE SURE YOU HAVE THE SPEAKERS WIRED INTO THE SURROUND NOT THE SURROUND BACK. IFF YOU HAVE SPEAKERS WIRED TO SURROUND MAKE SURE THE VOLUME FOR YOUR REARS IS TURNED UP.ALSO CHECK THAT YOU HAVE AMP SET FOR SURROUND SOUND,IE DOLBY DIGITAL OR PRO LOGIC TWO.
HOPE THIS HELPS.
Jun 01, 2008 | Audio Players & Recorders
Televison & Video Logo
29 people viewed this question
Top Televison & Video Experts
