Question about Brother Sewing Machines
Hello, I just purchased a used brother 170D and the thread keeps wading up underneath. Can you please let me know what the problem is Thanks, Glenda
    Genius:
  • 1,788 Answers
It is more than likely your top threading, insert a new needle (flat side facing away) because it could have a burr or a slight bend in it. Now totally rethread your machine, with the presser foot up, then pull on the top thread, it should move smoothly, put the presser foot down, pull the thread, it should barely move. This procedure should seat the thread in the tension discs. If, this does not solve your problem, return the machine and get a new one. Good luck.
Posted on Mar 18, 2011
Hello, I recently purchased a brother lx3817 sewing machine and it works but doesn’t stitch, what could be the problem
hi Desiree.
this is all i could find out.
There could be several things that could cause the machine not to pick up the bobbin thread.
  • The upper thread could be tangled.
    Remove the thread completely from the machine.
    The correct size spool cap should be used for the size of the thread spool.
    Re-thread the machine according to the directions in the manual.
One Point Advice Place a spool of thread on a spool pin.
One Point Advice Upper threading
  • Remove the bobbin and make sure the bobbin is threaded properly in the shuttle race.
    Remove any loose threads or lint in the shuttle race.
One Point Advice Installing a bobbin into a bobbin case
  • You could be holding the needle thread too tight.
    Hold the thread lightly to keep the end from going down into the shuttle.
  • The needle could be thread incorrectly.
    Thread the needle eye from the front to the back.
  • The needle could be bent or improperly inserted.
    Install a new needle with the flat side of the needle facing the back.
or this link might help you out some more.
Why won the machine pick up the bobbin thread Brother
or this one.
brother lx3817 sewing machine doesnt stitch Google Search
Dec 06, 2017 | Brother Sewing Machines
My bobbin thread keeps getting tangled...the machine is brand new, I've triple-checked the tension, my needle is sharp, and there is no lint. Please help!
hi, well i going to state something silly so please don't have a go because they are excellent sewing machines,. is it tangling under underneath ?? the footer plate ,
Okay main cause that people over look, Thread diameter ???
Have you fed the thread correctly ???
Does the tension actually make the thread harder to pull, this is a very common problem , has the tension dial has become damaged or simply not assembled correctly ???
Regards
Rob
www.electronicrepairs.co
Dec 30, 2013 | Brother CS6000i Computerized Sewing...
Brother pe180d thread bunching up underneath
try changing the needle
rethread the machine top and bobbin
make sure the bobbin is inserted correctly into the bobbin case
and that the bobbin is turned the right way
make sure the thread has not come off the thread take up lever
if the machine continues to see bunch thread underneath then the
machine may need to be checked to see if some part has become
damaged or out of alignment
Dec 02, 2012 | Brother Disney PE-180D Computerized Sewing...
My thread keeps getting knotted up underneath. I have followed all the trouble shooting procedures and it still won't work.
Usually it is the top threading, tangled thread or a bent needle that causes that problem. You can call Brother at 1-877-276-8437 and maybe they can suggest something else to try.
Oct 01, 2010 | Brother SE-270D Computerized Sewing...
My machine keeps bunching underneath why
totally rethread your machine, your top threading is wrong or thread is tangled. Sometimes the needle is bent or has a burr, use a new needle.
Sep 12, 2010 | Brother Sewing Machines
My brother LS-1520 sewing machine is having major tension problem
Try some metal bobbins, #15 or SA 156. that seems to help. If, you don't have a manual go to brother.com and download one for free
Jul 19, 2010 | Brother LS-1520 Mechanical Sewing Machine
How to thread a brother db2b737 industrial sewing machine
Hi. I just hate it when the thread keeps breaking and I can't figure out why! Brother makes it easy to get replacement manuals for their machines: http://www.brother-usa.com/Support/, then scroll down to Manuals and Documentation.
Besides not having the machine threaded correctly, some other things that can cause the thread to break are:
Upper tension is too tight
Wrong type of needle for the thread you're using (like trying to use metallic thread with a universal needle)
A burr or snag on the needle plate or bobbin hook
Please let me know if this helps, ok?
Thanks!
Robbie
Mar 03, 2010 | Sewing Machines
I have model #9920. The thread keeps wading up in
Most likely not threading the top thread correctly.
Jun 28, 2009 | Singer Sewing Machines
Buttonholes
please try this take out the bobbin and filp it around the other way and see if this helps
Jun 03, 2008 | Brother CS-80
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
