Question about Boss AVA-1204 7-Band Car Equalizer
I JUST GOT A BOSS AVA-1204 WHICH WIRES DO I HOOK UP TO THE HIGH INPUTS YELLOW AND ORANGE
2 Suggested Answers
BangEmBoy
  • 40 Answers
SOURCE: wiring diagram for BOSS AVA 1209 equalizer. It
Your wiring is as follow's :
The Red wire is your (+) Positive that connect's to the power source
The Black wire is your (-) Negative that connect's to the ground
The Orange wire is your Auxillary (+) that turn's on Amplifier's or Power Ant.
You should have a Green wire, a Green wire with a White stripe,a Gray wire, and a Gray wire with White stripe
The Green wire is the LEFT channel input (+)
The Green/White wire is the LEFT channel input (-)
The Gray wire is the RIGHT channel input (+)
The Gray/White wire is the RIGHT channe (-)
(BE SURE THAT YOU CONNECT THE RED (+) AND BLACK(-) WIRES BEFORE YOU CONNECT THE ORANGE WIRE TO AN AUX SOURCE OR YOU WILL BLOW THE INTERNAL FUSE !!!)
PS. I have no idea where that White wire you mentioned goes.
Posted on Feb 13, 2011
Where do I connect The red and violet wire
Squealing thats what, solid colors are the pos+ , same color with a stripe of a different color is the neg- side, of the same channel, green+ and GREEN with a white stripe -, its the general rule but it chances with different brands and manufactors..
Sep 15, 2016 | Boss AVA-1204 7-Band Car Equalizer
Need to know how the two yellow and two orange wires hook to
The yellow and yellow/black wire (left) and orange and orange/black (right) are high input speaker feeds to power the amplifier. You either connect high input feeds or the low level phono inputs! Not both!
Sep 05, 2015 | Car Audio & Video
On my boss ava-1204 equalizer what are the high input line use for to connect to
High input is designed for using speaker level output from another component (such as an amplifier) into the equalizer. Any source that is loud enough to power a speaker is a candidate for that input. The other type of input is the line-level input. This is a more common way to connect components. The power level on these is very tiny and must be amplified in order to be head.
Oct 28, 2014 | Car Audio & Video
Hi i just got a ava1202 boss eq it didnt have instructions this eq has rca inputs and high level speaker inputs can i use this eq with out an amp can smeone plz help me thnk u
Yes you can use the equalizer without an amplifier. That is what the high level speaker inputs are for. You simply take the positive and negative from a speaker and hook it up to the positive and negative high level speaker inputs on the equalizer.
Jun 04, 2011 | Boss AVA-1404 7-Band Car Equalizer
Wiring diagram for BOSS AVA 1209 equalizer. It was given to me dont know where the 4 wires connect red,black,white,last wire is orange or pink.
Feb 03, 2011 | Boss AVA1209 7-Band Car Equalizer
I would just like to have the wiring diagram for the Boss AVA 9060 model. Thanks!
wires are: red-ignition, yellow-battery or memory, black-ground, blue-remote for amp or antenna, orange-illumination (if it has one), the white, grey, purple and green wires are the speakers
Sep 17, 2010 | Boss AVA-9060
What is source ground on an equalizer
Ground Source, not the other way around. It is a metallic place, interconnected to the vehicle chassis, where the electricity will flow from positive to negative. Best bet is to connect your equalizer black ground wire to the radio black ground wire, since it has already been bolted to a good ground. Furthermore, grounding it to radio, will prevent any humming between the two units.
Jan 22, 2010 | Boss AVA-1204 7-Band Car Equalizer
Whinning noise when car is on and AUX is connected to ipod
ENGINE NOISE PLUG ALL YOUR RCA DIRECT TO AMP BYPASS EQ AND SEE WHAT HAPPEN IF THIS STILL HAPPEN CHECK ALL YOUR GROUND AND RCA MAKE SURE YOU HAVE GOOD CONNECTION
Mar 30, 2009 | Boss AVA-1215 5-Band Car Equalizer
Boss AVA-1204 7-Band Car Equalizer Logo
50 people viewed this question
Top Boss Car Audio & Video Experts
xxxxxx xxx
Jerry Umali
Are you a Boss Car Audio and Video Expert? Answer questions, earn points and help others
