Question about Nokia E75 Cell Phone
My screen is only working on side view. Also no opening or closing sound when slide out or close
  • Nokia Master
  • 6,993 Answers
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Read the tips on this link for more info about phone screen problems; http://www.fixya.com/support/r6382458-screen_problems_phones
Good luck.....
Posted on Mar 18, 2011
Hi I have a Sedona 2006 slideing door will close but not open unless part done manuly
it need more power to open the door incited of closing so i advise to visit the link for help
Aug 13, 2017 | Cars & Trucks
How to reset automatic sliding door on chevy venture van
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
  1. Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
  2. Manually open the power sliding door completely.
  3. Manually close and latch the power sliding door.
  4. Turn the power sliding door ON/OFF switch to the ON position.
  5. Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  6. Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
Sep 30, 2012 | Chevrolet Vehicle Parts & Accessories
2006 dodge Grand Caravan power door wont open automatically, makes clicking sound.
These automatic side doors are extremely complicated and require a trained technician to repair wit the factory repair guides to go by, there are many adjustments to be made and sometimes that is all they need plus some cleaning and lubrication of the latch and moving parts. My best advice is let the dealer fix this.
Jun 22, 2012 | 2006 Dodge Grand Caravan
If i have the slide opened the screen and image works ok but if i slide to close the keyboard, the screen goes dark with some glitchy images sometimes and then if i open it again and use the direction keys...
There is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
Take care.
Aug 25, 2010 | Nokia N95 Cellular Phone
Sliding door fails to latch
There is no "switch". The Sliding Doors should be manual anytime you try to open or close them. If not: then there is problem in the electronic system or the physical/mechanical side where something is jamming the door from opening or closing.
Dec 31, 2009 | 2002 Chrysler Town & Country
2008 Dodge Grand Caravan side door does not automatically close.
sounds like the door sensor switch is malfunctioning and when almost closed it reacts like it is blocked (such and kid in way) and opens for safety. try flushing trach with hose and try again, if not u need a good repair manual such as chiltons($25 most parts stores ) or see mechanic
Jul 07, 2009 | 2008 Dodge Grand Caravan
Dodge caravan sliding door hard to open/close by hand
i'd suggest you just grease the channel top and bottom where the arm slides to hold the door as it's sliding open or closed
Apr 11, 2009 | 1994 Dodge Caravan
2002 Old Silhouette Driver Power Sliding Door will not open
Look in your owners manual there is a procedure to reset the door controls. If that dosen't work maybe the motor is burnt out, it's in the left rear access panel.
Mar 25, 2009 | 2002 Oldsmobile Silhouette
Les extended, screen remains black
tuen on camera then press display a few times. it sounds like the display is just turned off. the lens system should be open.
Jan 03, 2008 | Pentax Optio S50 Digital Camera
Door opens and closes 3 times
v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} t needs to be realigned
unplug power
open unit
clip_image001.jpgremove dvd drive (4 screws)
remove power cable to dvd right rear of unit on circuit board
(squeeze plastic connector and pull up)
remove ribbon cable CAREFULLY wiggle it from side to side and it will come up clip_image002.jpg
Then with drive removed, open up drive to access the bottom near front door
Once open you will see a smalll motor and a white pice of plastic that slides. with tray closed slide that piece of plastic as far towards the middle as it will go clip_image003.jpg
with that slid all the way over you should be done.
close it up and be carefull sliding the ribbon cable back into place
Worked for me!
Good luck
Dec 22, 2007 | JVC DR-MV7 DVD Recorder/VCR
Nokia E75 Cell Phone Logo
65 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
IT Solution
IT Solution
