Invalid disc error message - Televison & Video
  • 6,993 Answers
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Take care.
Posted on Mar 18, 2011
All my DVDs say "invalid" when I try and play. This just started all of a sudden. Was working just fine before.
Always first unplug for a minute and make sure the discs are VERY CLEAN. Sometimes my player/recorders give an error message 2-3 times but eventually are able to load the disc.
Mar 29, 2014 | Toshiba UNTESTED, AS IS BDX2150KU Blu-Ray...
F2 error message on DVD
F2 appears to be an invalid region code error, try another disc... also check parental control and make sure it's not active. Failing that check fuses for the radio, the water may have shorted something, you can find the owners manual on help owl which details error codes.
Nov 23, 2013 | Car Audio & Video
Sony BDP-BX2 Blu-Ray player now rejects valid discs as "invalid"
Sometimes the latest update IS the problem, not the solution. If possible go back to an earlier version and retry the disks. Many of the answers here about power down and the like are all good and sometimes helpful things to do. They also point to the fact there isn't much a consumer can do to fix or repair malfunctioning DVD/Blu-Ray players and it always comes down to cost. Do you want to repair or replace. You've had your unit, you say, about 3 years? I think this is about end of life. Anyway, try the previous software version and if that works turn automatic update off.
Nov 14, 2013 | Sony BDP-BX2 Blu-Ray Player
I have been using windows Vista for about 2 months and I shut the computer one night and now it states the validation code is invalid
If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms. Error message 1
Error Code: Invalid Volume License Key
Error message 2
Error Code: 0xC004F059
Description: The Software Licensing Service reported that a license in the computer BIOS is invalid.
You receive the following error message:
Error Code: 0xc004f035
The Software Licensing Service reported that the computer could not be activated with a Volume license product key. Volume licensed systems require upgrading from a qualified operating system. Please contact your system administrator or use a different type of key. Article KB94962 will help you. If the following error code or error message appears when users try to activate Windows Vista The activation key You typed is invalid This TechNet thread may prove to be of help. If you face Volume Activation error codes on Windows Vista-based computers, KB938450 will help you troubleshoot them.If, when you try to activate Windows Vista on a computer that was obtained from an OEM, you experience one one of the following symptoms.
Error message 1
Error message 2
If you face Volume Activation error codes on Windows Vista-based computers..
May 05, 2010 | Microsoft Windows? Vista Home Basic...
Web page errors
if you're using IE8 try the compatibility view,
Make sure that the page displays correctly within ie7 or ie6.
Let me have some feedback
Regards
GeWiz.
Jul 21, 2009 | Microsoft Internet Explorer 8
SQL Invalid cursor number 135 error
The error is being generated because you are trying to order on a value not in your selected fields e.g EFFECTIVE_DATE
You only have TRANSACTION_TYPE in your select statement
Sep 24, 2008 | Gupta Team Developer for PC
Coby Model Number TF-DVD7005
Paul Sim, coby portable dvd player model TF DVD7005 keeps coming up with an error message that says NO DISC regardless of whatever disc you put in, the player comes up with the message LOADING on the screen and then stops after a little will and comes up with the NO DISC message
Dec 10, 2007 | Coby TF-DVD7005 Portable DVD Player
Looking for bios upgrade
That sometimes happens anyway,  basically your HDD has not initialised within the time allotted for it to do so.
you should be able to download an updated BIOS from the compaq /HQ website
Oct 25, 2007 | Compaq Evo N600c Notebook
Televison & Video Logo
238 people viewed this question
Top Televison & Video Experts
