Question about Bosch Washing Machines
Cant get the drive belt back on to tight is there any adjustment or way to do it
    Brigadier General:
  • 6,277 Answers
The main 'adjustment' is to purchase a new belt and NOT to attempt to put the old one back on!
Belts are not expensive- sorry I do not know how much yours would cost- and are easy to be changed by a competent person, yourself in this instance ;-0)
REMOVE POWER FROM THE MACHINE AND REMOVE THE BACK.
The motor support bolts should be loosened and the old belt removed. Often putting the new belt on is a bit of a struggle, even with the motor 'loose', because it is new and smaller!
Once on it should be tensioned by pulling the motor against the belt firmly- but not over tight- and the motor support bolts tightened.
ON NO ACCOUNT SHOULD ANY FORM OF LEVERAGE BE USED TO TENSION THE BELT. THAT COULD LEAD TO DAMAGE TO THE BELT, MOTOR AND BEARINGS- EXPENSIVE!
Hope this is your problem solved.
Good luck,
John C
Posted on Mar 18, 2011
How do you adjust the drive belt that makes mower drive
you cant your idler pulley is set to provide enough tension for the belt to keep it tight over tome belts stretch and or wear down to where they start to slip thats when time to replace with new one
Aug 11, 2015 | Garden
How do i adjust the drive belt on my troy bilt pony model 37120
There should be an adjusting nut you loosen somewhere along the belt path. You normally loosen it the pull the belt tight the tighten the nut back down much like a fan belt in a car.
May 18, 2014 | Garden
The belt has slipped off the pulleys and we cant get it back on as it is too tight. how can we put the belt back on - is there a tension adjuster?
depending on make of machine..............
most you can loosen the motor put belt on then tighten motor back up....
cheers
May 22, 2011 | Washing Machines
Belt broke stering has gone tight-which belt do i need audi a4 1996
Give the model and year at an autoparts store and ask for a power steering belt. Will likely be running the waterpump and alternator too so you cant drive far because you will overheat the engine and or flatten your battery.
Loosen alternator bracket all bolts and move it to the shortest distance to the nearest pulley wheel. Slide belt around all free wheels and idlers (tensioning wheels) and move alternator bracket back to original position so belt is tight.
If you cant get the belt on belt is too short, if it is not tight with alternator about half way along the adjustment bracket belt is too long. Take it back to store, act real grumpy, try to leave with right size belt and a free gift.
Apr 25, 2011 | Audi A4 Cars & Trucks
85 chevy celebrity. replaced alternator. that one squealed 2. got another. still hear a squeel. does not squeel when belt is off.
ALTERNATOR BELT NEED ADJUSTING AND REPLACING IT GLAZED. WHEN DRIVE BELT GET GLAZED SHINY CAUSE IT TO SLIP AND SQUEAL.REPLACE ALTERNATOR DRIVE BELT. AND ADJUST IT DRIVE BELT TENSION BY TIGHTEN THE UNTIL YOU CAN PRESS DOWN ON THE BELT IN THE LONGEST RUN. YOU NEED TO PRESS DOWN BELT AND GET A 1/4 TO 1/2 INCH DEFLECTION IN BELT.THE BELT CANT BE TOO TIGHT WHERE WHEN YOU PRESS DOWN AT IT WONT GIVE IN NONE TOO TIGHT, WILL CAUSE PREMATURE ALTERNATOR BEARING FAILURE IF DRIVE BELT TOO TIGHT.
Apr 18, 2011 | Chevrolet Celebrity Cars & Trucks
Hi we are trying to fit a drive belt, but cant get the belt on its to tight, cant find an adjustment lever or anything can you help?
hi providing you have the right belt. run the belt over the pulley until its tight (it will only go half way round and feel impossible to get on but just run it on like you would cycle chain it takes some effort but once the belt starts to stretch you will find it will go on. just brute force will do it. good luck
Nov 15, 2010 | Zanussi FS1255S Front Load Washer
My nordic track treadmill's walking belt stops when I start walking on it but the motor is still running although the front roller is not moving when I start walking on the walking belt. Do you think the...
Unplug the unit remove the motor shroud inspect the drive belt if the rubber feel slick then my recommendation is to replace the drive belt. Adjusting the drive belt may take care of the problem if you do not need to adjust it too tight. If you choose to do the adjusting and feel you have adjusted the running belt thinking it would resolve the slipping, then back the tension down until it the running belt is slipping then adjust until the slippage is resolved.
May 17, 2010 | Nordic Track Exercise & Fitness
Have a 4.9 treadmill and cant get it to adjust if i loosen bolts in back it slips if i tighten bolts on motor it quits pulling when i put weight on it can you help
Ok I really need more info but let's take a stab at it. The bolts in the back of the rear roller adjust the belt right and left. It also tightens and loosens. Ok there is also a drive belt from the motor that needs to be tight. Generally you should be able to twist the drive belt about 45 degrees. If it's more than that it probably needs to be tightened. If this is loose it will affect the walking belt the same as the walking belt being loose. So when your walking belt is slipping, make sure you tightened the right belt. Tightening the wrong belt can lead to other problems. Tightening the walk belt with the rear roller- turn both bolts clockwise equally to tighten. Remember the walking belt will travel to side with least tension. So to center belt, adj left or right side to fine tune. If belts are adjusted properly and machine stops when you walk on it, you have other issues. Could be the deck ( the board under the belt) and belt or the motor.
Nov 17, 2009 | Proform 6.5q Treadmill Walking Belt
Ho to replace serpentine belt. cant find anything
There probably won't be any adjustments. Serpentine Belts have be used for 25 or 26 years to my memory ,and have spring loaded tensioners to keep belt tight. So I quess your new to the car world. You release the tension with a long 1/2" Drive ratchet or tool specific for belt replacement. If you need to buy any tools you don't have, your better off leaving it to the pros
Oct 01, 2009 | 2004 Hyundai Santa Fe
Washing Machines Logo
50 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
