Question about Sanyo PLC-XU45 LCD Projector
I have a Sanyo PLC XU45 projector which recently gegan to shut down after about 10 secs after switch on countdown (30s). All Fans working OK. I've cleaned the filter (which was clogged). Funny thing, when I turn it on it's side it works perfectly (could it have something to do with the thermistor?).
    Sergeant:
  • 261 Answers
How many hrs are on it? I suspect the lamp is going out of it... Buy another lamp and go from there. This way even if it isn't the lamp you will have one in stock. But if it is, you have just fixed your porjector.... Good luck..HDTV GURU JAY
Posted on Mar 18, 2011
Hi I have a Sanyo PLC-XP18 projector and it has recently developed a problem. I was watching a film the other night and the projector just cut out. Now when i try and turn the projector on the the fans...
READY light is green when the projector is ready to be switched on
LAMP is dim when the projector is ON, but goes bright when it reverts to STANDBY.
Check that the lamp cover is fully down and the cover switch is activated
Feb 28, 2011 | Sanyo PLC XP18 Multimedia Projector
Sanyo PLC-XU33 multimedia projector. Starts up, goes through countdown, stays on for a minuit after that, then bulb goes out and it goes into shutdown?????? Rob,
hi,
check the video inputs. if there is no video input then the projector will goes off after count down.
also check that is the lamp replace light lights up or not. if its lights then you have to change the lamp and then reset the lamp hour.
ok
Jan 19, 2011 | Sanyo PLC XU33 Multimedia Projector
We are having one sanyo plc xu 78 projector.when it began to switch it on the count down screen will displays when the count down timing is coming to 0 then its directly going to stand by mode. its not...
The countdown shows while the unit is going through its internal circuit testing. Usually if a problem is found, there will be indications with the standby lights and lamp/temp lights. Are there any other indications here or just the unit going into standby?
Dan
Jul 08, 2010 | Sanyo PLC XU35 Multimedia Projector
Lamp goes out after 10-15 seconds
Recently had a similar issue.
When I took the lamp out (Let it cool for awhile first), there was dust all over one side preventing air from the fans from cooling the lamp, so it shut itself off after getting too hot.
Apr 27, 2009 | Sanyo PLC XU48 Multimedia Projector
Sanyo PLC SW20AR - Shuts itself down
check the follwoing :
check lamp physically for melted filament, white deposits on filament/ reflector, if so change lamp
if lamp looks perfect, the ballast needs to be replaced, also check for fans if they are running fine
Feb 08, 2009 | Sanyo PLC SW20A Multimedia Projector
Sanyo PLC-XF46N projector shuts down before powering up completely
The Fix Ya rep suggested that I try the "Reset" button located next to the Audio out on the side of the projector; this solution proved to be the fix I needed. I was able to get the lamps to warm up and get into the menu to cut back the bulbs/power consumption on start-up, allowing the projector to function for a problem-free 4 hour period Unfortunately, I had the same issue this morning, but the same fix worked again.
Jul 06, 2008 | Sanyo PLC-XF46N LCD Projector
LCD PROJECTOR GOES BLANK
Check the cooling fan/ air ducts - sounds like it's overheating and shutting off to prevent damage.
Mar 12, 2008 | Computers & Internet
Sanyo PLC-XU45 LCD Projector Logo
152 people viewed this question
Top Sanyo Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Sanyo Office Equipment and Supply Expert? Answer questions, earn points and help others
