When I try to scan a picture and save it in documents...it scans but shows the picture against a white back drop as if the picture is inserted in a white back drop. When I go to forward the picture it does not just take the picture but the whole page with the white back drop. How can I get it to just scan the picture but the a white paper behind the picure
  • 917 Answers
Your scannig software will allow you select the area you want to scan. If you just use the SCAN button on the printer then you will get the full scan.
Posted on Mar 18, 2011
I have a MP240. Can this printer scan multiple pages and make it into one document? If so, how? If not, then I'll persevere with emailing separate pages...grrr
Not sure ?
try if it has a top document feeder and then scan to a p.c if it has this option ?
otherwise
scan each document to seperate files and then insert each file into a word document using ms word select insert , picture from file (try holding CRTL to select multiple files at once with mouse click)
Then save word document and attach word document and send
Mar 15, 2016 | Office Equipment & Supplies
Hp 6210 officejet all in one ... want to test scanner only. Took 16 hour tech assist to download (software was not provided by work associate). Ink cartridges do need to be replaced. Want to test the...
yes, you can test the scanner without inks.
use the hp solution center c01810967.gif installed on the computer Double-click the HP Solution Center icon (c01810967.gif ) on your desktop
  • For photos or artwork : Click the on-screen Scan Picture "button" in HP Solution Center.
  • For a text document with or without graphics : Click the on-screen Scan Document "button" in HP Solution Center.
    For the HP Solution Center "button" that you are using ("Scan Picture" or "Scan Document"), set the option to prompt for settings each time you scan, and then click OK .
    • Scan to: Select your scan destination from the drop-down list.
    • File Type: Select the file type from the drop-down list.
    • ...Save Options...: (available only for certain "Scan to" destinations): For example, if you are saving to a file, click this option to select your Save Location .
    • Show preview...: Select this check box if you want to see a preview before the actual scan.
      Click Scan
Jun 05, 2011 | HP OfficeJet 6210 All-In-One InkJet...
After scanning a document how do I upload the document to my computer.
I am not familiar with the scanning software that you are using. But I am sure there must be a button after the scan completes that says save. Above save it should show the destination of where it is saving like My Pictures or my Documents for example. If it does have have a line like C: My Documents above the save button then to the right of that line you will see a small black triangle click on that and the line will drop down and you can select another destination to save your document.
I hope this helps you out if it does please click on Yes that I did try and help you. Thank you.
Apr 07, 2011 | VuPoint PDSST410VP
How to scan a document in HP F 4288 deskjet
Open printer suite and open scan option from it.
or
Open Microsoft Word > Insert > Pictures > From Scaner > Scan page will come out > Preview > Scan > Picture inserted in Word page > Set Picture In front of text > OK > right click at picture > save as picture file > choose save as JPEG file > Save.
Now you can use it as picture files.
Hope this help and if helpful RATE please !
Jan 20, 2011 | HP DeskJet F4280 All In One Printer InkJet
How to scan multiple images into one pdf document
after scanning one page .. do not save the page but choose "add another image /page option " and scan accordingly.. and save the entire document after you are done with the scanning of all the pages.
Sep 30, 2010 | HP PhotoSmart C4280 Laser Printer
I need help scanning a document on my hp photosmart C5200 printer/scanner. I can't find the option in menu to scan and save as document
scan by application.On your computer go to Microsoft word, go to insert then picture, from scanner or camera, choose the type of scanner you are using. Custom insert. The scanner scans your document
Sep 03, 2010 | Office Equipment & Supplies
How do I scan a document using the hp psc 1315 and then find it on my computer? I press the scan button and it seems to scan, but then I can't find the newly-scanned document anywhere. There needs to be an...
The scan button is setup to push the scan to an application, if you uninstalled the HP scanning software, it isn't going to go anywhere. If you didn't, it will put it into your documents folder under "My Pictures" in an HP created folder.
That said, you can also go into any application, like Word. then click "Insert > Picture > From Scanner or Camera" and carry the image in directly.
Oct 01, 2009 | HP PSC 1315 All-In-One InkJet Printer
How to scan picture to upload on computer
First, ensure you are connecting the scanner to your computer. I'm assuming USB connection, and that you're using an operating system supported by this device.
Next, install the drivers and software for this device. Those should have come with an installation disc, but if you don't have that disc, you can get them from the PIXMA MP830 support site, here:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=12804
To scan a single document, place the document:
1. Place the document face down on the platen glass.
2. Open the MP Navigator 2.2 software.
3. Click Scan Photo/Document.
4. Click Document Type drop-down arrow and select the type of document to be scanned. Chose from the following types.
  • Color Document(Simplex): Select this to scan one side of color documents.
  • Color Document(Duplex): Select this to scan both sides of color documents.
  • B/W Document(Simplex): Select this to scan one side of monochrome documents.
  • B/W Document(Duplex): Select this to scan both sides of monochrome documents.
  • Text(Simplex): Select this to scan one side of text documents.
  • Text(Duplex): Select this to scan both sides of text documents.
5. Click 'Specify' and set the preferences as required. Click here for detailed information
6. After making the setting changes, click 'Scan'
7. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning
The directions for Batch Scanning, or using the ADF to scan, are shown below.
  1. Place the document(s) in the Automatic Document Feeder (ADF).
    1. To scan using the ADF, remove any documents from the platen glass.
    2. Open the document tray.
    3. Insert the documents face-up in the ADF and then adjust the document guides.
      Note:
      When scanning using the ADF, the documents will automatically feed.
  2. On the Windows desktop, double-click 'MP Navigator 2.2'.
    1. Alternatively, on the Windows taskbar, click 'Start', point to '(All) Programs', 'Canon', then 'MP Navigator 2.2'.
    2. Then click 'MP Navigator 2.2'. MP Navigator opens.
  3. Click 'Batch Scanning'.
    * Color Document(Simplex): Select this to scan one side of color documents.
    * Color Document(Duplex): Select this to scan both sides of color documents.
    * B/W Document(Simplex): Select this to scan one side of monochrome documents.
    * B/W Document(Duplex): Select this to scan both sides of monochrome documents.
    * Text(Simplex): Select this to scan one side of text documents.
    * Text(Duplex): Select this to scan both sides of text documents.
  5. Click 'Specify' and set the preferences as required. Click here for detailed information.
  6. After making the setting changes, click 'Scan'.
    1. After the documents are scanned, a dialog box will appear indicating to load the next document.
    2. After the next document is loaded, click 'Scan'.
    3. Repeat steps 6a and 6b until all documents have been scanned and then click 'Exit' to end the scanning process.
  7. After all documents have been scanned, ensure the documents, in the preview area, are selected (have a check mark).
  8. Click 'Save to PC' or 'Save as PDF file'. Save to PC is displayed when an image is captured with Scan Photo/Document or Batch Scanning.
    Save to PC dialog box
    Save as PDF file dialog box
  9. Make settings to save a file. (Click File save settings for details.)
  10. Click 'Save' after all settings have been selected.
Aug 27, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Scanning
by default it is save in my picture but when we scan then from brouse we can select the location from the brouse options
Jun 27, 2008 | HP Photosmart C6180 All-In-One InkJet...
HOW TO GET FROM 35mm COPYING TO REGULAR COPYING
Configure your scan buttons in the bottom right corner of your screen (when you click on the scan icon in taskbar). This will help you to go back where you want to be. You may find it easier to use XP's inbuilt scanning facility instead or scan via Photoshop.
Sep 17, 2007 | Visioneer OneTouch 8920 Flatbed Scanner
60 people viewed this question
k24674
jasbo
jasbo
