No access on microphone - Computers & Internet
  • 27,725 Answers
Click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it hope this helps
Posted on Mar 19, 2011
The acer aspire 7551 built in microphone is not working
First check that driver is described as ok in device manager,and drivers loaded ,if there , will probably need to access microphone check for broken wire connection or dry joints at microphone ,or disconnected connector
Sep 06, 2014 | Acer Aspire 7551 7552 7741 Series 17.3"...
Tip
How to play computer sounds through microphone
<p>There may, of course, sounds from a microphone, because there is a speaker, but you can use sounds from a microphone or something speakers connected to the microphone system is played. Computer games, but might sound a bit complicated because they usually lead to loud sounds into the microphone to a number set. <br /> <p><br /> <p>1. Find the computer that you want to play sound. Go to Control Panel and click on "Hardware and Sound." Under "Sound" in "Changing the system sounds." You can access various Windows sounds by selecting them and clicking "Test". <br /> <p><br /> <p>2. External speakers to the sound card or audio output on a laptop. With active speakers is recommended, the stronger the better. Set the microphone in front of the speaker. <br /> <p><br /> <p>3. Connect the microphone and play the sound from computer speakers. That should pass the microphone for recording or performing live. <br />
on Jun 22, 2011 | Audio Players & Recorders
How do i get a microphone so i can audio type
Update your iOS to 7, then be aware that iOS 7 now requires applications to specifically request access to the microphone, and a new "Microphone" section under the Privacy controls allow users to view a list of those apps that have requested access and toggle the access on and off for each app, similar to how other the other privacy options work.
Mar 28, 2014 | Apple MC764LL/A Wi-Fi 3G Verizon 64GB iPad...
How to use microphone?
do you want to access in built microphone or external microphone
Jun 08, 2012 | Acer TravelMate 4740
How to detect microphone in laptop
I think it would be better if we check that the built-in microphone is working on your machine.
Internal microphone
The internal microphone is located near the top of the notebook LCD display or near the bottom of the LCD display near the hinge. Use the following best practices to better capture sound with the microphone.
-Adjust the notebook PC screen to place the microphone in the best direction for receiving sound.
-Speak directly into the microphone. Avoid speaking away from the microphone.
-When using the internal microphone, choose an environment without background noise.
Testing the record function on the notebook PC
1. Click Start , then Programs , Accessories , Entertainment , and then Sound Recorder .
2. Click Record (the red dot) and speak into the microphone.
3. When you are finished recording, click Stop (the gray rectangle).
4. To play back the recording, click Play (the gray arrow pointing to the right).
If happens that the recording with the microphone have no sound we have check the settings.
Checking microphone settings
1. Click Start , then Programs , Accessories , Entertainment , and then Volume Control .
2. A Volume Control or Master Volume window opens.
3. Click Options , and then Properties .
4. Select Recording , and make sure Microphone is selected.
5. Click OK . The Volume Control window should change to a Recording Gain Control window.
6. Click Options again and then click Advanced Controls . If Advanced Controls is unavailable, then an alternate microphone is not available. Proceed to the next series of steps.
7. Remove the check next to Alternate microphone , click Close , and test the microphone. If there is still no sound, continue to the next step
Ensuring the correct recording device is selected
1. Access sound properties:
-In Windows XP, to access the sound control panel applet, click Start , then Control Panel . Click Sounds, Speech, and Audio Devices , and then click Sounds and Audio Devices .
-In Windows 95, 98, and Me, click Start , Settings , and Control Panel . Double-click Sounds and Multimedia , or Multimedia . The Sounds and Multimedia Properties window opens.
2. Click the Audio tab.
3. Under Sound Playback , select the audio device that is installed on the computer (there should be only one).
4. Under Sound Recording , select the audio device that is installed on the computer. It should be the same as the listing under Sound Playback .
5. Click OK .
6. Close the Sound and Multimedia Properties window and test the recording.
Feel free to reply if happens the steps I've told you is not working. Hope it helps.
AnEspera
May 03, 2011 | HP Pavilion dv4000 Notebook
Where can I find a Midland 22-211 dynamic wiring diagram?
http://i79.photobucket.com/albums/j149/johncheney/todd/IMG_0057.jpg
Original Diagram that came in the box with this microphone!
Jan 04, 2010 | Midland Audio Players & Recorders
Microphone will not pass setup
I have finally found a solution! I found it by chance on the rosetta stone troubleshooting page. I have nod 3 antivirus + firewall and in the firewall settings the rosetta stone application was blocked (it was denied internet access). I just deleted it from the list and the next time rosetta stone asked for internet access I clicked yes. Now rosetta stone detects both my dynamic microphone and my usb headset and it works fine. Hope this works for everybody.
Jun 21, 2009 | Rosetta Stone Spanish (Latin American) -...
Microphone not working
Yea where IN the DS Lite menu?
Sep 06, 2008 | Nintendo DS Lite Console
Pc microphone
i found a solution under the control panel. to configure some settings under the default view of the control panel, use the Ease of Access icon. this does not allow you to see the actual device. by switching to the classic view, use the Speech Recognition Option, which showed that i had 3 microphone drivers installed. all that needed to be done was to select the one i was using as the default.
Mar 09, 2008 | Plantronics Audio™ 350 Headset
Sigmatel audio sofware
installation problem:-
i have already install winxp sp2
and all dirvers by cd with attach
motherboard D945GNT,and
one day sound driver was unistall automaticaly ,and never again install driver
Jan 17, 2008 | Intel D945GTP Motherboard
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
