Question about SATO Cl412e Label Printer
The printer ribbon on the SATO CL408E2 is wrinkling. The resulting transfer is not consistently bar code readable. The ribbon is smooth prior to unwinding, but the wrinkles appear as it unrolls through the print head. We have ensured it is loaded correctly. We can see no obvious mechanical problems. Any ideas?
SOURCE: printer problem
check baud rate on NIC card (pull out NIC), against COM settings on PC. they must match. 9600 usually works
Posted on Jan 14, 2008
SOURCE: Sato CL 480e not printing clearly...
Your platen roller (the black rubber roller) isn't smooth in that spot. Maybe it has be nicked or cut there or has something stuck onto it. If it's cut you will have to replace it, otherwise try cleaning it with high percentage isopropyl alcohol.
Posted on Mar 06, 2008
SOURCE: Zebra Z4MPlus Ribbon Wrinkles
I changed the print head, and the issue was solved.
Posted on Aug 04, 2008
SOURCE: Ribbon wrinkles when printing barcodes
This is usually caused by temperature of the thermal print head. This is found in the printing preferences of the printer.
Posted on Aug 15, 2008
  • 537 Answers
SOURCE: I have sato cx400 printer, looking for VB6 code
Try this link:
http://www.filebuzz.com/files/Codabar_C/freeware-1.html
Have a look at the VB Barcode Integration Kit
Posted on Feb 04, 2009
Red light blinking
You need to recalibrate the printer with sato cx400 printer driver.
There is also option to enable Direct Thermal (no ribbon) or thermal transfer printing option.
Jan 02, 2016 | SATO CX400 Thermal Label Printer
Bar code printed on sato m5900 Rve printer will not scan. Same bar code printed on HP laser WILL scan. Font used is ID Automation 39 - prints at 6 pitch
Are you printing in thermal transfer mode or on thermal direct stock? Sounds like your image is not black enough for your scanner. Things to check: adjust printhead temperature, change ribbon stock, change thermal-direct stock, adjust scanner's sensitivity.
Jul 18, 2011 | SATO M5900RVE Printer
Printer printed 5 tags but there is wrinkles in the tags so i tried to realign the ribbon and now it will not print
Ribbon wrinkles are due to:
- Ribbon too large.
- Print Head misaligned.
- To much heat.
- innapropriate Transfer film.
check with your tag dealer
Apr 24, 2011 | Toshiba TEC B-SX4 Thermal Label Printer
We are getting white vertical lines running through our barcode label. it looks like printer ribbon is wrinkling when printing them on long runs. How can we stop this
When you have this problem you need to determine if the ribbon is wrinkling before or after the head. If it is before the head then you need to adjust the bar prior to the head. There should be a phillips head screw there and directly behind it there is an adjustment. Loosen the screw and then move the bar (it is slightly arc'd) so it smooths out the ribbon. This is the least likely suspect. Most likely the head is not square. If the head is not square with the roller below it will cause the ribbon to "dance" as I call it. It will slowly move over then jump back to its rightful position. Or it could just wrinkle. If this is the case and your print looks good then you can adjust the ribbon bar right where the ribbon comes out of the head. There are two screws at the top. Loosen both of them and this adjustment bar will slide all the way back. Once this goes back. Manually manupulate it until it smooths out the ribbon. Once you manually figure out where it is smooth then tighten the screws back up. Feed a few labels and see if the ribbon is smooth.
Jan 27, 2011 | Datamax I-4208 Thermal Label Printer
Can this print thermal transfer as well as direct thermal
Sure it can. You just need to make sure you correctly match the thermal transfer ribbon to the facestock you're printing on. Wax ribbon for paper, Resin for synthetics like polyester.
May 26, 2010 | SATO CL408e Label Printer
Wrinkles in ribbon using Datamax H-4212 printer
Definitely. possible solution match the width of your label and ribbon. if your ribbon is wider for .5 inch it should be good.
1. check your spindle alignment, printhead alignment and rotate the green knob on the printhead while printing so that you'll see the difference.
Jan 29, 2010 | Datamax DMX I-4206 Printer
Outside wind ribbons/labels
sato uses outside wind ribbon and inside label.
you shouldn't have to configure anything as long as the ribbon spindle turns and registers movment
Nov 22, 2008 | SATO CL408e Thermal Printer
Printer Ribbon has a wrinkle in it
Remove the ribbon and try to remove the crease. Check the printhead for obstructions. You may have to open up both halves of the ribbon cartridge to look for jams or obstructions.
Aug 19, 2008 | Datamax DMX-I-4212 Label Printer
Datamax I-CLASS DMX-I-4212
Printer ribbon has a wrinkle and it transfers to the label in the form of a blank line accross the ribbon.
Jun 03, 2008 | Datamax DMX-I-4212 Label Printer
Ribbon End
Try changing setup from thermal transfer to direct thermal
Apr 03, 2008 | SATO M-8485Se Thermal Label Printer Print...
SATO Cl412e Label Printer Logo
163 people viewed this question
Top SATO Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
M_Butkus
Howard
Howard
Are you a SATO Office Equipment and Supply Expert? Answer questions, earn points and help others
