The aerial has become detached from my DAB Hitachi KH1105D. How do I reconnect tyhe aerial lead after taking the back off
5 Suggested Answers
  • 1138 Answers
SOURCE: Audio technica microphone atm33a socket detached
Unfortunately you will have to contact them here:http://www.audio-technica.com/cms/site/74a0c4b691ac33ae/index.html as they don't seem to have that document listed on their site.
Posted on Jan 18, 2010
kb8dns
  • 494 Answers
SOURCE: The external aerial wire has become detached from
With no idea of what the radio looks like inside and there are literally thousands of radio designs, there would be no way of explaning the place to solder the wire. Can you send some jpgs of the chassis?
Posted on Feb 09, 2010
snakehead
  • 1074 Answers
SOURCE: I have a Philips DAB
get a fm antenna that you can install on your roof.that should solve your problem.good luck.Ronald.
Posted on Sep 13, 2011
  • 6771 Answers
SOURCE: No aerial on Dab Radio
It is a right off, far cheaper to replace.
Posted on Mar 10, 2012
Why will my radio new 3120 not pick up dab stations at all really tune and all I get is radio 2 have tried for a week to get magic fm thank you
If you have replaced a normal car radio with a DAB then your existing aerial is not suitable due to the required frequency range. You need a DAB aerial for cars. There are many types available, internal or external. Don't bother with converters as this will only give a marginal boost to the fm aerial.
Jun 06, 2016 | Cars & Trucks
Can not get DAB radio too work on my Vita audio but FM radio works fine
This may be because you live in an area where DAB reception is currently poor, but to check this, please use our postcode checker (see 'check your DAB coverage' panel on the right) to see which DAB stations you should be able to receive. If reception for your area appears to be good, then it may be down to local conditions or building materials. Buildings constructed from steel and reflective glass are not good for radios with internal aerials as they reflect and greatly reduce the strength of signal. In such a case an external aerial will greatly improve reception, but most importantly, if you are using the supplied telescopic aerial, you should ensure that it is properly fitted and fully extended upright.
Secondly, when our products are first powered up from new, they automatically scan the DAB network to see which services are available. During this process it is important that the radio is not touched and that the aerial has been correctly fitted and extended as instructed. If this has not been done then it is likely that not all stations will be detected and only the strong ones displayed. To correct this a new AutoScan/AutoTune or System Reset should be performed as instructed elsewhere in our Q&A's.
questions answers
Sep 04, 2014 | Audio Players & Recorders
Have a problem, not with the DVD, which is
you need to change the setting to suit the tv. if you using it with hdmi lead. you need to put it on aerial lead to tv and change the setting in the samsung setting. could be the setting are in 1080p and your tv does not have this function so change it to 1080i or 720i if the tv is not able to take 1080i.if don't have arial port there is scart or and picture out put on the back of the samsung you can use to fit to the tv.
Sep 21, 2013 | Hitachi Computers & Internet
Mar 10, 2012 | Audio Players & Recorders
I opened my thermometer to change the battery and the two red wires detached. Where do I reconnect them [solder them].
The two red wires more than likely go to the speaker on the back
cover. There is usually a small dab of solder where the wires go.
Re solder the two wires to the speaker and don't worry about which
wire go to witch dab of solder. The speaker is not polarity sensitive.
Jul 14, 2010 | Polder Swivel Head Digital Instant Read...
The external aerial wire has become detached from it's solder point, (still attached at the base of the aerial with the spade connecter) where should it be soldered back onto, on the PSB. Please advise?
Feb 08, 2010 | Makita BMR100 Radio
Hitachi ax-m136u aerial outside
Hi What you probably need is a line transformer.
If you have 300 ohm "twin lead " from outside and the receiver has coax , you need a 300 to 75 ohm transformer.
If you have a coax coming in to 2 screw terminals on the receiver , you need a 75 ohm to 300 ohm transformer.
Some place like Radio Shack or a stereo store would have them.
Jan 22, 2009 | Audio Players & Recorders
How to reboot hitachi dab radio
Sounds like what happened to my Sharp DAB receiver recently . - Swtch OFF completely from all power sources and proceed with the recommended RESET function.
Move set and/or aerial to be sure of a good strong signal before attempting a complete re-start and full AutoTune as per the instruction manual.
This operation certainly cured my problem although I never have found out what caused the failure in the first place!!!
Feb 29, 2008 | Audio Players & Recorders
76 people viewed this question
 Grubhead
Grubhead
